[petsc-users] MatCreateMPIAIJWithSplitArrays for symmetric matrix?
Daniel Langr
daniel.langr at gmail.com
Mon Nov 8 06:07:50 CST 2010
Dne 8.11.2010 12:45, Jed Brown napsal(a):
> On Mon, Nov 8, 2010 at 12:36, Daniel Langr <daniel.langr at gmail.com
> <mailto:daniel.langr at gmail.com>> wrote:
> I am looking for several eigenvalues and eigenvectors with SLEPc.
> Presumably using methods that don't need a solve?
I don't use a linear solver, I use Lanczos or other iterative algorithm
based on sparse matrix-vector multiplication.
> Where does the sparsity of the matrix come from?
> Lie algebra, Slater determinants, SU(3) groups, new bases... But I
> don't understand all these things much, I just solve their
> (physicist's) eigenproblems.
> This more likely explains what the entries are, but not what the
> sparsity is. Sparse problems usually have some spatial locality (and/or
> locality in frequency or ensemble space). It is usually much easier to
> find a reasonable upper bound for the sparsity than to figure out
> exactly what the entries are. But I understand that this may be hard,
> such as if the support of the basis functions grew without bound due to
> some nonlinearity in the system.
> I don't know the exact matrix structure, but I need some estimate
> about the number of nonzeros, since the matrix needs to fit into a
> memory. And I can simply use 85-90% of available memory for arrays,
> and just left some space for vectors (but vectors are very small -
> matrices are not much sparse). If I underestimate arrays' size, I
> will abort a computation, cause I don't have any more memory.
> Why not use MatMPISBAIJSetPreallocation and MatSetOption
> MAT_NEW_NONZERO_ALLOCATION_ERR to abort if you have underestimated? How
> would you do better than this yourself?
Ok, that's a good idea and I will try it. I can estimate total number of
nonzeros (limited by the amount of memory), but I can hardly estimate
number of nonzeros per particular rows (d_nnz, o_nnz). So I need to use
d_nz and o_nz, right? And for symmetric matrix, what do d_nz and o_nz
mean? Is it number of nonzeros for whole matrix row, or just upper
triangular part? (I don't see this in manual page.)
(That was my point, through MatMPISBAIJSetPreallocation I need to
estimate number of nonzeros per row. Not just number of nonzeros of
whole local part. If I construct CSR arrays directly, I don't need this
row-estimates.)
Daniel
> Jed
