[petsc-users] amg from hypre
hxie at umn.edu
hxie at umn.edu
Mon Mar 8 09:05:43 CST 2010
On Mar 8 2010, Jed Brown wrote:
>On 06 Mar 2010 15:41:12 -0600, hxie at umn.edu wrote:
>> Hi,
>> I am solving incompressible navier-stokes equations. The code implements
>> the Newton iteration and just uses the KSP solver for each iteration. It
>> takes 14 nonlinear iterations (~8min) to converge using the default
>> solver
>> in PETSc. But it takes 6 nonlinear iterations (~30min) using boomeramg
>> from
>> hypre.
>Can you confirm that these are the number of NONLINEAR iterations?
Yes.
>Changing the preconditioner should not change this if it behaving
>correctly. Are you solving incompressible NS in a coupled manner,
>sending the indefinite (momentum + continuity equations) to the
>preconditioner?
It is a temperature driven flow. Temperature field is also included. We use
high order method (2nd order for velocity) to discretize the system and
solve it in a coupled manner. We do a small shifting for the preconditioner
to avoid zero diagonals.
>In this case, BoomerAMG can be giving you completely
>the wrong answer. For example, on a different Navier-Stokes example, it
>produces very nice preconditioned residuals
> 0 KSP Residual norm 9.526419214320e+00
> 1 KSP Residual norm 9.406988599189e-02
> 2 KSP Residual norm 2.767040414824e-03
> 3 KSP Residual norm 1.649604812054e-03
> 4 KSP Residual norm 1.611023301144e-03
> 5 KSP Residual norm 7.073431543229e-04
> 6 KSP Residual norm 1.404066303578e-04
> 7 KSP Residual norm 1.347821147393e-04
> 8 KSP Residual norm 7.713640141302e-05
> 9 KSP Residual norm 5.121198361232e-05
> 10 KSP Residual norm 4.790100151952e-05
> 11 KSP Residual norm 1.769376148248e-05
> 12 KSP Residual norm 1.671836687758e-05
> 13 KSP Residual norm 9.561298137614e-06
> 14 KSP Residual norm 6.509746067580e-07
> 15 KSP Residual norm 5.863323408081e-07
> 16 KSP Residual norm 5.120192651612e-07
> 17 KSP Residual norm 3.403122131501e-07
> 18 KSP Residual norm 3.342529361191e-07
> 19 KSP Residual norm 9.178974981883e-08
>but converges to completely the WRONG answer. This is because the
>preconditioner is singular, and the unpreconditioned residuals (using
>right-preconditioned GMRES) look like
> 0 KSP Residual norm 9.899494936612e+05
> 1 KSP Residual norm 3.460941545811e-02
> 2 KSP Residual norm 3.411670842883e-02
> 3 KSP Residual norm 3.406431296292e-02
> 4 KSP Residual norm 3.376198186394e-02
> 5 KSP Residual norm 3.374434209905e-02
> 6 KSP Residual norm 3.370086274150e-02
> 7 KSP Residual norm 3.334190783058e-02
> 8 KSP Residual norm 3.321057363881e-02
> 9 KSP Residual norm 3.321055343672e-02
> 10 KSP Residual norm 3.318392045928e-02
>which is NO CONVERGENCE at all after the penalty boundary conditions
>were enforced. So CPU time aside, the nonlinear iteration count could
>occur because Newton is failing due to an incorrect search direction or
>a vanishing step size, but the answer could be completely wrong.
>You have to clear up subtleties like getting the wrong answer before
>looking any further at the amount of time the various preconditioners
>are taking. Always run with
> -snes_converged_reason -ksp_converged_reason
>and check the unpreconditioned residuals, especially when dealing with
>indefinite problems.
>Jed
The result looks correct. I will double check by computing the real
residual by b-Ax. For all the methods I set the same options "-ksp_max_it
500 -ksp_gmres_restart 50". And each nonlinear iteration will take 500
gmres iteration. Maybe the 500 V cycles takes much more time than the ilu0.
Will there be a big difference to implement the amg directly from hypre?
Thanks.
Bests,
Hui
