[petsc-users] Initial guess for the GMRES solver in PETSC
jinshan wu wujinshan at yahoo.com
Fri Nov 5 14:30:20 CDT 2010
Aron and Dave, thanks both of you a lot.
Jinshan
Message: 6
Date: Fri, 5 Nov 2010 08:54:15 +0100
Subject: Re: [petsc-users] Initial guess for the GMRES solver in PETSC
To: PETSc users list <petsc-users at mcs.anl.gov>
Message-ID:
    <AANLkTikzKoBnD9n+dkMrUmR3FUry_BhgEGFXO8cZJfk- at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
Or you can specify this directly in your code.
See
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPSetInitialGuessNonzero.html
Cheers,
  Dave
On 5 November 2010 07:11, Aron Ahmadia <aron.ahmadia at kaust.edu.sa> wrote:
> Hi Jinshan,
> You can pass your initial guess in to the KSP object as X, then at the
> command line set the flag:
> -ksp_initial_guess_nonzero
> Happy Computing,
> Aron
> On Fri, Nov 5, 2010 at 8:41 AM, jinshan wu <wujinshan at yahoo.com> wrote:
>> Hi all,
>> I am using the GMRES linear solver in PETSC. I have a very good initial guess
>>of
>> the true solution. Can I somehow supply it to the solver? It should help the
>> solver speed up the convergence if I can do that. Thanks.
>> Jinshan
petsc-users mailing list
https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
End of petsc-users Digest, Vol 23, Issue 4
