[petsc-users] amg from hypre
hxie at umn.edu hxie at umn.edu
Mon Mar 8 12:31:30 CST 2010
I use left preconditioner. So the preconditioned residual should be less
than 10e-6||b||_2+10e^-10. How to print the final preconditioned residual
using the command line options? Or I will use -ksp_mpnitor to show all the
residuals.
Hui
On Mar 8 2010, Jed Brown wrote:
>On 08 Mar 2010 11:50:46 -0600, hxie at umn.edu wrote:
>> I printed the real residuals by computing ||b-Ax||_2  at the last column:
>>  equation  iter    gm_its    gmres
>> Linear solve converged due to CONVERGED_RTOL iterations 223
>>  field      1       223   0.414E+00
>How is there "nothing wrong" with this?
>Jed
