[petsc-users] question about PCMG
Randall Mackie rlmackie862 at gmail.com
Fri Sep 24 15:12:08 CDT 2010
I am interested in exploring whether or not the PCMG would be beneficial for
my problem which I currently
solve using a KSP of bcgs and an ILU PC on a DA.
So, as a first step, I just wanted to see what happens if I switched my PC
from ILU to PCMG using the
Galerkin option.
So my command line options are:
mpiexec -np 1 /home/rmackie/d3fwd/V3_2_PETSc_DA_PCMG/d3fwd \
         -ksp_monitor_true_residual \
         -ksp_type bcgs \
         -pc_type mg \
         -pc_mg_levels 1 \
         -pc_mg_cycles v \
         -pc_mg_galerkin \
         -help \
<< EOF
However, I keep getting this error message:
Preconditioner (PC) Options
  -pc_type <ilu>: Preconditioner (one of) none jacobi pbjacobi bjacobi sor
lu shell mg
      eisenstat ilu icc cholesky asm ksp composite redundant nn mat
fieldsplit galerkin exotic openmp asa cp bfbt lsc redistribute (PCSetType)
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSCERROR:
or try
http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
  Multigrid options
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PCSetFromOptions_MG line 318 src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: [0] PCSetFromOptions line 166 src/ksp/pc/interface/pcset.c
[0]PETSC ERROR: [0] KSPSetFromOptions line 320 src/ksp/ksp/interface/itcl.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 4, Fri Jul 30 14:42:02
CDT 2010
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: /home/rmackie/d3fwd/V3_2_PETSc_DA_PCMG/d3fwd on a linux-int
named he999.prod.houston.nam.slb.com by rmackie Fri Sep 24 13:06:12 2010
[0]PETSC ERROR: Libraries linked from
/home/rmackie/SPARSE/PETsc/petsc-3.1-p4/linux-intel-debug/lib
[0]PETSC ERROR: Configure run at Fri Sep 24 13:02:26 2010
[0]PETSC ERROR: Configure options --with-fortran --with-fortran-kernels=1
--with-blas-lapack-dir=/opt/intel/cmkl/10.2.2.025/lib/em64t-with-scalar-type=complex
--with-debugging=1 --with-cc=mpiicc
--with-cxx=mpiicpc --with-fc=mpiifort
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown
file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I am running the latest version of Petsc. Any help on getting past this
error message would be appreciated.
Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100924/71cd027c/attachment.htm>
