[petsc-users] using superlu_dist
Matt Funk mafunk at nmsu.edu
Fri Sep 10 15:59:46 CDT 2010
i was wondering on how i need to set the matrix type when i want to use the
superlu_dist solver.
Right now what i have is:
  if (m_preCondType == "LU_SUPERLU") {
    if (numProc() > 1)
      m_ierr = MatSetType(m_globalMatrix, MATAIJ);
    else {
      m_ierr = MatSetType(m_globalMatrix, MATSEQAIJ);
This i believe is according to the table in the petsc users manual (p.82).
Anyway, things work ok on 1 processor. However, when i try 8 processors (i.e.
it tells me:
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: No support for this operation for this object type!
[3]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc direct
solver!
So i guess i should not use the MATAIJ matrix format? I also tried the
MATMPIAIJ format, but got the same problem.
So how is one supposed to use it? Obviously i am doing something wrong. Any
help is appreciated.
thanks
matt
