[petsc-users] inserting into sparse matricies
Jed Brown jed at 59A2.org
Fri Mar 26 10:28:26 CDT 2010
On Fri, 26 Mar 2010 11:18:08 -0400, John-Michael Fischer <fischej at umich.edu> wrote:
> I have a vector of values I want to insert into a sparse matrix as a
> row.  My vector contains non-zero values at their proper positions in
> the row and zero's elsewhere.
How did you get this vector with all the explicit zeros?
There is an option MAT_IGNORE_ZERO_ENTRIES, but I don't think you want
to use it here.
> Alternatively, I was thinking I could assemble a vector with the
> indecies of the non-zero elements, then use that in the call to
> MatSetValues with a row vector of non-zero values only - but I wanted
> to ask first since this seems like a common usage pattern for PETSC
> sparse mat's.
Usually you only compute the nonzero entries.
Jed
