[petsc-users] distributed arrays
Jeff Brown jeffrey.scott.brown at gmail.com
Sat May 1 18:25:27 CDT 2010
I'm new to PetSc, but have been following your mailing list for several
months.
I'm using fortran95 if it changes the answer, but from reading the manual it
looks like only syntax changes.
I'm interested in using distributed arrays in my work, but I need to be able
to specify 2D grids that are not simply NX by NY.
I'm using a finite difference formulation and I would like to be able to use
a completely arbitrary number of processors,
like NP = 17.
For NP=17 on a square underlying finite difference grid (for the following
illustration, the side of a sqaure=1),
the optimum configuration (minimizing boundary surface to interior volume)
is the following:
[ 3 x 3 grid, each individual square is 1/3 x 3/17 on a side],
followed by a
[2x4 grid where each individual square is 1/2 x 2/17 on a side]
I've illustrated this below, with A and B being the 1/3 x 3/17 grids and C
and D being the 1/2 by 2/17 cells
AAA BBB AAA CC DD CC DD
BBB AAA BBB CC DD CC DD
BBB AAA BBB DD CC DD CC
AAA BBB AAA DD CC DD CC
Is there a way to specify this distribution of grid cells using distributed
arrays?
At different stages in computing with the distributed arrays, I would like
to be able to group sets of ghost values together for communication.
These will be different groups at different stages of the computation.
Let me illustrate with an example.
Step 1: Calculate A[east], B[east], C[east], D[east] on the ghost interface,
      each of A, B, C, D is a distributed array of doubles
      [east] means calculating the ghost interface to the east of each cell
Step 2: Transmit (A,B,C,D)[east] together.
     Let's pick the stuff on processor 1 for reference.
     If I were implementing this in raw MPI, I would create a combined
buffer = {A1east, B1east, C1east, D1east} and then send the total buffer
Step 3: Overlapping calculations of A[west], B[west], C[west], D[west]
Step 4: Transmit (A,B,C,D)[west] together
Step 5: Overlapping calculations of A[north], B[north], C[north], D[north]
Step 6: Transmit (A,B,C,D)[north]
Step 7: Overlapping calculations of A[south], B[south], C[south], D[south]
Step 8: Transmit (A,B,C,D)[south]
Step 9: Overlapping calcluations of A[center], B[center], C[center],
D[center]
Step 10: Wait on east, west, north, south
At different stages, A, B, C, D   might be A, B, C, D, E, F  (where ABCD are
the same as above).
Is there a good way to do this?
Suggestions?
--Jeff Brown
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100501/109df53c/attachment.htm>
