[petsc-users] updating values in a DA Global array
Matthew Knepley
knepley at gmail.com
Tue Jun 22 18:53:59 CDT 2010
On Tue, Jun 22, 2010 at 11:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt,
> Actually DAVecRestoreArrayF90() only works for 1 dimensional DAs. The
> F90 interface has to be written for 2 and 3d and the creation of Fortran 3d
> arrays (and 4d for dof > 1) stuff written.
Ah, I see. Mark, if you can bear C for 1 function, it will work. The problem
for the F90 is that we
are cutting out a section of a big array, and making it look
multidimensional. It is possible with F90,
but a pain to get everything right in the array descriptor and no one has
had to stamina to do it yet.
Sorry about that,
Matt
> Barry
> On Jun 22, 2010, at 6:21 PM, Matthew Knepley wrote:
> On Tue, Jun 22, 2010 at 12:59 PM, Mark Cheeseman <
> mark.cheeseman at kaust.edu.sa> wrote:
>> Hi,
>> I am trying to write a PETSc program in FORTRAN90 where I need to update a
>> single value in a global distributed array. I know the global coordinates
>> of the position that needs to be updated in the global array but I cannot
>> get the mapping from the local vector correct. In this case, I am working
>> on a domain with global dimensions [arraysize(1),arraysize(2),arraysize(3)]
>> and I want to alter a single point in the global distributed array, uGLOBAL,
>> at the global position [arraysize(1)/2-1,arraysize(2)-1,3]. I cannot seem
>> to be able to do this... what am I doing wrong?
>> DA da
>> Vec uGLOBAL, uLOCAL, tmp
>> PetscErrorCode ierr
>> PetscScalar, pointer :: xx
>> PetscInt rank, source_rank, i,j,k, row
>> call MPI_Comm_rank( PETSC_COMM_WORLD, rank, ierr )
>> call DACreate3d( PETSC_COMM_WORLD, DA_NONPERIODIC, DA_STENCIL_BOX, &
>> arraysize(1), arraysize(2), arraysize(3),
>> PETSC_DECIDE, &
>> PETSC_DECIDE, PETSC_DECIDE, 1, 5,
>> PETSC_NULL_INTEGER, &
>> PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, da, ierr)
>> call DACreateGlobalVector( da, pNOW, ierr )
>> call DAGetCorners( da, xs, ys, zs, xl, yl, zl, ierr )
> call DAVecGetArrayF90()
>> do i = xs,xs+xl-1
>> if ( i.eq.arraysize(1)/2-1 ) then
>> do j = ys,ys+yl-1
>> if ( j.eq.arraysize(2)/2-1 ) then
>> do k = zs,zs+zl-1
>> if ( k.eq.3 ) then
> array(k,j,i) = pressure
>> endif
>> enddo
>> endif
>> enddo
>> endif
>> enddo
> call
> That should work.
> Matt
> Thank you,
>> Mark
>> Mark Patrick Cheeseman
>> Computational Scientist
>> KSL (KAUST Supercomputing Laboratory)
>> Building 1, Office #126
>> King Abdullah University of Science & Technology
>> Thuwal 23955-6900
>> Kingdom of Saudi Arabia
>> EMAIL : mark.cheeseman at kaust.edu.sa
>> PHONE : +966 (2) 808 0221 (office)
>> +966 (54) 470 1082 (mobile)
>> SKYPE : mark.patrick.cheeseman
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100622/dbbaccbf/attachment-0001.htm>
