[petsc-users] PetscSplitOwnerShip()
Tue Mar 9 18:56:25 CST 2010
On Mar 9, 2010, at 6:52 PM, (Rebecca) Xuefei YUAN wrote:
> Dear Matt,
> Thanks for your reply. I did not partition by my own, and even if I
> use VecLoadIntoVector(), the same error shows up.
   It cannot be the same error, because the trace below has a call to
VecLoad() which you are not using.
   If you saved the vector to the binary file before with VecView()
from a DA vector then you need to use VecLoadIntoVector() with
the same type of vector from the same size DA. That is if
DAGetGlobalVector() was used to create the vector that you saved to
disk you need
to use the same DAGetGlobalVector() to get a vector to read into.
    Barry
> Anything wrong with it?
> Cheers,
> Rebecca
> Quoting Matthew Knepley <knepley at gmail.com>:
>> If you do your own partitioning, you need to use
>> VecLoadIntoVector() with a
>> Vec you get from the DA.
>>   Matt
>> On Tue, Mar 9, 2010 at 5:16 PM, (Rebecca) Xuefei YUAN
>> <xy2102 at columbia.edu>wrote:
>>> Hi,
>>> I ran np=4 for a small (-da_grid_x 6, -da_grid_y 5) problem, with
>>> PETSC_STENCIL_BOX and width=2, dof = 4.
>>> When I use vecLoad() to load the binary file with the following set:
>>> PetscViewerBinaryOpen
>>> (PETSC_COMM_WORLD,fileName,FILE_MODE_READ,&viewer);
>>>   VecLoad(viewer,PETSC_NULL,&FIELD);
>>>   ierr = DAVecGetArray(da2_4,FIELD,&field);CHKERRQ(ierr);
>>>   ierr = DAVecRestoreArray(da2_4,FIELD,&field);CHKERRQ(ierr);
>>>   ierr = VecDestroy(FIELD);CHKERRQ(ierr);
>>>   ierr = DADestroy(da2_4);CHKERRQ(ierr);
>>>   ierr = PetscViewerDestroy(viewer);CHKERRQ(ierr);
>>> However, I got the error messages as below:
>>> [0]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/
>>> dagetarray.c
>>> Vector local size 32 is not compatible with DA local sizes 36 100
>>> [1]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/
>>> dagetarray.c
>>> [2]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/
>>> dagetarray.c
>>> Vector local size 28 is not compatible with DA local sizes 24 80
>>> [3]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/
>>> dagetarray.c
>>> Then I tracked down and tried to find how this 32,32,28,28 coming
>>> from.
>>> It turns out that my da2_4 has the parameters at each processor:
>>>     xs xe ys ye x y Xs Xe Ys Ye Nl base nlocal Nlocal
>>> p0:   0  12 0  3 12 3 0  20 0  5  100 0   100    36
>>> p1:   12 24 0  3 12 3 4  24 0  5  100 36  100    36
>>> p2:   0  12 3  5 12 2 0  20 1  5  80  72   80    24
>>> p3:   12 24 3  5 12 2 4  24 1  5  80  96   80    24
>>> and deep in
>>> #0  PetscSplitOwnership (comm=-2080374782, n=0x8a061b4, N=0x8a061b8)
>>>   at psplit.c:81
>>> #1  0x08628384 in PetscLayoutSetUp (map=0x8a061b0) at pmap.c:140
>>> #2  0x08618320 in VecCreate_MPI_Private (v=0x8a05c50,
>>> alloc=PETSC_TRUE,
>>>   nghost=0, array=0x0) at pbvec.c:182
>>> #3  0x08618ba7 in VecCreate_MPI (vv=0x8a05c50) at pbvec.c:232
>>> #4  0x085f1554 in VecSetType (vec=0x8a05c50, method=0x885dd0b "mpi")
>>>   at vecreg.c:54
>>> #5  0x085ec4f0 in VecSetTypeFromOptions_Private (vec=0x8a05c50)
>>>   at vector.c:1335
>>> #6  0x085ec909 in VecSetFromOptions (vec=0x8a05c50) at vector.c:1370
>>> #7  0x085d7a7e in VecLoad_Binary (viewer=0x89f70b0,
>>> itype=0x885ce3d "mpi",
>>>   newvec=0xbfe148e4) at vecio.c:228
>>> #8  0x085d70e4 in VecLoad (viewer=0x89f70b0, outtype=0x885ce3d
>>> "mpi",
>>>   newvec=0xbfe148e4) at vecio.c:134
>>> #9  0x0804f140 in FormInitialGuess_physical (dmmg=0x89a2880,
>>> X=0x89b34f0)
>>>   at vecviewload_out.c:390
>>> #10 0x08052ced in DMMGSolve (dmmg=0x89a2720) at damg.c:307
>>> #11 0x0804d479 in main (argc=-1, argv=0xbfe14cd4) at
>>> vecviewload_out.c:186
>>> it says that
>>>     *n = *N/size + ((*N % size) > rank);
>>> where *N = 30; size = 4; rank = 0,1,2,3, in such a case, this
>>> gives me
>>> *n = 32,32,28,28 for pro0,1,2,3, separately.
>>> Where could be wrong with this mismatch of the local vector size
>>> and da
>>> local size(excluding ghost pts or including ghost pts)?
>>> Thanks so much!
>>> Rebecca
>> experiments
>> is infinitely more interesting than any results to which their
>> experiments
>> lead.
>> -- Norbert Wiener
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
