[petsc-users] valgrind error comes out when upgrade from ubuntu 8.04 LTS to 10.04
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep  7 12:56:30 CDT 2010
Ubuntu valgrind is at /usr/bin/valgrind.
/usr/local/bin/valgrind might be a personal install. [perhaps compiled on 8.04]
Try:
~/soft/petsc-3.1-p4/externalpackages/mpich2-1.0.8/bin/mpiexec -np 2 /usr/bin/valgrind --tool=memcheck ./ex19.exe -malloc off -da_grid_x 30 -da_grid_y 30
[and then delete valgrind installed at /usr/local]
Satish
On Tue, 7 Sep 2010, Rebecca Xuefei Yuan wrote:
> It is
> rebecca at YuanWork:~/soft$ which valgrind
> R
> Quoting Satish Balay <balay at mcs.anl.gov>:
> > what do you have for
> > which valgrind
> > Satish
> > > Dear Satish,
> > > I checked the update the valgrind as
> > > rebecca at YuanWork:~/soft$ sudo apt-get install valgrind
> > > [sudo] password for rebecca:
> > > Reading package lists... Done
> > > Building dependency tree
> > > Reading state information... Done
> > > valgrind is already the newest version.
> > > The following packages were automatically installed and are no longer
> > > required:
> > > nabi ttf-wqy-zenhei ttf-takao-mincho libgcj8-dev ttf-alee gcj-4.2
> > > ttf-takao-gothic gij xfonts-wqy ttf-unfonts-extra ttf-kacst
> > > Use 'apt-get autoremove' to remove them.
> > > 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
> > > rebecca at YuanWork:~/soft$ dpkg -l valgrind
> > > Desired=Unknown/Install/Remove/Purge/Hold
> > > Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
> > > |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
> > > ||/ Name           Version        Description
> > > ii  valgrind       1:3.6.0~svn201 A memory debugger and profiler
> > > It is a self installed valgrind or installed through ubuntu 10.04?
> > > Thanks a lot!
> > > Rebecca
> > > > > Dear Satish,
> > > > > I reinstalled PETSc by "rm -rf petsc-3.1-p4" and downloaded
> > > > > "petsc-lite-3.1-p4.tar.gz" to start over.
> > > > > The commands are
> > > > > ./config/configure.py --with-cc=gcc --with-fc=gfortran
> > > > > --download-f-blas-lapack=1 --download-mpich=1
> > > > > make PETSC_DIR=/home/rebecca/soft/petsc-3.1-p4
> > > > > PETSC_ARCH=linux-gnu-c-debug
> > > > > all
> > > > > test
> > > > > When I check the valgrind version
> > > > > rebecca at YuanWork:~/soft$ valgrind --version
> > > > > valgrind-3.5.0
> > > > > When I check at
> > > > > http://valgrind.org/
> > > > > the current release is 3.5.0. How could you get 3.6?
> > > > Are you using your own install of valgrind? [and not ubuntu install?]
> > > > If so - did you reinstall it after your OS upgrade?
> > > > Looks like valgrind packaged by ubuntu/debian is an SVN snapshot of
> > > > upcoming 3.6
> > > > balay at petsc:~ $ dpkg -l valgrind
> > > > ii  valgrind               1:3.6.0~svn20100212-0u A memory debugger  and
> > > > profiler
> > > > balay at petsc:~ $
> > > > So your choice is to either:
> > > > 1. install ubuntu valgrind [sudo apt-get install valgrind] - and  delete
> > > > personal copy
> > > > 2. reinstall valgrind from source [for this upgraded OS]
> > > > Satish
> > > Rebecca Xuefei YUAN
> > > Department of Applied Physics and Applied Mathematics
> > > Columbia University
> > > Tel:917-399-8032
> > > www.columbia.edu/~xy2102
> Rebecca Xuefei YUAN
> Columbia University
> Tel:917-399-8032
