[petsc-users] [petsc-maint #52322] Regarding PETSC using for OOFEM parallel and SLEPc library installation
    Matthew Knepley
    petsc-maint at mcs.anl.gov
    Tue Sep  7 06:54:53 CDT 2010
The first problem is that we changed the structure slightly in the latest
release. Instead of
include ${PETSC_DIR}/conf/base
you use
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
     Matt
On Tue, Sep 7, 2010 at 11:37 AM, shraddha <shraddhav at cdac.in> wrote:
> Dear Sir/Madam,
>              I have installed petsc-3.1-p4
> petsc-3.1-p4]$ time ./configure 2>&1 | tee LOG-config-2
> Compilers:
>  C Compiler:         mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -g3
>  Fortran Compiler:   mpif90  -Wall -Wno-unused-variable -g
> Linkers:
>  Static linker:   /usr/bin/ar cr
> MPI:
>  Includes: -I/opt/mpich2/gnu/include
> X11:
>  Includes:
>  Library:  -lX11
> BLAS/LAPACK: -llapack -lblas
> PETSc:
>  PETSC_ARCH: linux-gnu-c-debug
>  PETSC_DIR: /home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4
>  Clanguage: C
>  Memory alignment: 16
>  Scalar type: real
>  Precision: double
>  shared libraries: disabled
>  dynamic libraries: disabled
> xxx=========================================================================
> xxx
>   Configure stage complete. Now build PETSc libraries with:
>   make PETSC_DIR=/home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4
> PETSC_ARCH=linux-gnu-c-debug all
> xxx
> MAKE:
> [shraddha at Dell petsc-3.1-p4]$ ls linux-gnu-c-debug/
> bin  conf  include  lib
> [shraddha at Dell petsc-3.1-p4]$ ls linux-gnu-c-debug/bin/
> [shraddha at Dell petsc-3.1-p4]$ ls linux-gnu-c-debug/lib/
> libpetsc.a
> [shraddha at Dell petsc-3.1-p4]$ ls linux-gnu-c-debug/include/
> petscaodef.mod     petscda.mod     petsckspdef.mod     petscmeshdef.mod
> petscpcdef.mod    petscsys.mod
> petscao.mod        petscdef.mod    petscksp.mod        petscmesh.mod
> petscpc.mod       petsctsdef.mod
> petscconf.h        petscfix.h      petscmachineinfo.h  petscmgdef.mod
> petscsnesdef.mod  petscts.mod
> petscconfiginfo.h  petscisdef.mod  petscmatdef.mod     petscmg.mod
> petscsnes.mod     petscvecdef.mod
> petscdadef.mod     petscis.mod     petscmat.mod        petsc.mod
> petscsysdef.mod   petscvec.mod
> I have set PETSC_ARCH =linux-gnu or linux-gnu-c-debug in bashrc file.
> Now I wanted to install OOFEM parallel module.
> #export OOFEM_DIR=/home/shraddha/ONAMA/mechanical/OOFEM/oofem-1.8
> export OOFEM_DIR=/home/shraddha/ONAMA/mechanical/OOFEM/oofem-1.9
> ./configure --prefix=/home/shraddha/ONAMA/mechanical/OOFEM/oofem-1.9
> --enable-poofem --with-MPIDIR=/opt/mpich2/gnu --enable-petsc
> --with-PETSCDIR=/home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4
> --with-PARMETISDIR=/home/shraddha/PARMETIS/gnu/ParMetis-3.1.1
> PETSC_ARCH=linux-gnu-c-debug CXX=mpicxx
> make
> makefile:10: /home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4/conf/base: No
> such
> file or directory
> makefile:63: generalbc.d: No such file or directory
> makefile:63: boundary.d: No such file or directory
> makefile:63: crosssection.d: No such file or directory
> makefile:63: dictionr.d: No such file or directory
> makefile:63: dof.d: No such file or directory
> I am not having petsc-3.1-p4/conf/base file.
> What should I do in this case???Please guide me.
> Another kind of error I am getting when I am trying to install SLEPc
> library:
> slepc-3.1-p2]$ ./configure --help
> SLEPc Configure Help
>  --prefix=<dir>                   : Specifiy location to install SLEPc
> (e.g., /usr/local)
> ARPACK:
>  --with-arpack                    : Indicate if you wish to test for ARPACK
> (PARPACK)
>  --with-arpack-dir=<dir>          : Indicate the directory for ARPACK
> libraries
>  --with-arpack-flags=<flags>      : Indicate comma-separated flags for
> linking ARPACK
> BLZPACK:
>  --with-blzpack                   : Indicate if you wish to test for
> BLZPACK
>  --with-blzpack-dir=<dir>         : Indicate the directory for BLZPACK
> libraries
>  --with-blzpack-flags=<flags>     : Indicate comma-separated flags for
> linking BLZPACK
> TRLAN:
>  --with-trlan                     : Indicate if you wish to test for TRLAN
>  --with-trlan-dir=<dir>           : Indicate the directory for TRLAN
> libraries
>  --with-trlan-flags=<flags>       : Indicate comma-separated flags for
> linking TRLAN
> PRIMME:
>  --with-primme                    : Indicate if you wish to test for PRIMME
>  --with-primme-dir=<dir>          : Indicate the directory for PRIMME
> libraries
>  --with-primme-flags=<flags>      : Indicate comma-separated flags for
> linking PRIMME
> slepc4py:
>  --download-slepc4py              : Download and install slepc4py in SLEPc
> directory
> --prefix=/home/shraddha/ONAMA/mechanical/OOFEM/SLEPc/slepc-3.1-p2
> Checking environment...
> ERROR: SLEPc cannot be configured for non-source installation if PETSc is
> not configured in the same way.
> Please Guide me regarding this.
> Regards,
> Shraddha Desai
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
>  Dear Sir/Madam,
>               I have installed *petsc-3.1-p4*
> *petsc-3.1-p4]$ time ./configure 2>&1 | tee LOG-config-2*
> *Compilers:*
> *  C Compiler:         mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing
> -g3*
> *  Fortran Compiler:   mpif90  -Wall -Wno-unused-variable -g*
> Linkers:
> MPI:
> X11:
>   Includes:
>   Library:  -lX11
> *BLAS/LAPACK: -llapack -lblas*
> *PETSc:*
> *  PETSC_ARCH: linux-gnu-c-debug*
> *  PETSC_DIR: /home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4*
>   Clanguage: C
>   Scalar type: real
>   Precision: double
> xxx=========================================================================xxx
> *MAKE:*
> *make PETSC_DIR=/home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4
> PETSC_ARCH=linux-gnu-c-debug all*
> [shraddha@*Dell petsc-3.1-p4]$ ls linux-gnu-c-debug/*
> *bin  conf  include  lib*
> [shraddha at Dell *petsc-3.1-p4]$ ls linux-gnu-c-debug/bin/*
> [shraddha at Dell *petsc-3.1-p4]$ ls linux-gnu-c-debug/lib/*
> *libpetsc.a*
> [shraddha at Dell *petsc-3.1-p4]$ ls linux-gnu-c-debug/include/*
> *Now I wanted to install OOFEM parallel module.*
> *export OOFEM_DIR=/home/shraddha/ONAMA/mechanical/OOFEM/oofem-1.9*
> *./configure* --prefix=/home/shraddha/ONAMA/mechanical/OOFEM/oofem-1.9
> --with-PARMETISDIR=/home/shraddha/PARMETIS/gnu/ParMetis-3.1.1 *
> PETSC_ARCH=linux-gnu-c-debug* CXX=mpicxx
> *make*
> *makefile:10: /home/shraddha/PETSC/petsc-31p4/petsc-3.1-p4/conf/base: No
> such file or directory*
> I am not having *petsc-3.1-p4/conf/base file.*
> *What should I do in this case???Please guide me.*
> library:
> *slepc-3.1-p2]$ ./configure --help*
> (e.g., /usr/local)
> ARPACK:
> ARPACK (PARPACK)
> libraries
> linking ARPACK
> BLZPACK:
> BLZPACK
> libraries
> linking BLZPACK
> TRLAN:
> libraries
> linking TRLAN
> PRIMME:
> PRIMME
> libraries
> linking PRIMME
> slepc4py:
> directory
> *slepc-3.1-p2]$ ./configure*--prefix=/home/shraddha/ONAMA/mechanical/OOFEM/SLEPc/slepc-3.1-p2
> Regards,
> Shraddha Desai
> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100907/179c397f/attachment-0001.htm>
