[petsc-users] amg from hypre
hxie at umn.edu
hxie at umn.edu
Mon Mar 8 11:50:46 CST 2010
I printed the real residuals by computing ||b-Ax||_2 at the last column:
equation iter gm_its gmres
Linear solve converged due to CONVERGED_RTOL iterations 223
field 1 223 0.414E+00
Linear solve did not converge due to DIVERGED_ITS iterations 500
field 2 500 0.116E-05
field 3 500 0.922E-08
field 4 500 0.182E-08
field 5 500 0.256E-09
Nothing wrong with the inner linear systems. I chose "gmres rtol" as 1.0d-6
and "gmres atol" as 1.d-10 for the preconditioned system.
>This is the problem. The inner linear systems are just not really being
>solved. Have you looked at
>the convergence (-ksp_monitor)? You can get different nonlinear iteration
>counts this way.
> Matt
