[petsc-users] Linking error with C++ code: undefined symbols
charles reid charlesreid1 at gmail.com
Tue Mar 23 19:37:00 CDT 2010
(Please let me know if I can give any additional information that would be
helpful for this problem.)
I'm trying to use Petsc in an object-oriented C++ code, developing with g++
on Mac OS X 10.5, and I'm running into some problems in the linking stage.
I've defined an object that uses Petsc (what I'm calling the GmresSolver
class), and the object compiles just fine.  However, when it comes time to
compile the driver (Laplace.cc) and link to Petsc libraries, I see a bunch
of "Undefined symbol" errors.
In my object code that uses Petsc (GmresSolver.h), I have included the Petsc
header file as:
extern "C" {
#include "petscksp.h"
In the driver (Laplace.cc), depending on how I include the Petsc header
file, I get different errors.  If I include it like I do in GmresSolver.h,
extern "C" {
#include "petsc.h"
I get a whole slew of header file syntax errors (see postscript of email).
If I just include the header file,
#include "petsc.h"
then I get the undefined symbols problem (more below).
My configure line for Petsc is
Users/charles/pkg/petsc-2.3.3-p15/config/configure.py \
   --prefix=$HOME/pkg/petsc-2.3.3-p15 \
   --with-python \
   --with-mpi=0 \
   --with-debugging=1 \
   PETSC_DIR=$HOME/pkg/petsc-2.3.3-p15
Here's my step-by-step to produce the error:
1. Compile all non-Petsc object code
2. Compile object code that uses Petsc using this command:
g++ -c -Wall  -I.  -I/Users/charles/pkg/petsc-2.3.3-p15
-I/Users/charles/pkg/petsc-2.3.3-p15/bmake/darwin9.5.0-c-opt
-I/Users/charles/pkg/petsc-2.3.3-p15/include ./GmresSolver.
(as mentioned, this works fine.)
3. Compile the driver, "Laplace.cc", and link it to Petsc's libraries:
g++  \
 -I/Users/charles/pkg/petsc-2.3.3-p15/  \
 -I/Users/charles/pkg/petsc-2.3.3-p15/include  \
 -I/Users/charles/pkg/petsc-2.3.3-p15/include/mpiuni  \
 -I/Users/charles/pkg/petsc-2.3.3-p15/include/petsc \
 -DPETSC_STATIC_INLINE=""  \
 Laplace.cc  \
 -L/Users/charles/pkg/petsc-2.3.3-p15 \
 -L/Users/charles/pkg/petsc-2.3.3-p15/lib/darwin9.5.0-c-opt \
 -lpetscts -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc \
 BoundaryConditionFactory.o  BoundaryCondition.o Field.o FileIO.o
GmresSolver.o JacobiSolver.o Timer.o TimerFactory.o
(Note: I don't know why I need -DPETSC_STATIC_INLINE="", but I do, otherwise
I see a bunch of errors like "petsc-2.3.3-p15/include/petscviewer.h:117:
error: ‘PETSC_STATIC_INLINE’ does not name a type" - anyone know what that's
all about?)
This last compiler command gives the undefined symbols errors:
Undefined symbols:
  "PetscOptionsGetReal(char const*, char const*, double*, PetscTruth*)",
referenced from:
      PetscOptionsGetReal(char const*, double*, PetscTruth*)in ccPG7mg3.o
  "_Petsc_MPI_Abort", referenced from:
      _PetscMaxSum_Local in libpetsc.a(pinit.o)
      _PetscADMax_Local in libpetsc.a(pinit.o)
      _PetscADMin_Local in libpetsc.a(pinit.o)
      _PetscSynchronizedFlush in libpetsc.a(mprint.o)
      _PetscOptionsCheckInitial_Private in libpetsc.a(init.o)
      _PetscLogPrintSummary in libpetsc.a(plog.o)
      _PetscError in libpetsc.a(err.o)
      _PetscMallocDumpLog in libpetsc.a(mtr.o)
      _PetscSequentialPhaseBegin_Private in libpetsc.a(mpiu.o)
      _PetscSequentialPhaseEnd_Private in libpetsc.a(mpiu.o)
      _PetscSignalHandler_Private in libpetsc.a(signal.o)
      _PetscDefaultSignalHandler in libpetsc.a(signal.o)
      _PetscMPIAbortErrorHandler in libpetsc.a(errstop.o)
      _PetscDefaultFPTrap in libpetsc.a(fp.o)
  "_Petsc_MPI_Comm_dup", referenced from:
      _PetscFinalize in libpetsc.a(pinit.o)
      _PetscSequentialPhaseBegin in libpetsc.a(mpiu.o)
      _PetscCommDuplicate in libpetsc.a(tagm.o)
  "_Petsc_MPI_Init", referenced from:
      _PetscInitialize in libpetsc.a(pinit.o)
  "PetscOptionsGetTruth(char const*, char const*, PetscTruth*,
PetscTruth*)", referenced from:
      PetscOptionsGetTruth(char const*, PetscTruth*, PetscTruth*)in
ccPG7mg3.o
  "PetscInitialize(int*, char***, char const*, char const*)", referenced
      PetscInitialize(int*, char***)in ccPG7mg3.o
      _main in ccPG7mg3.o
  "_MPIUNI_TMP", referenced from:
      _MPIUNI_TMP$non_lazy_ptr in ccPG7mg3.o
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(pinit.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(mprint.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(init.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(options.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(plog.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(mpinit.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(err.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(mtr.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(mpiu.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(verboseinfo.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(adebug.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(binv.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(filev.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(eventLog.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(view.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(pdisplay.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(tagm.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(mpiuopen.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(draw.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(sysio.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(pbarrier.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(dupl.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(fretrieve.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(send.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(dscatter.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(petscvu.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(axis.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(random.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(drawv.o)
      _MPIUNI_TMP$non_lazy_ptr in libpetsc.a(lg.o)
  "PetscOptionsGetScalar(char const*, char const*, double*, PetscTruth*)",
referenced from:
      PetscOptionsGetScalar(char const*, double*, PetscTruth*)in ccPG7mg3.o
  "_Petsc_MPI_Keyval_create", referenced from:
      _PetscViewerASCIIGetStdout in libpetsc.a(vcreatea.o)
      _PetscViewerASCIIGetStderr in libpetsc.a(vcreatea.o)
      _PetscViewerASCIIOpen in libpetsc.a(vcreatea.o)
      _PETSC_VIEWER_BINARY_ in libpetsc.a(binv.o)
      _PetscViewerDestroy_ASCII in libpetsc.a(filev.o)
      _PetscCommGetNewTag in libpetsc.a(tagm.o)
      _PetscCommDestroy in libpetsc.a(tagm.o)
      _PetscSharedTmp in libpetsc.a(fretrieve.o)
      _PetscSharedWorkingDirectory in libpetsc.a(fretrieve.o)
      _PETSC_VIEWER_SOCKET_ in libpetsc.a(send.o)
      _PETSC_VIEWER_DRAW_ in libpetsc.a(drawv.o)
  "_Petsc_MPI_Attr_delete", referenced from:
      _PetscSequentialPhaseEnd in libpetsc.a(mpiu.o)
  "_Petsc_MPI_Attr_get", referenced from:
  "_Petsc_MPI_Attr_put", referenced from:
  "PetscOptionsGetString(char const*, char const*, char*, unsigned long,
      PetscOptionsGetString(char const*, char*, unsigned long,
  "_Petsc_MPI_Finalize", referenced from:
      _Petsc_MPI_DebuggerOnError in libpetsc.a(init.o)
      _PetscAttachDebuggerErrorHandler in libpetsc.a(adebug.o)
  "PetscOptionsGetRealArray(char const*, char const*, double*, int*,
      PetscOptionsGetRealArray(char const*, double*, int*, PetscTruth*)in
ccPG7mg3.o
  "PetscOptionsGetInt(char const*, char const*, int*, PetscTruth*)",
referenced from:
      PetscOptionsGetInt(char const*, int*, PetscTruth*)in ccPG7mg3.o
  "PetscViewerCreate(int, _p_PetscViewer**)", referenced from:
      PetscViewerCreate(_p_PetscViewer**)      in ccPG7mg3.o
  "_Petsc_MPI_Comm_free", referenced from:
  "PetscFinalize()", referenced from:
      _main in ccPG7mg3.o
  "PetscOptionsHasName(char const*, char const*, PetscTruth*)", referenced
      PetscOptionsHasName(char const*, PetscTruth*)in ccPG7mg3.o
  "PetscOptionsGetStringArray(char const*, char const*, char**, int*,
      PetscOptionsGetStringArray(char const*, char**, int*, PetscTruth*)in
ccPG7mg3.o
  "_MPIUNI_Memcpy", referenced from:
      _PetscMaxSum in libpetsc.a(pinit.o)
      _PetscGlobalMax in libpetsc.a(pinit.o)
      _PetscGlobalMin in libpetsc.a(pinit.o)
      _PetscGlobalSum in libpetsc.a(pinit.o)
      _PetscLogPrintDetailed in libpetsc.a(plog.o)
      _PetscIntView in libpetsc.a(err.o)
      _PetscRealView in libpetsc.a(err.o)
      _PetscScalarView in libpetsc.a(err.o)
  "_Petsc_MPI_Initialized", referenced from:
  "PetscOptionsGetIntArray(char const*, char const*, int*, int*,
      PetscOptionsGetIntArray(char const*, int*, int*, PetscTruth*)in
ccPG7mg3.o
  "PetscSequentialPhaseBegin(int, int)", referenced from:
      PetscSequentialPhaseBegin(int)  in ccPG7mg3.o
      PetscSequentialPhaseBegin()     in ccPG7mg3.o
  "PetscSequentialPhaseEnd(int, int)", referenced from:
      PetscSequentialPhaseEnd(int)  in ccPG7mg3.o
      PetscSequentialPhaseEnd()     in ccPG7mg3.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
Is this a problem with my libpetsc.a?  Or is this problem because another
library is broken or not being linked to?  Any insight into this problem
would be greatly appreciated.  After several hours of trying to figure this
out I feel like I'm lost at sea.
Charles
Postscript:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h: In function
‘PetscErrorCode PetscViewerCreate(_p_PetscViewer**)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h:117: error:
declaration of C function ‘PetscErrorCode
PetscViewerCreate(_p_PetscViewer**)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h:116: error:
previous declaration ‘PetscErrorCode PetscViewerCreate(MPI_Comm,
_p_PetscViewer**)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h:117: error: invalid
conversion from ‘int’ to ‘_p_PetscViewer**’
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h:117: error: too
many arguments to function ‘PetscErrorCode
/Users/charles/pkg/petsc-2.3.3-p15/include/petscviewer.h:117: error: at this
point in file
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h: In function
‘PetscErrorCode PetscOptionsHasName(const char*, PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:10: error:
declaration of C function ‘PetscErrorCode PetscOptionsHasName(const char*,
PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:9: error: previous
declaration ‘PetscErrorCode PetscOptionsHasName(const char*, const char*,
PetscTruth*)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:10: error: cannot
convert ‘const char*’ to ‘PetscTruth*’ for argument ‘2’ to ‘PetscErrorCode
‘PetscErrorCode PetscOptionsGetInt(const char*, PetscInt*, PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:12: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetInt(const char*,
PetscInt*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:11: error:
previous declaration ‘PetscErrorCode PetscOptionsGetInt(const char*, const
char*, PetscInt*, PetscTruth*)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:12: error: cannot
convert ‘const char*’ to ‘PetscInt*’ for argument ‘2’ to ‘PetscErrorCode
‘PetscErrorCode PetscOptionsGetTruth(const char*, PetscTruth*,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:14: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetTruth(const char*,
PetscTruth*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:13: error:
previous declaration ‘PetscErrorCode PetscOptionsGetTruth(const char*, const
char*, PetscTruth*, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:14: error: cannot
PetscOptionsGetTruth(const char*, PetscTruth*, PetscTruth*)’
‘PetscErrorCode PetscOptionsGetReal(const char*, PetscReal*, PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:16: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetReal(const char*,
PetscReal*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:15: error:
previous declaration ‘PetscErrorCode PetscOptionsGetReal(const char*, const
char*, PetscReal*, PetscTruth*)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:16: error: cannot
convert ‘const char*’ to ‘PetscReal*’ for argument ‘2’ to ‘PetscErrorCode
‘PetscErrorCode PetscOptionsGetScalar(const char*, PetscScalar*,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:18: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetScalar(const char*,
PetscScalar*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:17: error:
previous declaration ‘PetscErrorCode PetscOptionsGetScalar(const char*,
const char*, PetscScalar*, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:18: error: cannot
convert ‘const char*’ to ‘PetscScalar*’ for argument ‘2’ to ‘PetscErrorCode
PetscOptionsGetScalar(const char*, PetscScalar*, PetscTruth*)’
‘PetscErrorCode PetscOptionsGetIntArray(const char*, PetscInt*, PetscInt*,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:20: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetIntArray(const
char*, PetscInt*, PetscInt*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:19: error:
previous declaration ‘PetscErrorCode PetscOptionsGetIntArray(const char*,
const char*, PetscInt*, PetscInt*, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:20: error: cannot
PetscOptionsGetIntArray(const char*, PetscInt*, PetscInt*, PetscTruth*)’
‘PetscErrorCode PetscOptionsGetRealArray(const char*, PetscReal*, PetscInt*,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:22: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetRealArray(const
char*, PetscReal*, PetscInt*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:21: error:
previous declaration ‘PetscErrorCode PetscOptionsGetRealArray(const char*,
const char*, PetscReal*, PetscInt*, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:22: error: cannot
PetscOptionsGetRealArray(const char*, PetscReal*, PetscInt*, PetscTruth*)’
‘PetscErrorCode PetscOptionsGetString(const char*, char*, size_t,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:24: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetString(const char*,
char*, size_t, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:23: error:
previous declaration ‘PetscErrorCode PetscOptionsGetString(const char*,
const char*, char*, size_t, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:24: error: invalid
conversion from ‘const char*’ to ‘char*’
conversion from ‘char*’ to ‘size_t’
conversion from ‘size_t’ to ‘PetscTruth*’
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:24: error: too
many arguments to function ‘PetscErrorCode PetscOptionsGetString(const
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:24: error: at this
point in file
‘PetscErrorCode PetscOptionsGetStringArray(const char*, char**, PetscInt*,
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:26: error:
declaration of C function ‘PetscErrorCode PetscOptionsGetStringArray(const
char*, char**, PetscInt*, PetscTruth*)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:25: error:
previous declaration ‘PetscErrorCode PetscOptionsGetStringArray(const char*,
const char*, char**, PetscInt*, PetscTruth*)’ here
PetscTruth*)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petscoptions.h:26: error: cannot
convert ‘const char*’ to ‘char**’ for argument ‘2’ to ‘PetscErrorCode
PetscOptionsGetStringArray(const char*, char**, PetscInt*, PetscTruth*)’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h: In function
‘PetscErrorCode PetscInitialize(int*, char***)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1160: error: declaration
of C function ‘PetscErrorCode PetscInitialize(int*, char***)’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1159: error: previous
declaration ‘PetscErrorCode PetscInitialize(int*, char***, const char*,
const char*)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1160: error: too many
arguments to function ‘PetscErrorCode PetscInitialize(int*, char***)’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1160: error: at this
point in file
‘PetscErrorCode PetscSequentialPhaseBegin(MPI_Comm)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1347: error: declaration
of C function ‘PetscErrorCode PetscSequentialPhaseBegin(MPI_Comm)’ conflicts
with
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1346: error: previous
declaration ‘PetscErrorCode PetscSequentialPhaseBegin(MPI_Comm,
PetscMPIInt)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1347: error: too many
arguments to function ‘PetscErrorCode PetscSequentialPhaseBegin(MPI_Comm)’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1347: error: at this
point in file
‘PetscErrorCode PetscSequentialPhaseBegin()’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1348: error: declaration
of C function ‘PetscErrorCode PetscSequentialPhaseBegin()’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1347: error: previous
declaration ‘PetscErrorCode PetscSequentialPhaseBegin(MPI_Comm)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1348: error: too many
arguments to function ‘PetscErrorCode PetscSequentialPhaseBegin()’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1348: error: at this
point in file
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1350: error: declaration
of C function ‘PetscErrorCode PetscSequentialPhaseEnd(MPI_Comm)’ conflicts
with
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1349: error: previous
declaration ‘PetscErrorCode PetscSequentialPhaseEnd(MPI_Comm, PetscMPIInt)’
here
‘PetscErrorCode PetscSequentialPhaseEnd(MPI_Comm)’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1350: error: too many
arguments to function ‘PetscErrorCode PetscSequentialPhaseEnd(MPI_Comm)’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1350: error: at this
point in file
‘PetscErrorCode PetscSequentialPhaseEnd()’:
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1351: error: declaration
of C function ‘PetscErrorCode PetscSequentialPhaseEnd()’ conflicts with
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1350: error: previous
declaration ‘PetscErrorCode PetscSequentialPhaseEnd(MPI_Comm)’ here
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1351: error: too many
arguments to function ‘PetscErrorCode PetscSequentialPhaseEnd()’
/Users/charles/pkg/petsc-2.3.3-p15/include/petsc.h:1351: error: at this
point in file
Laplace.cc: In function ‘int main(int, char**)’:
Laplace.cc:206: error: at this point in file
This last error doesn't even make sense, as it conforms to the usage
specified here (
http://www.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-dev/docs/manualpages/Sys/PetscInitialize.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100323/0f0395c7/attachment-0001.htm>
