[petsc-users] petsc-users Digest, Vol 23, Issue 32
Rongliang Chen
rongliang.chan at gmail.com
Mon Nov 29 20:26:45 CST 2010
Hi Jed,
Thank you for your reply.
The Matrix A and Vector x are created by MatCreateMPIAIJ and VecCreateMPI
and
matrix A is obtained by SNESDefaultComputeJacobian.
I compared the results using the following routine:
sprintf(filename,"A.m");
ierr =
PetscViewerASCIIOpen(PETSC_COMM_WORLD,filename,&view->viewer);CHKERRQ(ierr);
ierr = PetscViewerSetFormat(view->viewer,
PETSC_VIEWER_ASCII_MATLAB);CHKERRQ(ierr);
ierr = MatView(A, view->viewer);CHKERRQ(ierr);
Vec y;
ierr = VecDuplicate(x, &y);CHKERRQ(ierr);
ierr = MatMult(A, x, y);CHKERRQ(ierr);
sprintf(filename,"x.m");
ierr =
ierr = VecView(x, view->viewer);CHKERRQ(ierr);
sprintf(filename,"y.m");
ierr =
ierr = VecView(y, view->viewer);CHKERRQ(ierr);
In the Matlab, I first load the files A.m, x.m and y.m into A, x and y, and
then do "error=norm(A*x - y)".
The 'error' is very big(about 200).
Following your suggestion, I can write the matrix and vectors into binary
files, but I do not how to load
these binary files into matlab matrix and vector.
I do not understand the command: [A,x,y] =
PetscBinaryRead('binaryoutput'), can this command load
the binary files into matlab matrix and vector? Thanks.
Best,
Rongliang
> Message: 2
> Date: Sun, 28 Nov 2010 21:18:59 +0100
> From: Jed Brown <jed at 59A2.org>
> Subject: Re: [petsc-users] Why MatMult(A, x, Ax) != A*x?
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> <AANLkTikGhD+2WcBmaZOR8xfT=D2Vh5xeK4HYHY_bG2vM at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> On Sun, Nov 28, 2010 at 21:11, Rongliang Chen <rongliang.chan at gmail.com
> >wrote:
> > The format of the matrix A is AIJ and is obtained by function
> > I compute A*x in Matlab with the following A and x and compare it with
> Ax.
> > ierr = MatMult(*A, x, Ax);CHKERRQ(ierr);
> > ierr =
> > sprintf(filename,"Ax.m");
> > ierr =
> > ierr = VecView(Ax, view->viewer);CHKERRQ(ierr);
> Are the vectors and matrices obtained from a DA (DACreateGlobalVector,
> DAGetMatrix)? How are you comparing the matrix that PETSc sees with the
> matrix that Matlab sees? I suggest writing the matrix and both vectors to
> a
> PETSc binary file
> PetscViewer viewer = PETSC_VIEWER_BINARY(PETSC_COMM_WORLD);
> MatView(A,viewer);
> VecView(x,viewer);
> MatMult(A,x,y);
> VecView(y,viewer);
> and read them into Matlab with
> [A,x,y] = PetscBinaryRead('binaryoutput')
> norm(A*x - y) % This should be small
> Jed
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101128/d97eefaa/attachment-0001.htm
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101129/1f0c733b/attachment-0001.htm>
