[petsc-users] Index set with zero size
Tim Kroeger tim.kroeger at cevis.uni-bremen.de
Thu Nov 11 10:03:36 CST 2010
On Thu, 11 Nov 2010, Tim Kroeger wrote:
> On Wed, 10 Nov 2010, Jed Brown wrote:
>> On Tue, Nov 9, 2010 at 15:43, Tim Kroeger <tim.kroeger at cevis.uni-bremen.de>
>> wrote:
>>       Okay, I implemented a workaround on user side (using a temporary
>> vector and MatMult()).  This seems to
>>       resolve the problem now.  I'll leave it like this in the libMesh
>> part, so that libMesh remains
>>       compatible with PETSc-3.1-p4.  Nevertheless, if you fix this within a
>> few days and launch PETSc-3.1-p5
>>       with this fix (or just send me a patch), let me know, I can then test
>> it.
>> I fixed this, and also a bug with nontrivial MatDiagonalScale after
>> MatGetSubMatrix.  You can get it from hg, or in
>> the next patch level (I don't know when that will be).
> Yes, this fixes it.  Thank you very much again.
One more question: Does this bux and fix also apply to a submatrix of
an MPIAIJ matrix? That is, can I safely use MatMultAdd() having v2==v3
for such a matrix in 3.1.0-p4 or not?  (I'm having trouble with such a
matrix now, but the error might be on my side.)
Best Regards,
Tim
Dr. Tim Kroeger
CeVis -- Center of Complex Systems and Visualization
University of Bremen              tim.kroeger at cevis.uni-bremen.de
Universitaetsallee 29             tim.kroeger at mevis.fraunhofer.de
D-28359 Bremen                             Phone +49-421-218-7710
Germany                                    Fax   +49-421-218-4236
