[petsc-users] help about my first petsc program
Xuan YU
xxy113 at psu.edu
Wed Jun 23 11:24:36 CDT 2010
On Jun 23, 2010, at 12:14 PM, Jed Brown wrote:
> On Wed, 23 Jun 2010 10:22:19 -0400, Xuan YU <xxy113 at psu.edu> wrote:
>> I got the correct results! Thanks!
> If you are feeling like experimenting, you could try -ts_type gl which
> is a very new adaptive order adaptive step method for stiff
> systems. It
> seems to be okay on your problem, but the controller is currently
> pretty
> fragile (it's possible for step size to go to zero due to poor error
> estimates, or for length/order to oscillate spuriously with several
> step
> period).
> Jed
I tried these method. Pseudo and Beuler work well. gl kept running
after t=1.665007e+01.
Actually, I will solve a global ODE system in form of y'=f(t,y;x), x
is the forcing. The problem has been solved by cvode(sundials). I want
to use petsc to improve efficiency.
