[petsc-users] valgrind error comes out when upgrade from ubuntu 8.04 LTS to	10.04
    Satish Balay
    balay at mcs.anl.gov
    Mon Sep  6 20:43:06 CDT 2010
I can't reproduce this. How did you build PETSc?
Satish
-------------- [configured with: ./configure  CC=gcc FC=gfortran --download-mpich=1] -------------
petsc:/sandbox/balay/petsc-3.1-p4/src/snes/examples/tutorials>cat /etc/issue
Ubuntu 10.04.1 LTS \n \l
petsc:/sandbox/balay/petsc-3.1-p4/src/snes/examples/tutorials>/sandbox/balay/petsc-3.1-p4/linux-gnu-c-debug/bin/mpiexec -n 2 valgrind -q --tool=memcheck ./ex19  -malloc off -da_grid_x 30 -da_grid_y 30
lid velocity = 0.000287274, prandtl # = 1, grashof # = 1
Number of Newton iterations = 2
On Mon, 6 Sep 2010, Barry Smith wrote:
>   Looks like ubuntu 10.04 is a terrible release without proper testing. All those are problems with the OS and system libraries. Unfortunately it makes it impossible to find errors in PETSc since it gives all those meaningless errors.
>     Barry
> On Sep 6, 2010, at 7:31 PM, Rebecca Xuefei Yuan wrote:
> > Dear all,
> > I upgrade my laptop from ubuntu 8.04 LTS to 10.04, after the upgrade, I reinstalled PETSc, but there are tons of valgrind errors coming out even the code is unchanged. Then I tried with
> > ~/soft/petsc-3.1-p4/src/snes/examples/tutorials/ex19.c
> > of the command:
> > ~/soft/petsc-3.1-p4/externalpackages/mpich2-1.0.8/bin/mpiexec -np 2 valgrind --tool=memcheck ./ex19.exe -malloc off -da_grid_x 30 -da_grid_y 30
> > as instructed in FAQ. However, the errors are very long(hope it is right to post the full log of valgrind here...), as
> > rebecca at YuanWork:~/linux/code/twoway/twoway_brandnew/trunk/set_a$ ~/soft/petsc-3.1-p4/externalpackages/mpich2-1.0.8/bin/mpiexec -np 2 valgrind --tool=memcheck  ./ex19.exe -malloc off -da_grid_x 30 -da_grid_y 30
> > ==2174== Memcheck, a memory error detector
> > ==2175== Memcheck, a memory error detector
> > ==2175== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et al.
> > ==2175== Using Valgrind-3.5.0 and LibVEX; rerun with -h for copyright info
> > ==2175== Command: ./ex19.exe -malloc off -da_grid_x 30 -da_grid_y 30
> > ==2175==
> > ==2174== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et al.
> > ==2174== Using Valgrind-3.5.0 and LibVEX; rerun with -h for copyright info
> > ==2174== Command: ./ex19.exe -malloc off -da_grid_x 30 -da_grid_y 30
> > ==2174==
> > ==2174== Conditional jump or move depends on uninitialised value(s)
> > ==2174==    at 0x400B217: _dl_relocate_object (do-rel.h:104)
> > ==2174==    by 0x40031D0: dl_main (rtld.c:2229)
> > ==2174==    by 0x4014206: _dl_sysdep_start (dl-sysdep.c:243)
> > ==2174==    by 0x4000C6C: _dl_start (rtld.c:333)
> > ==2174==    by 0x4000856: ??? (in /lib/ld-2.11.1.so)
> > ==2174==
> > ==2174==    at 0x400AF0F: _dl_relocate_object (do-rel.h:117)
> > ==2174==
> > ==2175== Conditional jump or move depends on uninitialised value(s)
> > ==2175==    at 0x400B217: _dl_relocate_object (do-rel.h:104)
> > ==2175==    by 0x40031D0: dl_main (rtld.c:2229)
> > ==2175==    by 0x4014206: _dl_sysdep_start (dl-sysdep.c:243)
> > ==2175==    by 0x4000C6C: _dl_start (rtld.c:333)
> > ==2175==    by 0x4000856: ??? (in /lib/ld-2.11.1.so)
> > ==2175==
> > ==2175==    at 0x400AF0F: _dl_relocate_object (do-rel.h:117)
> > ==2175==
> > ==2174==    at 0x400B27A: _dl_relocate_object (do-rel.h:127)
> > ==2174==
> > ==2175==    at 0x400B27A: _dl_relocate_object (do-rel.h:127)
> > ==2175==
> > ==2174==    at 0x400A5DE: _dl_relocate_object (do-rel.h:65)
> > ==2174==    by 0x40030FE: dl_main (rtld.c:2292)
> > ==2174==
> > ==2174==    at 0x400A5E6: _dl_relocate_object (do-rel.h:68)
> > ==2175==    at 0x400A5DE: _dl_relocate_object (do-rel.h:65)
> > ==2175==    by 0x40030FE: dl_main (rtld.c:2292)
> > ==2175==
> > ==2175==    at 0x400A5E6: _dl_relocate_object (do-rel.h:68)
> > ==2175==
> > ==2175==
> > ==2174==
> > ==2174==
> > ==2175==    at 0x4319794: __strlen_sse2 (strlen.S:93)
> > ==2175==    by 0x87E2BD2: T.206 (simple_pmi.c:985)
> > ==2175==    by 0x87E2FF4: PMI_Init (simple_pmi.c:206)
> > ==2175==    by 0x87C742A: MPID_Init (mpid_init.c:331)
> > ==2175==    by 0x879F65C: MPIR_Init_thread (initthread.c:288)
> > ==2175==    by 0x879F15A: PMPI_Init (init.c:106)
> > ==2175==    by 0x80AEE12: PetscInitialize (pinit.c:561)
> > ==2175==    by 0x804BA0C: main (ex19.c:96)
> > ==2175==
> > ==2175==    at 0x43197CB: __strlen_sse2 (strlen.S:116)
> > ==2175==
> > ==2175==    at 0x87F559E: PMIU_writeline (simple_pmiutil.c:180)
> > ==2175==
> > ==2175== Use of uninitialised value of size 4
> > ==2175==    at 0x87F55A4: PMIU_writeline (simple_pmiutil.c:184)
> > ==2175==
> > ==2175== Syscall param write(count) contains uninitialised byte(s)
> > ==2175==    at 0x41B1EB3: __write_nocancel (syscall-template.S:82)
> > ==2175==
> > ==2175==    at 0x87F566C: PMIU_writeline (simple_pmiutil.c:197)
> > ==2175==
> > ==2174==    at 0x4319794: __strlen_sse2 (strlen.S:93)
> > ==2174==    by 0x87E2BD2: T.206 (simple_pmi.c:985)
> > ==2174==    by 0x87E2FF4: PMI_Init (simple_pmi.c:206)
> > ==2174==    by 0x87C742A: MPID_Init (mpid_init.c:331)
> > ==2174==    by 0x879F65C: MPIR_Init_thread (initthread.c:288)
> > ==2174==    by 0x879F15A: PMPI_Init (init.c:106)
> > ==2174==    by 0x80AEE12: PetscInitialize (pinit.c:561)
> > ==2174==    by 0x804BA0C: main (ex19.c:96)
> > ==2174==
> > ==2174==    at 0x43197CB: __strlen_sse2 (strlen.S:116)
> > ==2174==
> > ==2174==    at 0x87F559E: PMIU_writeline (simple_pmiutil.c:180)
> > ==2174==
> > ==2174== Use of uninitialised value of size 4
> > ==2174==    at 0x87F55A4: PMIU_writeline (simple_pmiutil.c:184)
> > ==2174==
> > ==2174== Syscall param write(count) contains uninitialised byte(s)
> > ==2174==    at 0x41B1EB3: __write_nocancel (syscall-template.S:82)
> > ==2174==
> > ==2174==    at 0x87F566C: PMIU_writeline (simple_pmiutil.c:197)
> > ==2174==
> > ==2175==    at 0x43BE348: __strcmp_ssse3 (strcmp-ssse3.S:150)
> > ==2175==    by 0x87E2678: PMI_KVS_Get_my_name (simple_pmi.c:435)
> > ==2175==    by 0x87C74C7: MPID_Init (mpid_init.c:381)
> > ==2175==
> > ==2175==    at 0x43BF5B7: __strcmp_ssse3 (strcmp-ssse3.S:1887)
> > ==2175==
> > ==2175==    at 0x43BF5C0: __strcmp_ssse3 (strcmp-ssse3.S:1890)
> > ==2175==
> > ==2175==    at 0x43BF5C5: __strcmp_ssse3 (strcmp-ssse3.S:1893)
> > ==2175==
> > ==2175==    at 0x43BF5CA: __strcmp_ssse3 (strcmp-ssse3.S:1896)
> > ==2175==
> > ==2175==    by 0x87CABAB: MPIDI_PG_InitConnKVS (mpidi_pg.c:753)
> > ==2175==    by 0x87C7526: MPID_Init (mpid_init.c:417)
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2174==    at 0x43BE348: __strcmp_ssse3 (strcmp-ssse3.S:150)
> > ==2174==    by 0x87E2678: PMI_KVS_Get_my_name (simple_pmi.c:435)
> > ==2174==    by 0x87C74C7: MPID_Init (mpid_init.c:381)
> > ==2174==
> > ==2174==    at 0x43BF5B7: __strcmp_ssse3 (strcmp-ssse3.S:1887)
> > ==2174==
> > ==2174==    at 0x43BF5C0: __strcmp_ssse3 (strcmp-ssse3.S:1890)
> > ==2174==
> > ==2174==    at 0x43BF5C5: __strcmp_ssse3 (strcmp-ssse3.S:1893)
> > ==2174==
> > ==2174==    at 0x43BF5CA: __strcmp_ssse3 (strcmp-ssse3.S:1896)
> > ==2174==
> > ==2174==    by 0x87CABAB: MPIDI_PG_InitConnKVS (mpidi_pg.c:753)
> > ==2174==    by 0x87C7526: MPID_Init (mpid_init.c:417)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2175==    at 0x4319863: __GI_strlen (strlen.S:138)
> > ==2175==    by 0x438AD43: gethostbyname_r@@GLIBC_2.1.2 (getXXbyYY_r.c:191)
> > ==2175==    by 0x438A685: gethostbyname (getXXbyYY.c:117)
> > ==2175==    by 0x87CC54F: MPIDU_CH3U_GetSockInterfaceAddr (ch3u_getinterfaces.c:130)
> > ==2175==    by 0x87CBC56: MPIDI_CH3U_Get_business_card_sock (ch3u_connect_sock.c:428)
> > ==2175==    by 0x87F413B: MPIDI_CH3U_Init_sock (ch3u_init_sock.c:79)
> > ==2175==    by 0x87EE511: MPIDI_CH3_Init (ch3_init.c:43)
> > ==2175==    by 0x87C7554: MPID_Init (mpid_init.c:92)
> > ==2175==
> > ==2175==    at 0x431986D: __GI_strlen (strlen.S:144)
> > ==2175==
> > ==2174==    at 0x4319863: __GI_strlen (strlen.S:138)
> > ==2174==    by 0x438AD43: gethostbyname_r@@GLIBC_2.1.2 (getXXbyYY_r.c:191)
> > ==2174==    by 0x438A685: gethostbyname (getXXbyYY.c:117)
> > ==2174==    by 0x87CC54F: MPIDU_CH3U_GetSockInterfaceAddr (ch3u_getinterfaces.c:130)
> > ==2174==    by 0x87CBC56: MPIDI_CH3U_Get_business_card_sock (ch3u_connect_sock.c:428)
> > ==2174==    by 0x87F413B: MPIDI_CH3U_Init_sock (ch3u_init_sock.c:79)
> > ==2174==    by 0x87EE511: MPIDI_CH3_Init (ch3_init.c:43)
> > ==2174==    by 0x87C7554: MPID_Init (mpid_init.c:92)
> > ==2174==
> > ==2174==    at 0x431986D: __GI_strlen (strlen.S:144)
> > ==2174==
> > ==2175== Invalid read of size 4
> > ==2175==    at 0x431983B: __GI_strlen (strlen.S:115)
> > ==2175==    by 0x43843CE: __nss_lookup (nsswitch.c:191)
> > ==2175==    by 0x438596E: __nss_hosts_lookup2 (XXX-lookup.c:76)
> > ==2175==    by 0x438AF0F: gethostbyname_r@@GLIBC_2.1.2 (getXXbyYY_r.c:200)
> > ==2175==  Address 0x44308f8 is 40 bytes inside a block of size 42 alloc'd
> > ==2175==    at 0x4023BF3: malloc (vg_replace_malloc.c:195)
> > ==2175==    by 0x4384583: nss_parse_service_list (nsswitch.c:622)
> > ==2175==    by 0x4384E71: __nss_database_lookup (nsswitch.c:775)
> > ==2175==    by 0x43859AD: __nss_hosts_lookup2 (XXX-lookup.c:71)
> > ==2175==
> > ==2174== Invalid read of size 4
> > ==2174==    at 0x431983B: __GI_strlen (strlen.S:115)
> > ==2174==    by 0x43843CE: __nss_lookup (nsswitch.c:191)
> > ==2174==    by 0x438596E: __nss_hosts_lookup2 (XXX-lookup.c:76)
> > ==2174==    by 0x438AF0F: gethostbyname_r@@GLIBC_2.1.2 (getXXbyYY_r.c:200)
> > ==2174==  Address 0x44308f8 is 40 bytes inside a block of size 42 alloc'd
> > ==2174==    at 0x4023BF3: malloc (vg_replace_malloc.c:195)
> > ==2174==    by 0x4384583: nss_parse_service_list (nsswitch.c:622)
> > ==2174==    by 0x4384E71: __nss_database_lookup (nsswitch.c:775)
> > ==2174==    by 0x43859AD: __nss_hosts_lookup2 (XXX-lookup.c:71)
> > ==2174==
> > ==2174==    by 0x4011D15: dl_open_worker (dl-open.c:367)
> > ==2174==    by 0x400D875: _dl_catch_error (dl-error.c:178)
> > ==2174==    by 0x4011675: _dl_open (dl-open.c:583)
> > ==2174==    by 0x43AA4A1: do_dlopen (dl-libc.c:86)
> > ==2174==    by 0x43AA5A0: dlerror_run (dl-libc.c:47)
> > ==2174==    by 0x43AA6BA: __libc_dlopen_mode (dl-libc.c:160)
> > ==2174==    by 0x43842E4: __nss_lookup_function (nsswitch.c:405)
> > ==2174==
> > ==2174==
> > ==2175==    by 0x4011D15: dl_open_worker (dl-open.c:367)
> > ==2175==    by 0x400D875: _dl_catch_error (dl-error.c:178)
> > ==2175==    by 0x4011675: _dl_open (dl-open.c:583)
> > ==2175==    by 0x43AA4A1: do_dlopen (dl-libc.c:86)
> > ==2175==    by 0x43AA5A0: dlerror_run (dl-libc.c:47)
> > ==2175==    by 0x43AA6BA: __libc_dlopen_mode (dl-libc.c:160)
> > ==2175==    by 0x43842E4: __nss_lookup_function (nsswitch.c:405)
> > ==2175==
> > ==2175==
> > ==2174==    by 0x87E19C7: GetResponse (simple_pmi.c:1049)
> > ==2174==    by 0x87E2846: PMI_KVS_Put (simple_pmi.c:543)
> > ==2174==    by 0x87CAF27: MPIDI_PG_SetConnInfo (mpidi_pg.c:568)
> > ==2174==    by 0x87EE522: MPIDI_CH3_Init (ch3_init.c:48)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2175==    by 0x87E19C7: GetResponse (simple_pmi.c:1049)
> > ==2175==    by 0x87E2846: PMI_KVS_Put (simple_pmi.c:543)
> > ==2175==    by 0x87CAF27: MPIDI_PG_SetConnInfo (mpidi_pg.c:568)
> > ==2175==    by 0x87EE522: MPIDI_CH3_Init (ch3_init.c:48)
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2174==    by 0x87CAF44: MPIDI_PG_SetConnInfo (mpidi_pg.c:579)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==    at 0x43BF5CF: __strcmp_ssse3 (strcmp-ssse3.S:1899)
> > ==2174==
> > ==2175==    by 0x87CAF44: MPIDI_PG_SetConnInfo (mpidi_pg.c:579)
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==    at 0x43BF5CF: __strcmp_ssse3 (strcmp-ssse3.S:1899)
> > ==2175==    by 0x80AEE12: PetscI==2174== Invalid read of size 4
> > ==2174==    by 0x438564E: __nss_passwd_lookup2 (XXX-lookup.c:76)
> > ==2174==    by 0x433D0DE: getpwuid_r@@GLIBC_2.1.2 (getXXbyYY_r.c:200)
> > ==2174==    by 0x433C92E: getpwuid (getXXbyYY.c:117)
> > ==2174==    by 0x80BC53A: PetscGetUserName (fuser.c:66)
> > ==2174==    by 0x80822FF: PetscErrorPrintfInitialize (errtrace.c:68)
> > ==2174==    by 0x80AEED1: PetscInitialize (pinit.c:576)
> > ==2174==  Address 0x4430700 is 40 bytes inside a block of size 43 alloc'd
> > ==2174==  nitialize (pinit.c:561)
> > ==2175==
> > ==2174==
> > ==2175==    by 0x438564E: __nss_passwd_lookup2 (XXX-lookup.c:76)
> > ==2175==    by 0x433D0DE: getpwuid_r@@GLIBC_2.1.2 (getXXbyYY_r.c:200)
> > ==2175==    by 0x433C92E: getpwuid (getXXbyYY.c:117)
> > ==2175==    by 0x80BC53A: PetscGetUserName (fuser.c:66)
> > ==2175==    by 0x80822FF: PetscErrorPrintfInitialize (errtrace.c:68)
> > ==2175==    by 0x80AEED1: PetscInitialize (pinit.c:576)
> > ==2175==  Address 0x4430700 is 40 bytes inside a block of size 43 alloc'd
> > ==2175==
> > ==2174==    by 0x80885F9: PetscVSNPrintf (mprint.c:95)
> > ==2174==    by 0x8088B22: PetscSNPrintf (mprint.c:228)
> > ==2174==    by 0x8082456: PetscErrorPrintfInitialize (errtrace.c:71)
> > ==2174==
> > ==2174==
> > ==2174==    by 0x80A0906: PetscOptionsFindPair_Private (options.c:987)
> > ==2174==    by 0x80A1E0E: PetscOptionsGetTruth (options.c:1304)
> > ==2174==    by 0x80824DE: PetscErrorPrintfInitialize (errtrace.c:73)
> > ==2174==
> > ==2174==    by 0x8082563: PetscErrorPrintfInitialize (errtrace.c:77)
> > ==2174==
> > ==2174==    by 0x809CFD4: PetscOptionsInsert (options.c:516)
> > ==2174==    by 0x80AF4BD: PetscInitialize (pinit.c:629)
> > ==2174==
> > ==2175==    by 0x80885F9: PetscVSNPrintf (mprint.c:95)
> > ==2175==    by 0x8088B22: PetscSNPrintf (mprint.c:228)
> > ==2175==    by 0x8082456: PetscErrorPrintfInitialize (errtrace.c:71)
> > ==2175==
> > ==2175==
> > ==2174==    by 0x87E420A: PMI_KVS_Get (simple_pmi.c:572)
> > ==2174==    by 0x87CA9F9: getConnInfoKVS (mpidi_pg.c:622)
> > ==2174==    by 0x87CC11A: MPIDI_CH3I_VC_post_sockconnect (ch3u_connect_sock.c:1097)
> > ==2174==    by 0x87EEF6B: MPIDI_CH3_iStartMsg (ch3_istartmsg.c:177)
> > ==2174==    by 0x87C6341: MPIDI_CH3_EagerContigShortSend (ch3u_eager.c:250)
> > ==2174==    by 0x87C8AC6: MPID_Send (mpid_send.c:115)
> > ==2174==    by 0x879376B: MPIC_Send (helper_fns.c:34)
> > ==2174==    by 0x878BB6A: MPIR_Bcast (bcast.c:227)
> > ==2174==    by 0x878C6A1: PMPI_Bcast (bcast.c:761)
> > ==2174==    by 0x809C467: PetscOptionsInsertFile (options.c:436)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==    by 0x87CA9F9: getConnIn==2175== Conditional jump or move depends on uninitialised value(s)
> > ==2175==    by 0x80A0906: PetscOptionsFindPair_Private (options.c:987)
> > ==2175==    by 0x80A1E0E: PetscOptionsGetTruth (options.c:1304)
> > ==2175==    by 0x80824DE: PetscErrorPrintfInitialize (errtrace.c:73)
> > ==2175==
> > ==2174==
> > ==2174==    by 0x809D14A: PetscOptionsInsert (options.c:522)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2175==    by 0x8082563: PetscErrorPrintfInitialize (errtrace.c:77)
> > ==2175==
> > ==2175==    by 0x809CFD4: PetscOptionsInsert (options.c:516)
> > ==2175==    by 0x80AF4BD: PetscInitialize (pinit.c:629)
> > ==2175==
> > ==2174== Invalid read of size 8
> > ==2174==    at 0x4319785: __strlen_sse2 (strlen.S:87)
> > ==2174==    by 0x87BD379: MPIDI_CH3I_Progress_handle_sock_event (ch3_progress.c:776)
> > ==2174==    by 0x87BD7BD: MPIDI_CH3I_Progress (ch3_progress.c:212)
> > ==2174==    by 0x8793060: MPIC_Wait (helper_fns.c:269)
> > ==2174==    by 0x879377E: MPIC_Send (helper_fns.c:38)
> > ==2174==  Address 0x442e0d0 is 8 bytes before a block of size 257 alloc'd
> > ==2174==    by 0x87C74AE: MPID_Init (mpid_init.c:373)
> > ==2174==
> > ==2174==    at 0x43197AD: __strlen_sse2 (strlen.S:104)
> > ==2174==
> > ==2174== Syscall param writev(vector) points to uninitialised byte(s)
> > ==2174==    at 0x436BA61: writev (writev.c:51)
> > ==2174==    by 0x87EB49A: MPIDU_Sock_wait (sock_wait.i:693)
> > ==2174==    by 0x87BD7B0: MPIDI_CH3I_Progress (ch3_progress.c:187)
> > ==2174==  Address 0x4462754 is 68 bytes inside a block of size 72 alloc'd
> > ==2174==    by 0x87CBE6C: MPIDI_CH3I_Connection_alloc (ch3u_connect_sock.c:160)
> > ==2174==    by 0x87CBFAD: MPIDI_CH3I_Sock_connect (ch3u_connect_sock.c:1164)
> > ==2174==    by 0x87CC132: MPIDI_CH3I_VC_post_sockconnect (ch3u_connect_sock.c:1102)
> > ==2174==
> > ==2174== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==2174==  Address 0x4462728 is 24 bytes inside a block of size 72 alloc'd
> > ==2174==
> > ==2174==    at 0x87EC050: MPIDU_Sock_wait (socki_util.i:543)
> > ==2174==
> > ==2175==    by 0x87CA206: MPIDI_PG_Find (mpidi_pg.c:341)
> > ==2175==    by 0x87CB66D: MPIDI_CH3_Sockconn_handle_connopen_event (ch3u_connect_sock.c:883)
> > ==2175==    by 0x87BD3FA: MPIDI_CH3I_Progress_handle_sock_event (ch3_progress.c:639)
> > ==2175==    by 0x87BD7BD: MPIDI_CH3I_Progress (ch3_progress.c:212)
> > ==2175==    by 0x8793060: MPIC_Wait (helper_fns.c:269)
> > ==2175==    by 0x8793626: MPIC_Recv (helper_fns.c:74)
> > ==2175==    by 0x878C049: MPIR_Bcast (bcast.c:195)
> > ==2175==    by 0x878C6A1: PMPI_Bcast (bcast.c:761)
> > ==2175==    by 0x809C467: PetscOptionsInsertFile (options.c:436)
> > ==2175==    by 0x809D14A: PetscOptionsInsert (options.c:522)
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2174==    at 0x43BE324: __strcmp_ssse3 (strcmp-ssse3.S:142)
> > ==2174==    by 0x809F18B: PetscOptionsSetValue (options.c:803)
> > ==2174==    by 0x809DD95: PetscOptionsInsert (options.c:588)
> > ==2174==  Address 0x44c0d88 is 8 bytes inside a block of size 10 alloc'd
> > ==2174==    by 0x809F5F2: PetscOptionsSetValue (options.c:829)
> > ==2174==
> > ==2174==    at 0x43BE32D: __strcmp_ssse3 (strcmp-ssse3.S:144)
> > ==2174==  Address 0x44c0d90 is 6 bytes after a block of size 10 alloc'd
> > ==2174==
> > ==2174==    by 0x80A1074: PetscOptionsHasName (options.c:1092)
> > ==2174==    by 0x80AF535: PetscInitialize (pinit.c:635)
> > ==2174==
> > ==2174==    by 0x80A8875: PetscOptionsCheckInitial_Private (init.c:242)
> > ==2174==    by 0x80AF618: PetscInitialize (pinit.c:639)
> > ==2174==
> > ==2174==    by 0x8099BCC: PetscOptionsAtol (options.c:152)
> > ==2174==    by 0x80A1E9D: PetscOptionsGetTruth (options.c:1310)
> > ==2174==    by 0x80A88F7: PetscOptionsCheckInitial_Private (init.c:244)
> > ==2174==  Address 0x44c0d40 is 8 bytes before a block of size 4 alloc'd
> > ==2174==    by 0x809F6EB: PetscOptionsSetValue (options.c:833)
> > ==2174==
> > ==2174==    by 0x80A8A66: PetscOptionsCheckInitial_Private (init.c:257)
> > ==2174==
> > ==2174==    by 0x80A8BC3: PetscOptionsCheckInitial_Private (init.c:264)
> > ==2174==
> > ==2174==    by 0x80A8C5B: PetscOptionsCheckInitial_Private (init.c:267)
> > ==2174==
> > ==2175== Invalid read of size 8
> > ==2175==    at 0x43BE324: __strcmp_ssse3 (strcmp-ssse3.S:142)
> > ==2175==    by 0x809F18B: PetscOptionsSetValue (options.c:803)
> > ==2175==    by 0x809DD95: PetscOptionsInsert (options.c:588)
> > ==2175==  Address 0x4433c38 is 8 bytes inside a block of size 10 alloc'd
> > ==2175==    by 0x809F5F2: PetscOptionsSetValue (options.c:829)
> > ==2175==
> > ==2175==    at 0x43BE32D: __strcmp_ssse3 (strcmp-ssse3.S:144)
> > ==2175==  Address 0x4433c40 is 6 bytes after a block of size 10 alloc'd
> > ==2175==
> > ==2175==    by 0x80A1074: PetscOptionsHasName (options.c:1092)
> > ==2175==    by 0x80AF535: PetscInitialize (pinit.c:635)
> > ==2175==
> > ==2174==    by 0x80A3E53: PetscOptionsGetString (options.c:1693)
> > ==2174==    by 0x80C395E: PetscSetDisplay (pdisplay.c:99)
> > ==2174==    by 0x80A8D23: PetscOptionsCheckInitial_Private (init.c:276)
> > ==2174==
> > ==2175==    by 0x80A8875: PetscOptionsCheckInitial_Private (init.c:242)
> > ==2175==    by 0x80AF618: PetscInitialize (pinit.c:639)
> > ==2175==
> > ==2175==    at 0x4319785: __strlen_sse2 (strlen.S:87)
> > ==2175==    by 0x8099BCC: PetscOptionsAtol (options.c:152)
> > ==2175==    by 0x80A1E9D: PetscOptionsGetTruth (options.c:1310)
> > ==2175==    by 0x80A88F7: PetscOptionsCheckInitial_Private (init.c:244)
> > ==2175==  Address 0x4433bf0 is 8 bytes before a block of size 4 alloc'd
> > ==2175==    by 0x809F6EB: PetscOptionsSetValue (options.c:833)
> > ==2175==
> > ==2174==    by 0x80A8D9B: PetscOptionsCheckInitial_Private (init.c:281)
> > ==2174==
> > ==2174==    at 0x80A0A4A: PetscOptionsFindPair_Private (options.c:989)
> > ==2174==
> > ==2174==    by 0x80A8E13: PetscOptionsCheckInitial_Private (init.c:282)
> > ==2174==
> > ==2174==    by 0x80A8E8B: PetscOptionsCheckInitial_Private (init.c:283)
> > ==2174==
> > ==2174==    by 0x80A94FC: PetscOptionsCheckInitial_Private (init.c:320)
> > ==2174==
> > ==2175==    by 0x80A8A66: PetscOptionsCheckInitial_Private (init.c:257)
> > ==2175==
> > ==2175==    by 0x80A8BC3: PetscOptionsCheckInitial_Private (init.c:264)
> > ==2175==
> > ==2175==    by 0x80A8C5B: PetscOptionsCheckInitial_Private (init.c:267)
> > ==2175==
> > ==2174==    by 0x80A95F6: PetscOptionsCheckInitial_Private (init.c:323)
> > ==2174==
> > ==2174==    by 0x80A96F8: PetscOptionsCheckInitial_Private (init.c:326)
> > ==2174==
> > ==2174==    by 0x80A97FA: PetscOptionsCheckInitial_Private (init.c:329)
> > ==2174==
> > ==2174==    by 0x80A0906: ==2175== Conditional jump or move depends on uninitialised value(s)
> > ==2175==    by 0x80A3E53: PetscOptionsGetString (options.c:1693)
> > ==2175==    by 0x80C395E: PetscSetDisplay (pdisplay.c:99)
> > ==2175==    by 0x80A8D23: PetscOptionsCheckInitial_Private (init.c:276)
> > ==2175==
> > ==2174==    by 0x80A98FE: PetscOptionsCheckInitial_Private (init.c:334)
> > ==2174==
> > ==2174==    by 0x80A9A5C: PetscOptionsCheckInitial_Private (init.c:341)
> > ==2174==
> > ==2174==    by 0x80A9CA7: PetscOptionsCheckInitial_Private (init.c:350)
> > ==2174==
> > ==2174==    by 0x80A9D9D: PetscOptionsCheckInitial_Private (init.c:352)
> > ==2174==
> > ==2174==    by 0x80A9E24: PetscOptionsCheckInitial_Private (init.c:353)
> > ==2174==
> > ==2174==    by 0x80AA655: PetscOptionsCheckInitial_Private (init.c:402)
> > ==2174==
> > ==2174==    by 0x80AA74F: PetscOptionsCheckInitial_Private (init.c:409)
> > ==2174==
> > ==2174==    by 0x80AA7C7: PetscOptionsCheckInitial_Private (init.c:410)
> > ==2174==
> > ==2174==    by 0x80AAABF: PetscOptionsCheckInitial_Private (init.c:439)
> > ==2174==
> > ==2174==    by 0x80AAC26: PetscOptionsCheckInitial_Private (init.c:452)
> > ==2174==
> > ==2175==    by 0x80A8D9B: PetscOptionsCheckInitial_Private (init.c:281)
> > ==2175==
> > ==2175==    at 0x80A0A4A: PetscOptionsFindPair_Private (options.c:989)
> > ==2175==
> > ==2175==    by 0x80A8E13: PetscOptionsCheckInitial_Private (init.c:282)
> > ==2175==
> > ==2175==    by 0x80A8E8B: PetscOptionsCheckInitial_Private (init.c:283)
> > ==2175==
> > ==2175==    by 0x80A94FC: PetscOptionsCheckInitial_Private (init.c:320)
> > ==2175==
> > ==2175==    by 0x80A95F6: PetscOptionsCheckInitial_Private (init.c:323)
> > ==2175==
> > ==2175==    by 0x80A96F8: PetscOptionsCheckInitial_Private (init.c:326)
> > ==2175==
> > ==2175==    by 0x80A97FA: PetscOptionsCheckInitial_Private (init.c:329)
> > ==2175==
> > ==2175==    by 0x80A98FE: PetscOptionsCheckInitial_Private (init.c:334)
> > ==2175==
> > ==2174==    by 0x80AADBF: PetscOptionsCheckInitial_Private (init.c:468)
> > ==2174==
> > ==2174==    by 0x80AAE3F: PetscOptionsCheckInitial_Private (init.c:469)
> > ==2174==
> > ==2174==
> > ==2174==    by 0x80AAEB7: PetscOptionsCheckInitial_Private (init.c:470)
> > ==2174==
> > ==2174==    by 0x80AB021: PetscOptionsCheckInitial_Private (init.c:474)
> > ==2174==
> > ==2174==    by 0x80AB29D: PetscOptionsCheckInitial_Private (init.c:499)
> > ==2174==
> > ==2174==    by 0x80AB315: PetscOptionsCheckInitial_Private (init.c:504)
> > ==2174==
> > ==2174==
> > ==2174== More than 100 errors detected.  Subsequent errors
> > ==2174== will still be recorded, but in less detail than before.
> > ==2175==    by 0x80A9A5C: PetscOptionsCheckInitial_Private (init.c:341)
> > ==2175==
> > ==2175==    by 0x80A9CA7: PetscOptionsCheckInitial_Private (init.c:350)
> > ==2175==
> > ==2175==    by 0x80A9D9D: PetscOptionsCheckInitial_Private (init.c:352)
> > ==2175==
> > ==2175==    by 0x80A9E24: PetscOptionsCheckInitial_Private (init.c:353)
> > ==2175==
> > ==2175==    by 0x80AA655: PetscOptionsCheckInitial_Private (init.c:402)
> > ==2175==
> > ==2175==    by 0x80AA74F: PetscOptionsCheckInitial_Private (init.c:409)
> > ==2175==
> > ==2175==    by 0x80AA7C7: PetscOptionsCheckInitial_Private (init.c:410)
> > ==2175==
> > ==2175==    by 0x80AAABF: PetscOptionsCheckInitial_Private (init.c:439)
> > ==2175==
> > ==2175==    by 0x80AAC26: PetscOptionsCheckInitial_Private (init.c:452)
> > ==2175==
> > ==2175==    by 0x80AADBF: PetscOptionsCheckInitial_Private (init.c:468)
> > ==2175==
> > ==2175==    by 0x80AAE3F: PetscOptionsCheckInitial_Private (init.c:469)
> > ==2175==
> > ==2175==
> > ==2175==    by 0x80AAEB7: PetscOptionsCheckInitial_Private (init.c:470)
> > ==2175==
> > ==2175==    by 0x80AB021: PetscOptionsCheckInitial_Private (init.c:474)
> > ==2175==
> > ==2175==    by 0x80AB29D: PetscOptionsCheckInitial_Private (init.c:499)
> > ==2175==
> > ==2175==    by 0x80AB315: PetscOptionsCheckInitial_Private (init.c:504)
> > ==2175==
> > ==2175==    by 0x80A27DF: PetscOptionsGetReal (options.c:1419)
> > ==2175==    by 0x80AC610: PetscOptionsCheckInitial_Private (init.c:554)
> > ==2175==
> > ==2175==    by 0x80AC70C: PetscOptionsCheckInitial_Private (init.c:559)
> > ==2175==
> > ==2175==    by 0x80C52B1: PetscLogBegin_Private (plog.c:196)
> > ==2175==    by 0x80AF677: PetscInitialize (pinit.c:643)
> > ==2175==
> > ==2175==    by 0x80C532E: PetscLogBegin_Private (plog.c:200)
> > ==2175==
> > ==2175==    by 0x80A420A: PetscOptionsGetStringArray (options.c:1756)
> > ==2175==    by 0x808387F: PetscInitialize_DynamicLibraries (reg.c:80)
> > ==2175==    by 0x80AF6D6: PetscInitialize (pinit.c:650)
> > ==2175==
> > ==2175==    by 0x81DE8F5: PetscInitializePackage (dlregispetsc.c:58)
> > ==2175==    by 0x8083A20: PetscInitialize_DynamicLibraries (reg.c:93)
> > ==2175==
> > ==2175==    by 0x81DEA77: PetscInitializePackage (dlregispetsc.c:66)
> > ==2175==
> > ==2175==    by 0x8083AA5: PetscInitialize_DynamicLibraries (reg.c:117)
> > ==2175==
> > ==2174==    by 0x80A066B: PetscOptionsFindPair_Private (options.c:967)
> > ==2174==    by 0x80B5ECA: PetscOptionsString (aoptions.c:522)
> > ==2174==    by 0x80A4FDB: PetscOptionsSetFromOptions (options.c:1891)
> > ==2174==    by 0x80AF975: PetscInitialize (pinit.c:659)
> > ==2174==
> > ==2174==    at 0x40249EA: strncat (mc_replace_strmem.c:202)
> > ==2174==    by 0x80BE6E2: PetscStrncat (str.c:205)
> > ==2174==    by 0x80A06F1: PetscOptionsFindPair_Private (options.c:968)
> > ==2174==
> > ==2175==    by 0x80AC9CD: PetscOptionsCheckInitial_Components (pinit.c:57)
> > ==2175==    by 0x80AF916: PetscInitialize (pinit.c:657)
> > ==2175==
> > ==2174==    at 0x4024A18: strncat (mc_replace_strmem.c:202)
> > ==2174==
> > ==2175==    by 0x80B290F: PetscOptionsBegin_Private (aoptions.c:44)
> > ==2175==    by 0x80A4EED: PetscOptionsSetFromOptions (options.c:1890)
> > ==2175==    by 0x80AF975: PetscInitialize (pinit.c:659)
> > ==2175==
> > ==2175==    by 0x80A066B: PetscOptionsFindPair_Private (options.c:967)
> > ==2175==    by 0x80B5ECA: PetscOptionsString (aoptions.c:522)
> > ==2175==    by 0x80A4FDB: PetscOptionsSetFromOptions (options.c:1891)
> > ==2175==
> > ==2175==
> > ==2175== More than 100 errors detected.  Subsequent errors
> > ==2175== will still be recorded, but in less detail than before.
> > ==2175==    at 0x40249EA: strncat (mc_replace_strmem.c:202)
> > ==2175==    by 0x80BE6E2: PetscStrncat (str.c:205)
> > ==2175==    by 0x80A06F1: PetscOptionsFindPair_Private (options.c:968)
> > ==2175==
> > ==2175==    at 0x4024A18: strncat (mc_replace_strmem.c:202)
> > ==2175==
> > ==2174==    by 0x80BDE83: PetscStrallocpy (str.c:79)
> > ==2174==    by 0x808368E: PetscFListGetPathAndFunction (reg.c:24)
> > ==2174==    by 0x80841CC: PetscFListAdd (reg.c:201)
> > ==2174==    by 0x81843D0: DARegister (dareg.c:104)
> > ==2174==    by 0x818476B: DARegisterAll (daregall.c:32)
> > ==2174==    by 0x855F08B: DMInitializePackage (dlregisdm.c:80)
> > ==2174==    by 0x815F1D1: DACreate (dacreate.c:173)
> > ==2174==    by 0x81558E2: DACreate2d (da2.c:1837)
> > ==2174==    by 0x804BE2A: main (ex19.c:107)
> > ==2174==
> > ==2174==
> > ==2174==    at 0x80BDEDB: PetscStrallocpy (str.c:80)
> > ==2175==    by 0x80BDE83: PetscStrallocpy (str.c:79)
> > ==2175==    by 0x808368E: PetscFListGetPathAndFunction (reg.c:24)
> > ==2175==    by 0x80841CC: PetscFListAdd (reg.c:201)
> > ==2175==    by 0x81843D0: DARegister (dareg.c:104)
> > ==2175==    by 0x818476B: DARegisterAll (daregall.c:32)
> > ==2175==    by 0x855F08B: DMInitializePackage (dlregisdm.c:80)
> > ==2175==    by 0x815F1D1: DACreate (dacreate.c:173)
> > ==2175==    by 0x81558E2: DACreate2d (da2.c:1837)
> > ==2175==    by 0x804BE2A: main (ex19.c:107)
> > ==2175==
> > ==2175==    at 0x43197AD: __strlen_sse2 (strlen.S:104)
> > ==2175==
> > ==2175==    at 0x80BDEDB: PetscStrallocpy (str.c:80)
> > ==2175==
> > ==2174==
> > ==2175==    at 0x43197A0: __strlen_sse2 (strlen.S:99)
> > ==2175==    by 0x8099209: PetscOptionsAtoi (options.c:70)
> > ==2175==    by 0x80A13CE: PetscOptionsGetInt (options.c:1138)
> > ==2175==    by 0x80B5AA5: PetscOptionsInt (aoptions.c:473)
> > ==2175==    by 0x815E8BC: DASetFromOptions (dacreate.c:109)
> > ==2175==    by 0x8155C96: DACreate2d (da2.c:1847)
> > ==2175==  Address 0x4433c70 is 0 bytes inside a block of size 3 alloc'd
> > ==2175==
> > ==2174==    at 0x43197A0: __strlen_sse2 (strlen.S:99)
> > ==2174==    by 0x8099209: PetscOptionsAtoi (options.c:70)
> > ==2174==    by 0x80A13CE: PetscOptionsGetInt (options.c:1138)
> > ==2174==    by 0x80B5AA5: PetscOptionsInt (aoptions.c:473)
> > ==2174==    by 0x815E8BC: DASetFromOptions (dacreate.c:109)
> > ==2174==    by 0x8155C96: DACreate2d (da2.c:1847)
> > ==2174==  Address 0x44c0dc0 is 0 bytes inside a block of size 3 alloc'd
> > ==2174==
> > ==2175==    by 0x815E96A: DASetFromOptions (dacreate.c:114)
> > ==2175==  Address 0x4433ce0 is 8 bytes before a block of size 3 alloc'd
> > ==2175==
> > ==2174==    by 0x815E96A: DASetFromOptions (dacreate.c:114)
> > ==2174==  Address 0x44c0e30 is 8 bytes before a block of size 3 alloc'd
> > ==2174==
> > ==2175==    at 0x43197BC: __strlen_sse2 (strlen.S:110)
> > ==2175==    by 0x80846F3: PetscFListAdd (reg.c:238)
> > ==2175==    by 0x829D9AC: MatRegister (matreg.c:139)
> > ==2175==    by 0x86C6837: MatRegisterAll (matregis.c:85)
> > ==2175==    by 0x82A0B71: MatInitializePackage (dlregismat.c:80)
> > ==2175==    by 0x8542386: MatCreate (gcreate.c:72)
> > ==2175==    by 0x8171B37: DAGetInterpolation_2D_Q1 (dainterp.c:308)
> > ==2175==    by 0x8179179: DAGetInterpolation (dainterp.c:879)
> > ==2175==    by 0x8197E93: DMGetInterpolation (dm.c:144)
> > ==2175==    by 0x81BD897: DMMGSetDM (damg.c:250)
> > ==2175==
> > ==2174==    at 0x43197BC: __strlen_sse2 (strlen.S:110)
> > ==2174==    by 0x80846F3: PetscFListAdd (reg.c:238)
> > ==2174==    by 0x829D9AC: MatRegister (matreg.c:139)
> > ==2174==    by 0x86C6837: MatRegisterAll (matregis.c:85)
> > ==2174==    by 0x82A0B71: MatInitializePackage (dlregismat.c:80)
> > ==2174==    by 0x8542386: MatCreate (gcreate.c:72)
> > ==2174==    by 0x8171B37: DAGetInterpolation_2D_Q1 (dainterp.c:308)
> > ==2174==    by 0x8179179: DAGetInterpolation (dainterp.c:879)
> > ==2174==    by 0x8197E93: DMGetInterpolation (dm.c:144)
> > ==2174==    by 0x81BD897: DMMGSetDM (damg.c:250)
> > ==2174==
> > ==2175==    at 0x43BEC7D: __strcmp_ssse3 (strcmp-ssse3.S:1021)
> > ==2175==    by 0x80842B8: PetscFListAdd (reg.c:223)
> > ==2175==    by 0x8096702: PetscObjectComposeFunction_Petsc (inherit.c:227)
> > ==2175==    by 0x8097550: PetscObjectComposeFunction (inherit.c:340)
> > ==2175==    by 0x834D30B: MatCreate_MPIAIJ (mpiaij.c:5096)
> > ==2175==    by 0x829D1E0: MatSetType (matreg.c:65)
> > ==2175==    by 0x86EE543: MatCreate_AIJ (aijtype.c:35)
> > ==2175==    by 0x8171C4C: DAGetInterpolation_2D_Q1 (dainterp.c:310)
> > ==2175==  Address 0x44db848 is 24 bytes inside a block of size 28 alloc'd
> > ==2175==    at 0x4022E01: memalign (vg_replace_malloc.c:532)
> > ==2175==    by 0x808B1A0: PetscMallocAlign (mal.c:30)
> > ==2175==    by 0x80BDF14: PetscStrallocpy (str.c:80)
> > ==2175==    by 0x8084689: PetscFListAdd (reg.c:237)
> > ==2175==    by 0x834D296: MatCreate_MPIAIJ (mpiaij.c:5093)
> > ==2175==
> > ==2174==    at 0x43BEC7D: __strcmp_ssse3 (strcmp-ssse3.S:1021)
> > ==2174==    by 0x80842B8: PetscFListAdd (reg.c:223)
> > ==2174==    by 0x8096702: PetscObjectComposeFunction_Petsc (inherit.c:227)
> > ==2174==    by 0x8097550: PetscObjectComposeFunction (inherit.c:340)
> > ==2174==    by 0x834D30B: MatCreate_MPIAIJ (mpiaij.c:5096)
> > ==2174==    by 0x829D1E0: MatSetType (matreg.c:65)
> > ==2174==    by 0x86EE543: MatCreate_AIJ (aijtype.c:35)
> > ==2174==    by 0x8171C4C: DAGetInterpolation_2D_Q1 (dainterp.c:310)
> > ==2174==  Address 0x456b7c8 is 24 bytes inside a block of size 28 alloc'd
> > ==2174==    at 0x4022E01: memalign (vg_replace_malloc.c:532)
> > ==2174==    by 0x808B1A0: PetscMallocAlign (mal.c:30)
> > ==2174==    by 0x80BDF14: PetscStrallocpy (str.c:80)
> > ==2174==    by 0x8084689: PetscFListAdd (reg.c:237)
> > ==2174==    by 0x834D296: MatCreate_MPIAIJ (mpiaij.c:5093)
> > ==2174==
> > ==2175==    at 0x43BE415: __strcmp_ssse3 (strcmp-ssse3.S:225)
> > ==2175==    by 0x8085399: PetscFListFind (reg.c:375)
> > ==2175==    by 0x80968C7: PetscObjectQueryFunction_Petsc (inherit.c:238)
> > ==2175==    by 0x80978B5: PetscObjectQueryFunction (inherit.c:376)
> > ==2175==    by 0x833E82B: MatMPIAIJSetPreallocation (mpiaij.c:3486)
> > ==2175==    by 0x8171D37: DAGetInterpolation_2D_Q1 (dainterp.c:312)
> > ==2175==    by 0x804BEA0: main (ex19.c:108)
> > ==2175==
> > ==2175==    at 0x43BE421: __strcmp_ssse3 (strcmp-ssse3.S:228)
> > ==2175==  Address 0x44dc7d8 is 24 bytes inside a block of size 28 alloc'd
> > ==2175==    by 0x8085186: PetscFListFind (reg.c:356)
> > ==2175==
> > ==2175==    by 0x8085406: PetscFListFind (reg.c:376)
> > ==2175==
> > ==2174==    at 0x43BE415: __strcmp_ssse3 (strcmp-ssse3.S:225)
> > ==2174==    by 0x8085399: PetscFListFind (reg.c:375)
> > ==2174==    by 0x80968C7: PetscObjectQueryFunction_Petsc (inherit.c:238)
> > ==2174==    by 0x80978B5: PetscObjectQueryFunction (inherit.c:376)
> > ==2174==    by 0x833E82B: MatMPIAIJSetPreallocation (mpiaij.c:3486)
> > ==2174==    by 0x8171D37: DAGetInterpolation_2D_Q1 (dainterp.c:312)
> > ==2174==    by 0x804BEA0: main (ex19.c:108)
> > ==2174==
> > ==2174==    at 0x43BE421: __strcmp_ssse3 (strcmp-ssse3.S:228)
> > ==2174==  Address 0x456c758 is 24 bytes inside a block of size 28 alloc'd
> > ==2174==    by 0x8085186: PetscFListFind (reg.c:356)
> > ==2174==
> > ==2174==    by 0x8085406: PetscFListFind (reg.c:376)
> > ==2174==
> > ==2174==    by 0x82BE3A6: MatCreate_SeqAIJ (aij.c:3363)
> > ==2174==    by 0x83393A9: MatMPIAIJSetPreallocation_MPIAIJ (mpiaij.c:2789)
> > ==2174==    by 0x833E8AA: MatMPIAIJSetPreallocation (mpiaij.c:3488)
> > ==2174==  Address 0x456d3a0 is 16 bytes inside a block of size 21 alloc'd
> > ==2174==    by 0x8084162: PetscFListAdd (reg.c:200)
> > ==2174==    by 0x82BE331: MatCreate_SeqAIJ (aij.c:3360)
> > ==2174==
> > ==2175==    by 0x82BE3A6: MatCreate_SeqAIJ (aij.c:3363)
> > ==2175==    by 0x83393A9: MatMPIAIJSetPreallocation_MPIAIJ (mpiaij.c:2789)
> > ==2175==    by 0x833E8AA: MatMPIAIJSetPreallocation (mpiaij.c:3488)
> > ==2175==  Address 0x44dd420 is 16 bytes inside a block of size 21 alloc'd
> > ==2175==    by 0x8084162: PetscFListAdd (reg.c:200)
> > ==2175==    by 0x82BE331: MatCreate_SeqAIJ (aij.c:3360)
> > ==2175==
> > ==2174==    by 0x80A6193: PetscObjectSetOptionsPrefix (prefix.c:37)
> > ==2174==    by 0x80A6564: PetscObjectAppendOptionsPrefix (prefix.c:70)
> > ==2174==    by 0x87169FB: PCAppendOptionsPrefix (precon.c:1242)
> > ==2174==    by 0x861C3B2: KSPAppendOptionsPrefix (itcl.c:121)
> > ==2174==    by 0x85A5056: PCMGSetLevels (mg.c:195)
> > ==2174==    by 0x81BE9AD: DMMGSetUpLevel (damg.c:379)
> > ==2174==    by 0x81C5787: DMMGSetSNES (damgsnes.c:648)
> > ==2174==    by 0x81C71AE: DMMGSetSNESLocal_Private (damgsnes.c:952)
> > ==2174==    by 0x804C4FF: main (ex19.c:140)
> > ==2174==
> > ==2175==    by 0x80A6193: PetscObjectSetOptionsPrefix (prefix.c:37)
> > ==2175==    by 0x80A6564: PetscObjectAppendOptionsPrefix (prefix.c:70)
> > ==2175==    by 0x87169FB: PCAppendOptionsPrefix (precon.c:1242)
> > ==2175==    by 0x861C3B2: KSPAppendOptionsPrefix (itcl.c:121)
> > ==2175==    by 0x85A5056: PCMGSetLevels (mg.c:195)
> > ==2175==    by 0x81BE9AD: DMMGSetUpLevel (damg.c:379)
> > ==2175==    by 0x81C5787: DMMGSetSNES (damgsnes.c:648)
> > ==2175==    by 0x81C71AE: DMMGSetSNESLocal_Private (damgsnes.c:952)
> > ==2175==    by 0x804C4FF: main (ex19.c:140)
> > ==2175==
> > ==2174==    by 0x8668D6B: KSPDestroy_GMRES (gmres.c:302)
> > ==2174==    by 0x8675E35: KSPDestroy_FGMRES (fgmres.c:341)
> > ==2174==    by 0x8635CA0: KSPSetType (itcreate.c:569)
> > ==2174==    by 0x81C5A98: DMMGSetSNES (damgsnes.c:668)
> > ==2174==  Address 0x462f078 is 24 bytes inside a block of size 31 alloc'd
> > ==2174==    by 0x86784F2: KSPCreate_FGMRES (fgmres.c:753)
> > ==2174==    by 0x8635D92: KSPSetType (itcreate.c:576)
> > ==2174==    by 0x81BE7AA: DMMGSetUpLevel (damg.c:372)
> > ==2174==
> > ==2174==    at 0x43BE320: __strcmp_ssse3 (strcmp-ssse3.S:141)
> > ==2174==    by 0x858986E: PCSetType (pcset.c:66)
> > ==2174==    by 0x81C5BCA: DMMGSetSNES (damgsnes.c:672)
> > ==2174==  Address 0x45a0778 is 8 bytes inside a block of size 10 alloc'd
> > ==2175==    by 0x8668D6B: KSPDestroy_GMRES (gmres.c:302)
> > ==2175==    by 0x8675E35: KSPDestroy_FGMRES (fgmres.c:341)
> > ==2175==    by 0x8635CA0: KSPSetType (itcreate.c:569)
> > ==2175==    by 0x81C5A98: DMMGSetSNES (damgsnes.c:668)
> > ==2175==  Address 0x459cf78 is 24 bytes inside a block of size 31 alloc'd
> > ==2175==    by 0x86784F2: KSPCreate_FGMRES (fgmres.c:753)
> > ==2175==    by 0x8635D92: KSPSetType (itcreate.c:576)
> > ==2175==    by 0x81BE7AA: DMMGSetUpLevel (damg.c:372)
> > ==2175==
> > ==2174==    by 0x8718EF5: PCRegister (precon.c:1537)
> > ==2174==    by 0x858B07B: PCRegisterAll (pcregis.c:95)
> > ==2174==    by 0x8642C37: PCInitializePackage (dlregisksp.c:60)
> > ==2174==    by 0x870E72D: PCCreate (precon.c:299)
> > ==2174==    by 0x862ADD8: KSPGetPC (itfunc.c:1251)
> > ==2174==    by 0x861BF6A: KSPSetOptionsPrefix (itcl.c:87)
> > ==2174==    by 0x81AD4A9: SNESSetOptionsPrefix (snes.c:2529)
> > ==2174==    by 0x81C52C6: DMMGSetSNES (damgsnes.c:612)
> > ==2174==
> > ==2174==  Address 0x4630188 is 8 bytes inside a block of size 10 alloc'd
> > ==2174==
> > ==2174==    at 0x43BE328: __strcmp_ssse3 (strcmp-ssse3.S:143)
> > ==2174==  Address 0x45a0780 is 6 bytes after a block of size 10 alloc'd
> > ==2174==
> > ==2174==  Address 0x4630190 is 6 bytes after a block of size 10 alloc'd
> > ==2174==2175== Invalid read of size 8
> > ==2175==    at 0x43BE320: __strcmp_ssse3 (strcmp-ssse3.S:141)
> > ==2175==    by 0x858986E: PCSetType (pcset.c:66)
> > ==2175==    by 0x81C5BCA: DMMGSetSNES (damgsnes.c:672)
> > ==2175==  Address 0x450e678 is 8 bytes inside a block of size 10 alloc'd
> > ==2175==    by 0x8718EF5: PCRegister (precon.c:1537)
> > ==2175==    by 0x858B07B: PCRegisterAll (pcregis.c:95)
> > ==2175==    by 0x8642C37: PCInitializePackage (dlregisksp.c:60)
> > ==2175==    by 0x870E72D: PCCreate (precon.c:299)
> > ==2175==    by 0x862ADD8: KSPGetPC (itfunc.c:1251)
> > ==2175==    by 0x861BF6A: KSPSetOptionsPrefix (itcl.c:87)
> > ==2175==    by 0x81AD4A9: SNESSetOpti==    by 0x808B1A0: PetscMallocAlign (mal.c:30)
> > ==2174==
> > ==2175==    by 0x81C52C6: DMMGSetSNES (damgsnes.c:612)
> > ==2175==
> > ==2175==  Address 0x459e088 is 8 bytes inside a block of size 10 alloc'd
> > ==2175==
> > ==2175==    at 0x43BE328: __strcmp_ssse3 (strcmp-ssse3.S:143)
> > ==2175==  Address 0x450e680 is 6 bytes after a block of size 10 alloc'd
> > ==2175==    by 0x81AD4A9: SNESSetOptionsPrefix (snes.c:2529)
> > ==2175==
> > ==2175==  Address 0x459e090 is 6 bytes after a block of size 10 alloc'd
> > ==2175==
> > ==2175==    at 0x43B674F: __memcpy_ssse3 (memcpy-ssse3.S:703)
> > ==2175==    by 0x87923CB: MPIR_Allgatherv (allgatherv.c:340)
> > ==2175==    by 0x879274D: PMPI_Allgatherv (allgatherv.c:997)
> > ==2175==    by 0x83631F0: MatFDColoringCreate_MPIAIJ (fdmpiaij.c:89)
> > ==2175==    by 0x854A377: MatFDColoringCreate (fdmatrix.c:385)
> > ==2175==    by 0x81C5E65: DMMGSetSNES (damgsnes.c:712)
> > ==2175==  Address 0x47cd128 is 0 bytes after a block of size 720 alloc'd
> > ==2175==    by 0x8791B68: MPIR_Allgatherv (allgatherv.c:143)
> > ==2175==
> > ==2174==    at 0x43B677F: __memcpy_ssse3 (memcpy-ssse3.S:715)
> > ==2174==    by 0x8791BD2: MPIR_Allgatherv (allgatherv.c:160)
> > ==2174==    by 0x879274D: PMPI_Allgatherv (allgatherv.c:997)
> > ==2174==    by 0x83631F0: MatFDColoringCreate_MPIAIJ (fdmpiaij.c:89)
> > ==2174==    by 0x854A377: MatFDColoringCreate (fdmatrix.c:385)
> > ==2174==    by 0x81C5E65: DMMGSetSNES (damgsnes.c:712)
> > ==2174==  Address 0x4920208 is 0 bytes after a block of size 1,416 alloc'd
> > ==2174==    by 0x8132724: ISCreateGeneral (general.c:342)
> > ==2174==    by 0x813BE92: ISColoringGetIS (iscoloring.c:161)
> > ==2174==    by 0x836235A: MatFDColoringCreate_MPIAIJ (fdmpiaij.c:30)
> > ==2174==
> > ==2174==    by 0x80B2778: PetscOptionsBegin_Private (aoptions.c:38)
> > ==2174==    by 0x858A3C6: PCSetFromOptions (pcset.c:170)
> > ==2174==    by 0x861D3B6: KSPSetFromOptions (itcl.c:323)
> > ==2174==    by 0x85A8052: PCSetUp_MG (mg.c:490)
> > ==2174==    by 0x8714039: PCSetUp (precon.c:795)
> > ==2174==    by 0x8621C54: KSPSetUp (itfunc.c:237)
> > ==2174==    by 0x8622C90: KSPSolve (itfunc.c:353)
> > ==2174==    by 0x81B0295: SNES_KSPSolve (snes.c:2944)
> > ==2174==    by 0x86A2C12: SNESSolve_LS (ls.c:191)
> > ==2174==    by 0x81AB5EC: SNESSolve (snes.c:2255)
> > ==2174==  Address 0x4858f38 is 8 bytes inside a block of size 11 alloc'd
> > ==2174==    by 0x85A4D63: PCMGSetLevels (mg.c:180)
> > ==2174==
> > ==2175==    by 0x80B2778: PetscOptionsBegin_Private (aoptions.c:38)
> > ==2175==    by 0x858A3C6: PCSetFromOptions (pcset.c:170)
> > ==2175==    by 0x861D3B6: KSPSetFromOptions (itcl.c:323)
> > ==2175==    by 0x85A8052: PCSetUp_MG (mg.c:490)
> > ==2175==    by 0x8714039: PCSetUp (precon.c:795)
> > ==2175==    by 0x8621C54: KSPSetUp (itfunc.c:237)
> > ==2175==    by 0x8622C90: KSPSolve (itfunc.c:353)
> > ==2175==    by 0x81B0295: SNES_KSPSolve (snes.c:2944)
> > ==2175==    by 0x86A2C12: SNESSolve_LS (ls.c:191)
> > ==2175==    by 0x81AB5EC: SNESSolve (snes.c:2255)
> > ==2175==  Address 0x4797eb8 is 8 bytes inside a block of size 11 alloc'd
> > ==2175==    by 0x85A4D63: PCMGSetLevels (mg.c:180)
> > ==2175==    by 0x81C71AE: DMMGSetSNESLocal_Private (dam==2174== Invalid read of size 8
> > ==2174==    by 0x870C60A: PCGetDefaultType_Private (precon.c:25)
> > ==2174==    by 0x858A499: PCSetFromOptions (pcset.c:172)
> > ==2174==  Address 0x4cfa520 is 16 bytes inside a block of size 22 alloc'd
> > ==2174==    by 0x808368E: PetscFListGetPathAndFunction (reg.c:24)gsnes.c:952)
> > ==2175==
> > ==2174==
> > ==2175==    by 0x870C60A: PCGetDefaultType_Private (precon.c:25)
> > ==2175==    by 0x858A499: PCSetFromOptions (pcset.c:172)
> > ==2175==  Address 0x4c39110 is 16 bytes inside a block of size 22 alloc'd
> > ==2175==
> > ==2175==    by 0x80A671F: PetscObjectAppendOptionsPrefix (prefix.c:76)
> > ==2174==    by 0x80A671F: PetscObjectAppendOptionsPrefix (prefix.c:76)
> > ==2174==    by 0x859F3D9: PCSetUp_BJacobi_Singleblock (bjacobi.c:905)
> > ==2174==    by 0x85992B8: PCSetUp_BJacobi (bjacobi.c:180)
> > ==2174==    by 0x85A8E40: PCSetUp_MG (mg.c:556)
> > ==2174==  Address 0x4d567c8 is 8 bytes inside a block of size 13 alloc'd
> > ==2174==    by 0x87166FA: PCSetOptionsPrefix (precon.c:1209)
> > ==2174==    by 0x861BFD3: KSPSetOptionsPrefix (itcl.c:88)
> > ==2174==    by 0x859F375: PCSetUp_BJacobi_Singleblock (bjacobi.c:904)
> > ==2174==
> > ==2175==    by 0x859F3D9: PCSetUp_BJacobi_Singleblock (bjacobi.c:905)
> > ==2175==    by 0x85992B8: PCSetUp_BJacobi (bjacobi.c:180)
> > ==2175==    by 0x85A8E40: PCSetUp_MG (mg.c:556)
> > ==2175==  Address 0x4c42198 is 8 bytes inside a block of size 13 alloc'd
> > ==2175==    by 0x87166FA: PCSetOptionsPrefix (precon.c:1209)
> > ==2175==    by 0x861BFD3: KSPSetOptionsPrefix (itcl.c:88)
> > ==2175==    by 0x859F375: PCSetUp_BJacobi_Singleblock (bjacobi.c:904)
> > ==2175==
> > ==2174==    at 0x43197AF: __strlen_sse2 (strlen.S:106)
> > ==2174==    by 0x859F978: PCSetUp_BJacobi_Singleblock (bjacobi.c:944)
> > ==2174==  Address 0x4d568d0 is 16 bytes inside a block of size 17 alloc'd
> > ==2174==    by 0x80A67BF: PetscObjectAppendOptionsPrefix (prefix.c:77)
> > ==2174==
> > ==2175==    at 0x43197AF: __strlen_sse2 (strlen.S:106)
> > ==2175==    by 0x859F978: PCSetUp_BJacobi_Singleblock (bjacobi.c:944)
> > ==2175==  Address 0x4c422a0 is 16 bytes inside a block of size 17 alloc'd
> > ==2175==    by 0x80A67BF: PetscObjectAppendOptionsPrefix (prefix.c:77)
> > ==2175==
> > ==2175==    at 0x43BF3A5: __strcmp_ssse3 (strcmp-ssse3.S:1687)
> > ==2175==    by 0x85E8F9A: PCCreate_ILU (ilu.c:379)
> > ==2175==    by 0x8589A8B: PCSetType (pcset.c:78)
> > ==2175==    by 0x858A64C: PCSetFromOptions (pcset.c:181)
> > ==2175==  Address 0x4c94a28 is 24 bytes inside a block of size 27 alloc'd
> > ==2175==    by 0x85E8F25: PCCreate_ILU (ilu.c:377)
> > ==2175==
> > ==2174==    at 0x43BF3A5: __strcmp_ssse3 (strcmp-ssse3.S:1687)
> > ==2174==    by 0x85E8F9A: PCCreate_ILU (ilu.c:379)
> > ==2174==    by 0x8589A8B: PCSetType (pcset.c:78)
> > ==2174==    by 0x858A64C: PCSetFromOptions (pcset.c:181)
> > ==2174==  Address 0x4d58a28 is 24 bytes inside a block of size 27 alloc'd
> > ==2174==    by 0x85E8F25: PCCreate_ILU (ilu.c:377)
> > ==2174==
> > ==2175==    by 0x8093FC2: PetscTypeCompare (destroy.c:254)
> > ==2175==    by 0x85A956A: PCSetUp_MG (mg.c:585)
> > ==2175==    by 0x81C4919: DMMGSolveSNES (damgsnes.c:510)
> > ==2175==    by 0x81BDF6C: DMMGSolve (damg.c:313)
> > ==2175==    by 0x804C9A7: main (ex19.c:155)
> > ==2175==  Address 0x4798858 is 8 bytes inside a block of size 10 alloc'd
> > ==2175==    by 0x80902DB: PetscObjectChangeTypeName (pname.c:114)
> > ==2175==    by 0x8589AEE: PCSetType (pcset.c:79)
> > ==2175==    by 0x85A4F3C: PCMGSetLevels (mg.c:187)
> > ==2175==
> > ==2175==  Address 0x4798860 is 6 bytes after a block of size 10 alloc'd
> > ==2175==
> > ==2174==    by 0x8093FC2: PetscTypeCompare (destroy.c:254)
> > ==2174==    by 0x85A956A: PCSetUp_MG (mg.c:585)
> > ==2174==    by 0x81C4919: DMMGSolveSNES (damgsnes.c:510)
> > ==2174==    by 0x81BDF6C: DMMGSolve (damg.c:313)
> > ==2174==    by 0x804C9A7: main (ex19.c:155)
> > ==2174==  Address 0x48598d8 is 8 bytes inside a block of size 10 alloc'd
> > ==2174==    by 0x80902DB: PetscObjectChangeTypeName (pname.c:114)
> > ==2174==    by 0x8589AEE: PCSetType (pcset.c:79)
> > ==2174==    by 0x85A4F3C: PCMGSetLevels (mg.c:187)
> > ==2174==
> > ==2174==  Address 0x48598e0 is 6 bytes after a block of size 10 alloc'd
> > ==2174==
> > ==2175==    by 0x8086A53: PetscFListDuplicate (reg.c:596)
> > ==2175==    by 0x82BFA68: MatDuplicateNoCreate_SeqAIJ (aij.c:3511)
> > ==2175==    by 0x82D1840: MatILUFactorSymbolic_SeqAIJ_ilu0 (aijfact.c:1630)
> > ==2175==    by 0x82D2300: MatILUFactorSymbolic_SeqAIJ (aijfact.c:1731)
> > ==2175==    by 0x82866FB: MatILUFactorSymbolic (matrix.c:5464)
> > ==2175==    by 0x85E7785: PCSetUp_ILU (ilu.c:204)
> > ==2175==    by 0x859D9CE: PCSetUpOnBlocks_BJacobi_Singleblock (bjacobi.c:753)
> > ==2175==    by 0x8714602: PCSetUpOnBlocks (precon.c:828)
> > ==2175==
> > ==2175==
> > ==2175==    at 0x43BF669: __strcmp_ssse3 (strcmp-ssse3.S:2007)
> > ==2175==
> > ==2175==    at 0x43BF66E: __strcmp_ssse3 (strcmp-ssse3.S:2010)
> > ==2175==
> > ==2175==    at 0x43BF673: __strcmp_ssse3 (strcmp-ssse3.S:2013)
> > ==2175==
> > ==2175==    at 0x43BF678: __strcmp_ssse3 (strcmp-ssse3.S:2016)
> > ==2175==
> > ==2175==    at 0x43BF67D: __strcmp_ssse3 (strcmp-ssse3.S:2019)
> > ==2175==    by 0x82D1840: MatILUFactorSymbolic_SeqAIJ_ilu0 (aijfact.c:1==2174== Conditional jump or move depends on uninitialised value(s)
> > ==2174==    by 0x8086A53: PetscFListDuplicate (reg.c:596)
> > ==2174==    by 0x82BFA68: MatDuplicateNoCreate_SeqAIJ (aij.c:3511)
> > ==2174==    by 0x82D1840: MatILUFactorSymbolic_SeqAIJ_ilu0 (aijfact.c:1630)
> > ==2174==    by 0x82D2300: MatILUFactorSymbolic_SeqAIJ (aijfact.c:1731)
> > ==2174==    by 0x82866FB: MatILUFactorSymbolic (matrix.c:5464)
> > ==2174==    by 0x85E7785: PCSetUp_ILU (ilu.c:204)
> > ==2174==    by 0x859D9CE: PCSetUpOnBlocks_BJacobi_Singleblock (bjacobi.c:753)
> > ==2174==    by 0x8714602: PCSetUpOnBlocks (precon.c:828)
> > ==2174==
> > ==2174==    by 0x8086A53: Pets630)
> > ==2175==
> > ==2175==    at 0x43BF10D: __strcmp_ssse3 (strcmp-ssse3.S:1446)
> > ==2175==  cFListDuplicate (reg.c:596)
> > ==2174==
> > ==2174==    at 0x43BF669: __strcmp_ssse3 (strcmp-ssse3.S:2007)
> > ==2174==    by 0x82D2300: MatILUFactorSym  by 0x8621C54: KSPSetUp (itfunc.c:237)
> > ==2175==  Address 0x501a448 is 24 bytes inside a block of size 30 alloc'd
> > ==2175==    by 0x82C3982: MatGetFactor_seqaij_petsc (aijfact.c:118)
> > ==2175==    by 0x8276893: MatGetFactor (matrix.c:3649)
> > ==2175==    by 0x85E7687: PCSetUp_ILU (ilu.c:202)
> > ==2175==
> > ==21bolic_SeqAIJ (aijfact.c:1731)
> > ==2174==
> > ==2174==    at 0x43BF66E: __strcmp_ssse3 (strcmp-ssse3.S:2010)
> > ==2174==    by 0x86275==    at 0x43BF12F: __strcmp_ssse3 (strcmp-ssse3.S:1456)
> > ==2175==
> > ==2175==    by 0x82BFA68: MatDuplicateNoCre1C54: KSPSetUp (itfunc.c:237)
> > ==2174==
> > ==2174==    at 0x43BF673: __strcmp_ssse3 (strcmp-ssse3.S:2013)
> > ==2174==
> > ==2174== Conditional jump or move depate_SeqAIJ (aij.c:3511)
> > ==2175==
> > ==2175==    by 0x82866FB: MatILUFactorSymends on uninitialised value(s)
> > ==2174==    at 0x43BF678: __strcmp_ssse3 (strcmp-ssse3.S:2016)
> > ==2174==
> > ==2174==    at 0x43BF67D: __strcmp_ssse3 (strcmp-ssse3.S:2019)
> > ==2174==bolic (matrix.c:5464)
> > ==2175==
> > ==2175==    by 0x859D9CE: PCSetUpOnBlocks    by 0x82BFA68: MatDuplicateNoCreate_SeqAIJ (aij.c:3511)
> > ==2174==
> > ==2174==    at 0x43BF10D: __strcmp_ssse3 (strcmp-ssse3.S:1446)
> > ==2174==    by 0x82866FB: MatILUFactorSymb_BJacobi_Singleblock (bjacobi.c:753)
> > ==2175==
> > ==2175==
> > ==2175==    at 0x43BF5D4: __strcmp_ssse3olic (matrix.c:5464)
> > ==2174==  Address 0x5799948 is 24 bytes inside a block of size 30 alloc'd
> > ==2174==    by 0x82C3982: MatGetFactor_seqaij_petsc (aijfact.c:118)
> > ==2174==    by 0x8276893: MatGetFactor (matrix.c:3649)
> > ==2174==    by 0x85E7687: PCSetUp_ILU (ilu.c:202)
> > = (strcmp-ssse3.S:1902)
> > ==2175==
> > ==2175==    at 0x43BF5D9: __strcmp_ssse3 (strcmp-ssse3.S:1905)
> > ==2175==    =2174==    by 0x8714039: PCSetUp (precon.c:795)
> > ==2174==
> > ==2174==    at 0x43BF12F: __strcmp_ssse3 (strcmp-ssse3.S:1456)
> > ==2174==
> > ==2174==    by 0x80842Bby 0x82D1840: MatILUFactorSymbolic_SeqAIJ_ilu0 (aijfact.c:1630)
> > ==2175==
> > ==2175==    at 0x43197BE: __strlen_sse2 (strlen.S:112)
> > ==2175==    by 0x808432D: PetscFListAdd (reg.c:225)
> > ==8: PetscFListAdd (reg.c:223)
> > ==2174==
> > ==2174==    by 0x82D1840: MatILUFactorSymbolic_SeqAIJ_ilu02175==    by 0x82866FB: MatILUFactorSymbolic (matrix.c:5464)
> > ==2175==  Address 0x45afcd0 is 32 bytes inside a block of size 35 alloc'd
> > ==2175==    by 0x818A96F: DAGetMatrix2d_MPIAIJ (fdda.c:779)
> > (aijfact.c:1630)
> > ==2174==
> > ==2174==  ==2175==
> > ==2175==    at 0x43BF5DE: __strcmp_ssse3 (strcmp-ssse3.S:1908)
> > ==2175==
> > ==2175==    at 0x43BF165: __strcmp_ssse3 (strcmp-ssse3.S:1474)
> > ==2175==    by 0x8086A53: PetscFListDuplicate (reg.c:59  by 0x8714039: PCSetUp (precon.c:795)
> > ==2174==
> > ==2174==    by 0x8714602: PCSetUpOnBlocks (pr6)
> > ==2175==  Address 0x541be90 is 32 bytes inside a block of size 37 alloc'd
> > ==2175==    by 0x82BEAecon.c:828)
> > ==2174==
> > ==2174==    at 0x43BF5D4: __strcmp_ssse3 (strcmp-ssse3.S:1902)
> > ==2174==
> > ==2174==    at 0x43BF5D9: __strcmp_ssse3 (strcmp-ssse3.S:1905)
> > ==2174=33: MatCreate_SeqAIJ (aij.c:3408)
> > ==2175==
> > ==2175==    at 0x43BF18F: __strcmp_ssse3 (strcmp-ssse3.S:1485)
> > ==2175==    by 0x859D9CE: PCSetUpOnBlock=    by 0x8086A53: PetscFListDuplicate (reg.c:596)
> > ==2174==
> > ==2174==    at 0x43197BE: __strlen_sse2 (strlen.S:112)
> > ==2174==    by 0x808432D: PetscFListAdd (reg.c:225)
> > ==2174==    by 0x82s_BJacobi_Singleblock (bjacobi.c:753)
> > ==2175==
> > ==2174==  Address 0x4642530 is 32 bytes inside a block of size 35 alloc'd
> > ==2174==    by 0x818A96F: DAGetMatrix2d_MPIAIJ (fdda.c:779)
> > ==2174==
> > ==2174==    at 0x43BF5DE: __strcmp_ssse3 (strcmp-ssse3.S:1908)
> > ==2174==
> > ==2174==    at 0x43BF165: __strcmp_ssse3 (strcmp-ssse3.S:1474)
> > ==2174==  Address 0x54138b0 is 32 bytes inside a block of size 37 alloc'd
> > ==2174==    by 0x82BEA33: MatCreate_SeqAIJ (aij.c:3408)
> > ==2174==
> > ==2174==    at 0x43BF18F: __strcmp_ssse3 (strcmp-ssse3.S:1485)
> > ==2174==
> > ==2175==    at 0x43BEFE9: __strcmp_ssse3 (strcmp-ssse3.S:1339)
> > ==2175==    by 0x86A4028: SNESDestroy_LS (ls.c:322)
> > ==2175==    by 0x81A578E: SNESDestroy (snes.c:1406)
> > ==2175==    by 0x8093606: PetscObjectDestroy (destroy.c:172)
> > ==2175==    by 0x81BCE39: DMMGDestroy (damg.c:179)
> > ==2175==    by 0x804CBD4: main (ex19.c:174)
> > ==2175==  Address 0x4b28898 is 24 bytes inside a block of size 28 alloc'd
> > ==2175==    by 0x86AA093: SNESCreate_LS (ls.c:1199)
> > ==2175==    by 0x81AC1EF: SNESSetType (snes.c:2353)
> > ==2175==    by 0x819BDE2: SNESSetFromOptions (snes.c:306)
> > ==2175==    by 0x81C69A8: DMMGSetFromOptions (damgsnes.c:818)
> > ==2175==    by 0x804C56B: main (ex19.c:141)
> > ==2175==
> > ==2175==    at 0x43BF015: __strcmp_ssse3 (strcmp-ssse3.S:1354)
> > ==2175==
> > ==2175==    at 0x43BF04A: __strcmp_ssse3 (strcmp-ssse3.S:1369)
> > ==2175==  Address 0x4b288a0 is 4 bytes after a block of size 28 alloc'd
> > ==2175==
> > ==2174==    at 0x43BEFE9: __strcmp_ssse3 (strcmp-ssse3.S:1339)
> > ==2174==    by 0x86A4028: SNESDestroy_LS (ls.c:322)
> > ==2174==    by 0x81A578E: SNESDestroy (snes.c:1406)
> > ==2174==    by 0x8093606: PetscObjectDestroy (destroy.c:172)
> > ==2174==    by 0x81BCE39: DMMGDestroy (damg.c:179)
> > ==2174==    by 0x804CBD4: main (ex19.c:174)
> > ==2174==  Address 0x4be1e28 is 24 bytes inside a block of size 28 alloc'd
> > ==2174==    by 0x86AA093: SNESCreate_LS (ls.c:1199)
> > ==2174==    by 0x81AC1EF: SNESSetType (snes.c:2353)
> > ==2174==    by 0x819BDE2: SNESSetFromOptions (snes.c:306)
> > ==2174==    by 0x81C69A8: DMMGSetFromOptions (damgsnes.c:818)
> > ==2174==    by 0x804C56B: main (ex19.c:141)
> > ==2174==
> > ==2174==    at 0x43BF015: __strcmp_ssse3 (strcmp-ssse3.S:1354)
> > ==2174==
> > ==2174==    at 0x43BF04A: __strcmp_ssse3 (strcmp-ssse3.S:1369)
> > ==2174==  Address 0x4be1e30 is 4 bytes after a block of size 28 alloc'd
> > ==2174==
> > ==2175==    at 0x43BF469: __strcmp_ssse3 (strcmp-ssse3.S:1765)
> > ==2175==    by 0x830D1DF: MatDestroy_SeqAIJ_Inode (inode2.c:62)
> > ==2175==    by 0x82AB1E1: MatDestroy_SeqAIJ (aij.c:810)
> > ==2175==    by 0x82595D1: MatDestroy (matrix.c:876)
> > ==2175==    by 0x8327843: MatDestroy_MPIAIJ (mpiaij.c:900)
> > ==2175==    by 0x8470F9F: MatDestroy_MPIMAIJ (maij.c:152)
> > ==2175==    by 0x85A560D: PCDestroy_MG_Private (mg.c:232)
> > ==2175==  Address 0x44df298 is 24 bytes inside a block of size 26 alloc'd
> > ==2175==    by 0x830D905: MatCreate_SeqAIJ_Inode (inode2.c:101)
> > ==2175==    by 0x82BEB04: MatCreate_SeqAIJ (aij.c:3414)
> > ==2175==
> > ==2175==    at 0x43BF46D: __strcmp_ssse3 (strcmp-ssse3.S:1766)
> > ==2175==    by 0x82AB357: MatDestroy_SeqAIJ (aij.c:815)
> > ==2175==    by 0x85A5A49: PCDestroy_MG (mg.c:257)
> > ==2175==  Address 0x44dd918 is 24 bytes inside a block of size 28 alloc'd
> > ==2175==    by 0x82BE442: MatCreate_SeqAIJ (aij.c:3369)
> > ==2175==
> > ==2175==    at 0x43BF22D: __strcmp_ssse3 (strcmp-ssse3.S:1553)
> > ==2175==    by 0x82AB527: MatDestroy_SeqAIJ (aij.c:819)
> > ==2175==  Address 0x44ddfa8 is 24 bytes inside a block of size 28 alloc'd
> > ==2175==    by 0x82BE616: MatCreate_SeqAIJ (aij.c:3381)
> > ==2175==
> > ==2175==    at 0x43BEFED: __strcmp_ssse3 (strcmp-ssse3.S:1340)
> > ==2175==    by 0x8327F64: MatDestroy_MPIAIJ (mpiaij.c:919)
> > ==2175==    by 0x870CC31: PCDestroy (precon.c:83)
> > ==2175==    by 0x8627601: KSPDestroy (itfunc.c:695)
> > ==2175==
> > ==2174==    at 0x43BF469: __strcmp_ssse3 (strcmp-ssse3.S:1765)
> > ==2174==    by 0x830D1DF: MatDestroy_SeqAIJ_Inode (inode2.c:62)
> > ==2174==    by 0x82AB1E1: MatDestroy_SeqAIJ (aij.c:810)
> > ==2174==    by 0x82595D1: MatDestroy (matrix.c:876)
> > ==2174==    by 0x8327843: MatDestroy_MPIAIJ (mpiaij.c:900)
> > ==2174==    by 0x8470F9F: MatDestroy_MPIMAIJ (maij.c:152)
> > ==2174==    by 0x85A560D: PCDestroy_MG_Private (mg.c:232)
> > ==2174==  Address 0x456f218 is 24 bytes inside a block of size 26 alloc'd
> > ==2174==    by 0x830D905: MatCreate_SeqAIJ_Inode (inode2.c:101)
> > ==2174==    by 0x82BEB04: MatCreate_SeqAIJ (aij.c:3414)
> > ==2174==
> > ==2174==    at 0x43BF46D: __strcmp_ssse3 (strcmp-ssse3.S:1766)
> > ==2174==    by 0x82AB357: MatDestroy_SeqAIJ (aij.c:815)
> > ==2174==    by 0x85A5A49: PCDestroy_MG (mg.c:257)
> > ==2174==  Address 0x456d898 is 24 bytes inside a block of size 28 alloc'd
> > ==2174==    by 0x82BE442: MatCreate_SeqAIJ (aij.c:3369)
> > ==2174==
> > ==2174==    at 0x43BF22D: __strcmp_ssse3 (strcmp-ssse3.S:1553)
> > ==2174==    by 0x82AB527: MatDestroy_SeqAIJ (aij.c:819)
> > ==2174==  Address 0x456df28 is 24 bytes inside a block of size 28 alloc'd
> > ==2174==    by 0x82BE616: MatCreate_SeqAIJ (aij.c:3381)
> > ==2174==
> > ==2174==    at 0x43BEFED: __strcmp_ssse3 (strcmp-ssse3.S:1340)
> > ==2174==    by 0x8327F64: MatDestroy_MPIAIJ (mpiaij.c:919)
> > ==2174==    by 0x870CC31: PCDestroy (precon.c:83)
> > ==2174==    by 0x8627601: KSPDestroy (itfunc.c:695)
> > ==2174==
> > ==2175==    by 0x8791BD2: MPIR_Allgatherv (allgatherv.c:160)
> > ==2175==  Address 0x4c37f38 is 0 bytes after a block of size 360 alloc'd
> > ==2175==    by 0x8132724: ISCreateGeneral (general.c:342)
> > ==2175==    by 0x813BE92: ISColoringGetIS (iscoloring.c:161)
> > ==2175==    by 0x836235A: MatFDColoringCreate_MPIAIJ (fdmpiaij.c:30)
> > ==2175==
> > ==2174==    at 0x43B674F: __memcpy_ssse3 (memcpy-ssse3.S:703)
> > ==2174==  Address 0x4cb0c68 is 0 bytes after a block of size 360 alloc'd
> > ==2174==
> > ==2174==    by 0x87923CB: MPIR_Allgatherv (allgatherv.c:340)
> > ==2174==  Address 0x4461998 is 0 bytes after a block of size 720 alloc'd
> > ==2174==    by 0x8791B68: MPIR_Allgatherv (allgatherv.c:143)
> > ==2174==
> > ==2175==    by 0x80B0A16: PetscFinalize (pinit.c:829)
> > ==2175==    by 0x804CCA7: main (ex19.c:181)
> > ==2175==
> > ==2174==    by 0x80B0A16: PetscFinalize (pinit.c:829)
> > ==2174==    by 0x804CCA7: main (ex19.c:181)
> > ==2174==
> > ==2174==    by 0x87E2922: PMI_Finalize (simple_pmi.c:398)
> > ==2174==    by 0x87CB316: MPIDI_PG_Finalize (mpidi_pg.c:92)
> > ==2174==    by 0x87C728D: MPID_Finalize (mpid_finalize.c:141)
> > ==2174==    by 0x879FA8C: PMPI_Finalize (finalize.c:158)
> > ==2174==    by 0x80B2276: PetscFinalize (pinit.c:973)
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2174==
> > ==2175==    by 0x87E2922: PMI_Finalize (simple_pmi.c:398)
> > ==2175==    by 0x87CB316: MPIDI_PG_Finalize (mpidi_pg.c:92)
> > ==2175==    by 0x87C728D: MPID_Finalize (mpid_finalize.c:141)
> > ==2175==    by 0x879FA8C: PMPI_Finalize (finalize.c:158)
> > ==2175==    by 0x80B2276: PetscFinalize (pinit.c:973)
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==
> > ==2175==    at 0x43BF5D4: __strcmp_ssse3 (strcmp-ssse3.S:1902)
> > ==2175==
> > ==2174==
> > ==2174== HEAP SUMMARY:
> > ==2174==     in use at exit: 160 bytes in 11 blocks
> > ==2174==   total heap usage: 60,266 allocs, 60,255 frees, 51,015,236 bytes allocated
> > ==2174==
> > ==2174== LEAK SUMMARY:
> > ==2174==    definitely lost: 40 bytes in 1 blocks
> > ==2174==    indirectly lost: 120 bytes in 10 blocks
> > ==2174==      possibly lost: 0 bytes in 0 blocks
> > ==2174==    still reachable: 0 bytes in 0 blocks
> > ==2174==         suppressed: 0 bytes in 0 blocks
> > ==2174== Rerun with --leak-check=full to see details of leaked memory
> > ==2174==
> > ==2174== For counts of detected and suppressed errors, rerun with: -v
> > ==2174== Use --track-origins=yes to see where uninitialised values come from
> > ==2174== ERROR SUMMARY: 15690 errors from 164 contexts (suppressed: 0 from 0)
> > ==2175==
> > ==2175== HEAP SUMMARY:
> > ==2175==     in use at exit: 160 bytes in 11 blocks
> > ==2175==   total heap usage: 59,069 allocs, 59,058 frees, 49,630,900 bytes allocated
> > ==2175==
> > ==2175== LEAK SUMMARY:
> > ==2175==    definitely lost: 40 bytes in 1 blocks
> > ==2175==    indirectly lost: 120 bytes in 10 blocks
> > ==2175==      possibly lost: 0 bytes in 0 blocks
> > ==2175==    still reachable: 0 bytes in 0 blocks
> > ==2175==         suppressed: 0 bytes in 0 blocks
> > ==2175== Rerun with --leak-check=full to see details of leaked memory
> > ==2175==
> > ==2175== For counts of detected and suppressed errors, rerun with: -v
> > ==2175== Use --track-origins=yes to see where uninitialised values come from
> > ==2175== ERROR SUMMARY: 15664 errors from 162 contexts (suppressed: 0 from 0)
> > What is going on here? Shall I ignore those errors?
> > Thanks a lot!
> > Rebecca Xuefei YUAN
> > Department of Applied Physics and Applied Mathematics
> > Columbia University
> > Tel:917-399-8032
> > www.columbia.edu/~xy2102
