[petsc-users] Divergence termination of KSP iteration despite disabled convergence test
Florian Rathgeber florian.rathgeber at googlemail.com
Wed Sep 8 05:13:27 CDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I instructed KSP (cg, jacobi) to run for a fixed number of CG iterations
(for benchmarking purposes) by disabling convergence testing and norm
computation as so:
    KSPSetConvergenceTest(ksp, KSPSkipConverged, PETSC_NULL, PETSC_NULL);
    KSPSetNormType(ksp, KSP_NORM_NO);
This worked fine for all my tests but Poisson. I tried solving Poisson
on P1, P2, and P3 elements with the right hand side 1 and no Dirichlet
condition (the result was not supposed to be meaningful, it was just for
benchmarking) and every time iteration terminated prematurely with
reason KSP_DIVERGED_INDEFINITE_MAT (-10).
To me, there are several strange issues with this:
1) I would expect KSPSkipConverged to disable the divergence check as well
2) I don't understand the divergence reason, how would the matrix
suddenly become indefinite?
3) Increasing the divergence limit to a very high value (1e50) doesn't
change anything
Could someone elaborate on these issues?
So my question is: how to safely disable this divergence test so that
KSP runs for the number of iterations I expect it to run?
Thank you for any hints
Florian
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.12 (MingW32)
iEYEARECAAYFAkyHYccACgkQ8Z6llsctAxafpQCgmZsMxvCc5UYEVsO+ibRXLM+j
1cMAoMeBD/iz7JL0VZaz8sCVCqTFrOVE
=dMKQ
-----END PGP SIGNATURE-----
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100908/5b1e7691/attachment.bin>
