[petsc-users] Multivector Object
Thu Mar 18 21:15:54 CDT 2010
    Henc,
      PETSc has no concept of "multivectors" nor an infrastructure for
solving linear systems with multiple right hand sides.
      Though there are important subclasses of problems where multiple
right hand sides do come up, we have chosen not to invest resources
needed to make PETSc general enough to handle them cleanly and
efficiently. We have had a small number of requests for such support,
it seems the vast majority of users have never expressed any need for
it.
      To truly support "multivectors" I would replace the Vec object
in PETSc with an object that represents one or more vectors and
propagate this change throughout PETSc; that is I won't have a Vec
version of solvers and a multivector version, I would only have a
multivector version.  The difficulties to truly do this right are
1) multiple right hand size Krylov methods are actually pretty tricky
to code robustly since one must properly deal with the various
multivectors in the Krylov space becoming linearly dependent and thus
one needs to "remove" one of the vectors in the multivector for later
iterations and then later remove another etc.
2) to get the best performance it is likely one wants to interlace the
vectors in the multivector. Thus suddenly iterating with one fewer
vectors is not as simple as simply discarding a pointer, one must
uninterlace the vectors by one vector.
    In an ideal world with unlimited time and money, we would rewrite
PETSc around a "multivector" but frankly we have so many other cool
things that we want to do that this is unlikely to happen.
    Barry
On Mar 18, 2010, at 8:51 PM, Henc Bouwmeester wrote:
> Hello all,
> In section 4.2 of the manual, it is stated that the only option for
> solving linear systems having the same preconditioner is to call
> KSPSolve() multiple times.  However, when dealing with such a
> system, one can take advantage of DGEMM when updating the vectors as
> a 'multivector'.  Has anyone attempted to create a multivector
> object in PETSc?  If so, what is the interface and where can I find
> the code?  If not, can anyone speak to the difficulties?
> Thank you,
> Henc
