[petsc-users] ublas sparse matrix bindings?
Luke Bloy
luke.bloy at gmail.com
Tue Jun 29 10:16:17 CDT 2010
Thanks for the response. Thats unfortunate as i use many different types
of matrices that i would like use with petsc.
I'm not much of a c++ whiz, but i'm curious if something like an adaptor
would be possible that would make a
(float *) behave like a (petscscalar *) as far as petsc was concerned?
Thoughts?
-Luke
On 06/29/2010 10:31 AM, Satish Balay wrote:
> On Tue, 29 Jun 2010, Luke Bloy wrote:
>> Thanks for the quick responses.
>> my matrices are fairly large 80,000 x 80,000 and not too sparse so I'd like to
>> avoid any serialization if possible.
>> I've worked out how to use MatCreateSeqAIJWithArrays so long as i control the
>> types used in my ublas matrix, which is something i'd like to avoid doing if
>> possible.
>> unfortunately I'm not sure how to control the types petscscalar and petscint.
>> I've looked through
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-3.0.0/include/petsc.h.html#PetscScalar
>> and
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-3.0.0/docs/manualpages/Sys/PetscScalar.html
>> which seem to suggest that I can use command line flags --with-scalar-type
>> etc to control these typedefs is it possible to control these in the code
>> directly if so how?
> They are configure/compile time constants - and one can't have 2 types
> in the same code. By default PetscScalar is 'double; and 'PetscInt is 'int'.
> Satish
