[petsc-users] matrix-matrix addition
Shri abhyshr at mcs.anl.gov
Mon Sep 27 12:24:03 CDT 2010
Ok. I'll work on it this afternoon.
----- Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 27, 2010, at 12:04 PM, Jed Brown wrote:
> > On Mon, Sep 27, 2010 at 19:01, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> If you do not merge the column indices from A and B but simply count them all you will get over allocation, at worst a factor of two, though usually it would just be a little.
> > You count the number of *unique* entries.  You have two indices that
> > run through the arrays aj and bj, counting duplicates only once.  This
> > is easy to do since they are both sorted.
>    Yes, sounds like it could work and definitely better than my suggestion.
>   Shri, can you try this?
>    Barry
> > Jed
