[petsc-users] MatPermuteSparsify hanging
Jed Brown
jed at 59A2.org
Mon Nov 29 13:32:11 CST 2010
On Mon, Nov 29, 2010 at 20:28, Kelly Fermoyle <kjf198 at cse.psu.edu> wrote:
> I am using a Cray machine and it requires that I call as aprun -n 1
> ./prog_name, which does not seem to work with -start_in_debugger.
Can you reproduce with the same code on a local machine (e.g.
desktop/laptop) where you can get a proper debugging session?
> Below is the output of the full backtrace:
This trace is not even in your code
> #2 0x0000000000403be7 in main (argc=20, argv=0x7fffe2814538) at
aprun.c:225
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101129/5237ebe4/attachment-0001.htm>
