[petsc-users] MatCreateMPIAIJWithSplitArrays for symmetric matrix?
Daniel Langr
daniel.langr at gmail.com
Mon Nov 8 05:36:39 CST 2010
Dne 8.11.2010 12:24, Jed Brown napsal(a):
> On Mon, Nov 8, 2010 at 12:14, Daniel Langr <daniel.langr at gmail.com
> <mailto:daniel.langr at gmail.com>> wrote:
> MatCreateMPISBAIJWithArrays() copy the arrays, so it won't help me.
> I need all available memory for a matrix, so I cannot have it in
> memory twice.
> What preconditioners do you use? Block Jacobi with incomplete
> factorization, for example, uses the same amount of memory as the
> matrix, presumably you could free those arrays before factoring. This
> doesn't help if you use SOR.
I am looking for several eigenvalues and eigenvectors with SLEPc.
> Matrices emerge in new methods in nuclear structure computations
> (symmetry-adapted no-core shell models). I don't know how to
> allocate arrays exactly.
> Where does the sparsity of the matrix come from?
Lie algebra, Slater determinants, SU(3) groups, new bases... But I don't
understand all these things much, I just solve their (physicist's)
eigenproblems.
> But, I can generate a matrix into CSR format and then probably
> reorganize it (split into diagonal and off-diagonal entries).
> It's not clear how you could generate it in CSR format to begin with,
> considering that if you underallocate, you will be forced to reallocate
> and copy. It would be possible to have a
> MatCreateMPISBAIJWithSplitArrays, but it would be very peculiar to be
> able to create the arrays without being able to preallocate correctly.
I don't know the exact matrix structure, but I need some estimate about
the number of nonzeros, since the matrix needs to fit into a memory. And
I can simply use 85-90% of available memory for arrays, and just left
some space for vectors (but vectors are very small - matrices are not
much sparse). If I underestimate arrays' size, I will abort a
computation, cause I don't have any more memory.
Daniel
> Jed
