[petsc-users] Adding adaptive mesh refinement to current fortran code
TAY wee-beng zonexo at gmail.com
Thu Nov 18 04:04:19 CST 2010
Hi Barry,
In that case, will it be very difficult to use paramesh together with
PETSc?
I may thinking that as long as I can create a matrix from paramesh and
store it as a PETSc format matrix, everything should be fine when I try
to solve Ax=b. Is it the same for the parallel case too?
Or is it better if I direct the questions to the paramesh developers?
Thanks!
Yours sincerely,
TAY wee-beng
On 17-11-2010 18:28, Barry Smith wrote:
>     libmesh has adaptive refinement and all kinds of cool stuff and lives on top of PETSc.
>      Barry
>     But it is C++.
> On Nov 17, 2010, at 8:04 AM, TAY wee-beng wrote:
>> Hi,
>> I am thinking of adding adaptive mesh refinement to my current fortran code. I am using an immersed boundary code with staggered cartesian grid. I am using PETSc to solve my momentum equations and PETSc/hypre to solve my poisson equation. The code now runs in parallel.
>> Since I'm programming in fortran, some other c++ packages may not be feasible.  I am considering packages like paramesh and AGRIF. I wonder if it is possible to integrate them together with PETSc. Is there anything which I need to consider too?
>> Thanks!
>> Yours sincerely,
>> TAY wee-beng
