[petsc-users] -log_summary
Tue Mar 16 08:32:56 CDT 2010
   Hmm, you shouldn't need to use a PetscLogBegin() after
PetscInitialize(). When -log_summary is used PetscLogBegin() is
automatically called by PetscInitialize(). I cannot explain the
behavior you are seeing.
    Barry
On Mar 16, 2010, at 5:51 AM, burckhardt at itis.ethz.ch wrote:
> Dear Barry,
> the Cray software seems to be innocent as -log_summary afilename
> did'nt have an effect. However, the introduction of a
> PetscLogBegin() after PetscInitialize(...) solved the problem.
> Thank you anyway!
> Kathrin
> Quoting "Barry Smith" <bsmith at mcs.anl.gov>:
>>   The Cray software may not be properly flushing all the standard
>> out data before the process ends. Try using -log_summary afilename
>> and see if the file afilename is complete with the log information.
>>    Barry
>> On Mar 15, 2010, at 5:58 AM, burckhardt at itis.ethz.ch wrote:
>>> Dear all,
>>> I have problems with the display of -log_summary on the Cray XT5.
>>> Only the lines
>>> Event                Count      Time (sec)     Flops/
>>> sec                         --- Global ---  --- Stage ---   Total
>>>                 Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
>>> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>> --- Event Stage 0: Main Stage
>>> are printed but nothing follows. Do you have an idea why?
>>> Best regards,
>>> Kathrin
