[petsc-users] Configuring PETSc with Intel compiler.
Tue Mar 30 12:50:11 CDT 2010
You should use CXX=icpc
Satish
On Tue, 30 Mar 2010, Pedro Torres wrote:
> Hello,
> I'm trying to compile PETSc with intel compiler and get the error below. I
> can compile a c/c++ source code without problem.
> What am I doing wrong?.  Thanks a lot
> ./config/configure.py PETSC_ARCH=linux-gnu-c++-nodebug-parmetis CXX=icc
> FC=ifort  --with-clanguage=C++ --download-parmetis=1
> --download-parmetis=/home/ptorres/soft/ParMetis-dev-p3.tar.gz
> --with-blas-lapack-dir=/opt/intel/mkl/10.2.4.032 --with-debugging=0
> CXXOPTFLAGS='-O3 -xN -tpp7 -ipo'
>              Configuring PETSc to compile on your system
> TESTING: checkCxxCompiler from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:585)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> C++ compiler you provided with -CXX=icc does not work
