[petsc-users] memory management of external libraries
    SUN Chun
    Chun.SUN at 3ds.com
    Tue Sep 28 08:48:00 CDT 2010
Hi PETSc developers,
Sorry if this might be related to ML rather than PETSc. I have used PetscSetMalloc to override memory management of PETSc with my own code. Everything looks fine with PETSc. However I'm noticing that when using external library such as ML, we can't pass down our own allocator down. I believe this is a limitation from the interface of ML, though I'm not 100% sure.
Could you please comment on this? If this is true, is there any way around to replace the allocation from ML?
Thanks a lot,
Chun
This email and any attachments are intended solely for the use of the individual or entity to whom it is addressed and may be confidential and/or privileged.  If you are not one of the named recipients or have received this email in error, (i) you should not read, disclose, or copy it, (ii) please notify sender of your receipt by reply email and delete this email and all attachments, (iii) Dassault Systemes does not accept or assume any liability or responsibility for any use of or reliance on this email.For other languages, go to http://www.3ds.com/terms/email-disclaimer.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100928/972e1360/attachment.htm>
