[petsc-users] using PETSc libraries in an OpenMP application
Tue Mar 2 21:04:30 CST 2010
  Yes, see the manual page for PCOPENMP.
  Possibly you want to use the hypre BoomerAMG algebraic multigrid
solver inside it.
   The command line argument would be mpiexec -n <p> programname -
openmp_merge_size  <p>  -ksp_type preonly -pc_type openmp -
openmp_pc_type hypre
    You need to start your program with the line PetscInitialize() end
with PetscFinalize() have your usual OpenMP code in between and create
a sequential AIJ matrix to hold the matrix and a sequential KSP object
to hold the linear system.
   Barry
On Mar 2, 2010, at 8:42 PM, David L Rodriguez wrote:
> Hello.  I am new to PETSc so bare with me.  I have gone through the
> archived questions but have not been able to find an answer to my
> question.  So here it goes.
> I have a huge CFD application that is parallelized exclusively with
> OpenMP.  There is no use of MPI anywhere.  I am making significant
> enhancements to this code and one enhancement includes an additional
> elliptic solver for that builds very sparse matrices.  The matrix is
> huge and has significantly varying eigenvalues and therefore I need
> a preconditioned iterative solver.  I would like to implement PETSc
> in this code to solve this matrix, but it from what I can tell, I
> can only run it in serial.  Is there a way to call the parallel
> PETSc libraries from an application that is parallelized strictly
> with OpenMP?
> Any ideas would be very much appreciated.  Thanks.
> ____________________
> David L Rodriguez, Ph.D.
> Desktop Aeronautics, Inc.
> PH: 650-323-3141
> dlr at desktopaero.com
> http://desktopaero.com
