[petsc-users] DAGlobalToLocalBegin()
Jed Brown
jed at 59A2.org
Wed Mar 24 15:50:00 CDT 2010
On Wed, 24 Mar 2010 15:34:24 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 24, 2010, at 2:41 PM, (Rebecca) Xuefei YUAN wrote:
> > Hi,all,
> > I have an error from
> > ierr = DAGlobalToLocalBegin(dafield,X,INSERT_VALUES,localFIELD);
> > CHKERRQ(ierr);
> > where
> > ierr = DMMGSetSNES(dmmg, FormFunction,0);CHKERRQ(ierr); is used for
> > set up the SNES.
> There is not enough information here to determine what is going
> on. Where is X coming from? Where is dafield coming from?
Apply the attached patch and run snes ex25 on two procs. The solution
vector is a local vector on the second entry to FormFunction (within
SNESDefaultComputeJacobianColor) when it would normally be a global one
(the residual vector is correctly global in both cases). This vector is
created in DMMGComputeJacobianWithFD (damgsnes.c:362). Note that
MatFDColoringApply_AIJ calls the function in a different place than the
local function (I think this is where all the logic is, FormFunction is
called from fdmatrix.c:680, FormFunctionLocal is called from
fdmatrix.c:588).
Note that this all works fine with -dmmg_iscoloring_type global.
Jed
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100324/cce38202/attachment.bin>
