[petsc-users] DAGlobalToLocalBegin()
    Jed Brown
    jed at 59A2.org
    Wed Mar 24 14:55:56 CDT 2010
On Wed, 24 Mar 2010 15:41:38 -0400, "(Rebecca) Xuefei YUAN" <xy2102 at columbia.edu> wrote:
> Hi,all,
> I have an error from
> ierr = DAGlobalToLocalBegin(dafield,X,INSERT_VALUES,localFIELD);
> CHKERRQ(ierr);
> where
> ierr = DMMGSetSNES(dmmg, FormFunction,0);CHKERRQ(ierr); is used for
> set up the SNES.
> So I check up the vector size of X, F, localFIELD where
> 	ierr = DAGetLocalVector(dafield,&localFIELD);CHKERRQ(ierr);
> 	PetscInt	nlocalFIELD,nX,nF;
> 	ierr = VecGetSize(localFIELD,&nlocalFIELD);CHKERRQ(ierr);
> 	ierr = VecGetSize(X,&nX);CHKERRQ(ierr);
> 	ierr = VecGetSize(F,&nF);CHKERRQ(ierr);
> CHKERRQ(ierr);
> 	ierr = DAGlobalToLocalEnd(dafield,X,INSERT_VALUES,localFIELD);CHKERRQ(ierr);
>   	ierr = DAVecGetArray(dafield,localFIELD,&localfield);CHKERRQ(ierr);
> (gdb) disp nX
> 1: nX = 120
> (gdb) disp nF
> 2: nF = 120
> (gdb) disp nlocalFIELD
> 3: nlocalFIELD = 100
Is this run in parallel?  Note that the sizes of X and F are global,
while localFIELD is serial.  What error did you get?
Matt, it's clearly FormFunction and not FormFunctionLocal because the
function prototype has the SNES.
Jed
