[petsc-users] nnz's in finite element stiffness matrix
Dave Makhija makhijad at colorado.edu
Tue Sep 7 19:28:07 CDT 2010
I used to have a decent setup that worked as follows:
1. Build node->element table (For a given node, which elements contain
this node. You may already have this) OR build a node connectivity
table (For a given node, which nodes are connected).
2. Build element->node table (For a given element, which nodes are
contained in this element. You probably already have this)
4. Loop over nodes and get the global DOFs contained in that node. For
those DOF id rows, add the number of nodal DOFs for each unique node
connected to the current node using the node->element and
element->node table OR the node connectivity table.
5. Loop over elements and add the number of elemental DOFs to each
nodal DOF global id row contained in this element using element->node
table. Also add the number of elemental DOF's and the sum of the nodal
DOF's to the elemental global DOF id rows.
6. Add contributions of multi-point constraints, i.e. Lagrange multiplier DOF's.
Note that in parallel you may have to scatter values to global DOF ids
owned by off-processors to get an accurate Onz. This setup as a whole
can be pretty fast but can scale poorly if you don't have a good way
of developing the node-element table or node connectivity since it
requires some loops within loops.
Another way is to use the PETSc preallocation macros such as
MatPreallocateSet. You can essentially do a "dry run" of a Jacobian
Matrix assembly into the preallocation macros. They can be tricky to
use, so if you have problems you can simply look at the PETSc
documentation for those macros and hand code them yourself. This
strategy will overestimate the memory, but a matrix inversion will
dwarf how much this will waste.  I vaguely remember a PETSc archive
asking how to free the unneeded memory if this is absolutely
necessary, but I don't think anything really worked without a full
matrix copy. If someone by chance knows how the Trilinos
"OptimizeStorage" routine works for Epetra matricies they could
potentially shed some light on how to do this - if it is even
possible.
Dave Makhija
On Tue, Sep 7, 2010 at 2:24 PM, stali <stali at purdue.edu> wrote:
> Petsc-users
> How can I efficiently calculate the _exact_ number of non-zeros that would
> be in the global sparse (stiffness) matrix given an unstructured mesh?
> Thanks
