[petsc-users] petsc4py
Jed Brown jed at 59A2.org
Thu Sep 30 00:28:23 CDT 2010
And I get the same output as Lisandro if I comment the ts.setIJaconian line
(because that Jacobian is not being used).
Jed
On Sep 30, 2010 4:25 AM, "Lisandro Dalcin" <dalcinl at gmail.com> wrote:
2010/9/29 Николай Кутузов <kutuzovnp at gmail.com>:
> Where can i get it? I've tried this one --
> http://code.google.com/p/petsc4py/source/browse/demo/...
This is from branch release-1.1, a  new release 1.1.2 is planned for
the weekend. As you can see from the output at the very end, SNES is
using matrix free. Note that I've not changed he code code, just
passed -snes_mf
What petsc4py and PETSc versions are you using?
[dalcinl at trantor petsc4py-release-1.1]$ python demo/ode/rober.py
-ts_view -snes_mf
TS Object:
 type: theta
   Theta=0.5
   Extrapolation=no
 maximum steps=100
 maximum time=1e+30
 total number of nonlinear solver iterations=203
 total number of linear solver iterations=311
 SNES Object:
   type: ls
     line search variant: SNESLineSearchCubic
     alpha=0.0001, maxstep=1e+08, minlambda=1e-12
   maximum iterations=50, maximum function evaluations=10000
   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
   total number of function evaluations=8
   KSP Object:
     type: gmres
       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
       GMRES: happy breakdown tolerance 1e-30
     maximum iterations=10000, initial guess is zero
     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
     left preconditioning
     using PRECONDITIONED norm type for convergence test
   PC Object:
     type: none
     linear system matrix = precond matrix:
     Matrix Object:
       type=mffd, rows=3, cols=3
           matrix-free approximation:
             err=1e-07 (relative error in function evaluation)
             Using wp compute h routine
             Computes normA
             Does not compute normU
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100930/60f8f3d2/attachment-0001.htm>
