[petsc-users] help about my first petsc program
Barry Smith
bsmith at mcs.anl.gov
Mon Jun 28 13:44:13 CDT 2010
On Jun 28, 2010, at 1:21 PM, Xuan YU wrote:
> On Jun 23, 2010, at 1:17 PM, Jed Brown wrote:
>> On Wed, 23 Jun 2010 12:45:37 -0400, Xuan YU <xxy113 at psu.edu> wrote:
>>> I changed dt=0.4 and the Monitor function, so GL doesn't work.
>> Choosing a smaller dt (only an initial value in this case) fixes that
>> problem, but I still see some difficulties unless I give
>> -ts_gl_max_order 2 (seems like I don't have enough stabilization for the
>> higher-order error estimators). But feel free to keep using the simpler
>> methods, I'm sure they will be more predictable.
>>> PetscErrorCode Monitor(TS ts,PetscInt step,PetscReal time,Vec u, void
>>> *ctx)
>>> PetscScalar *y;
>>> PetscReal dt;
>>> TSGetTimeStep(ts,&dt);
>>> VecGetArray(u,&y);
>>> PetscPrintf(PETSC_COMM_WORLD,"At t =%e y =%e %e %e,
>>> \n",time,y[0],y[1],y[2]);
>>> VecRestoreArray(u,&y);
>>> if(step>0)dt=time*9;
>>> TSSetTimeStep(ts,dt);
>>> return 0;
>> TSGL has an adaptive controller, based on a local error estimator. It
>> surely won't work right if the monitor changes it (because it doesn't
>> happen in the correct place; GL can't change the step size arbitrarily,
>> it needs to know the size of the next step when it "completes" the
>> current one). You should be able to TSGLAdaptRegisterDynamic() you own
>> adaptive scheme, there is currently NONE, SIZE (only step size, not
>> order), and BOTH (default). If you do this, and it works better than
>> the builtin ones, let me know and I'll add it to the library.
>>> Why Petsc is faster than cvode? How fast it will be?
>> It might not be faster, but at least you can get back CVODE as a runtime
>> option. And since PETSc offers a lot more preconditioning options, you
>> can probably beat it that way. Whether PETSc-native integrators
>> (e.g. TSTHETA, TSGL) are faster or not is very problem dependent.
>> Jed
> I have successfully solve my problem with TS. But it is slower than Cvode. I don't know how to choose preconditioner.
-pc_type asm or whatever preconditioner you want to use. Run with -help to see the options
> I only found preconditioner option in SNES. Is that means I should use SNES to solve my problem?
NO
Barry
> Many thanks!
> Xuan YU
> xxy113 at psu.edu
