[petsc-users] help about my first petsc program
XUAN YU
xxy113 at psu.edu
Tue Jun 22 18:09:32 CDT 2010
I got my program to run. But the results doesn't make any sence.
At t = 0 y =1.000000e+00 0.000000e+00 0.000000e+00,
At t = 0.01 y =9.996000e-01 4.000000e-04 0.000000e+00,
At t = 0.02 y =9.992002e-01 -4.720016e-02 4.800000e-02,
At t = 0.03 y =7.722397e-01 -6.681768e+02 6.684045e+02,
At t = 0.04 y =-4.466124e+07 -1.338934e+11 1.339381e+11,
At t = 0.05 y =-1.793342e+24 -5.376439e+27 5.378233e+27,
At t = 0.06 y =-2.891574e+57 -8.668938e+60 8.671830e+60,
At t = 0.07 y =-7.517556e+123 -2.253763e+127 2.254515e+127,
At t = 0.08 y =-5.081142e+256 -1.523326e+260 1.523834e+260,
At t = 0.09 y =-inf nan inf,
At t = 0.1 y =nan nan nan,
At t = 0.11 y =nan nan nan,
At t = 0.12 y =nan nan nan,
At t = 0.13 y =nan nan nan,
At t = 0.14 y =nan nan nan,
Would you please help me check what's wrong with my code?
#include "petscts.h"
/*The problem is from
* chemical kinetics, and consists of the following three rate
* equations:
* dy1/dt = -.04*y1 + 1.e4*y2*y3
* dy2/dt = .04*y1 - 1.e4*y2*y3 - 3.e7*(y2)^2
* dy3/dt = 3.e7*(y2)^2
* on the interval from t = 0.0 to t = 4.e10, with initial
* conditions: y1 = 1.0, y2 = y3 = 0.*/
typedef struct {
PetscInt m;
}AppCtx;
extern PetscErrorCode
FormJacobian(TS,PetscReal,Vec,Mat*,Mat*,MatStructure*,void*),Monitor(TS
ts,PetscInt step,PetscReal time,Vec u,void*ctx),
FormFunction(TS,PetscReal,Vec,Vec,void*);
int main(int argc,char **argv)
TS ts;
Vec u;
PetscScalar *u_localptr;
Mat J;
AppCtx user;
PetscInt its,m;
PetscReal dt,ftime;
PetscErrorCode ierr;
PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL);
m=3;
dt=0.01;
ierr = PetscOptionsGetInt(PETSC_NULL,"-m",&m,PETSC_NULL);CHKERRQ(ierr);
user.m=m;
ierr=VecCreateSeq(PETSC_COMM_SELF,m,&u);CHKERRQ(ierr);
ierr=VecGetArray(u,&u_localptr);CHKERRQ(ierr);
u_localptr[0]=1.0;
u_localptr[1]=0.0;
u_localptr[2]=0.0;
ierr = VecRestoreArray(u,&u_localptr);CHKERRQ(ierr);
ierr = TSCreate(PETSC_COMM_WORLD,&ts);CHKERRQ(ierr);
ierr = TSSetProblemType(ts,TS_NONLINEAR);CHKERRQ(ierr);
ierr = TSMonitorSet(ts,Monitor,&user,PETSC_NULL);
ierr = TSSetSolution(ts,u);CHKERRQ(ierr);
ierr = TSSetRHSFunction(ts,FormFunction,&user);CHKERRQ(ierr);
ierr = MatCreate(PETSC_COMM_SELF,&J);CHKERRQ(ierr);
ierr = MatSetSizes(J,PETSC_DECIDE,PETSC_DECIDE,m,m);CHKERRQ(ierr);
ierr = MatSetFromOptions(J);
ierr = TSSetRHSJacobian(ts,J,J,FormJacobian,&user);CHKERRQ(ierr);
ierr = TSSetInitialTimeStep(ts,0.0,dt);CHKERRQ(ierr);
ierr = TSSetDuration(ts,1000,8.e-1);
ierr = TSSetFromOptions(ts);CHKERRQ(ierr);
ierr = TSSetUp(ts);CHKERRQ(ierr);
ierr = TSStep(ts,&its,&ftime);CHKERRQ(ierr);
printf("Number of timesteps = %d final time %4.2e\n",(int)its,ftime);
ierr = VecDestroy(u);CHKERRQ(ierr);
ierr = MatDestroy(J);CHKERRQ(ierr);
ierr = TSDestroy(ts);CHKERRQ(ierr);
ierr = PetscFinalize();CHKERRQ(ierr);
return 0;
PetscErrorCode FormFunction(TS ts,PetscReal t,Vec X,Vec F,void *ptr)
PetscScalar *x,*f;
PetscInt n;
n=3;
ierr = VecGetArray(X,&x);CHKERRQ(ierr);
ierr = VecGetArray(F,&f);CHKERRQ(ierr);
f[0]=-0.04*x[0]+1.0e4*x[1]*x[2];
f[1]=0.04*x[0]-1.0e4*x[1]*x[2]-3*1.0e7*x[1]*x[1];
f[2]=3*1.0e7*x[1]*x[1];
ierr = VecRestoreArray(X,&x);CHKERRQ(ierr);
ierr = VecRestoreArray(F,&f);CHKERRQ(ierr);
return 0;
PetscErrorCode FormJacobian(TS ts,PetscReal t,Vec X,Mat *J,Mat *B,MatStructure
*flag,void *ptr)
Mat jac=*J;
PetscScalar v[3],*x;
PetscInt row,col;
v[0]=-0.04;
v[1]=0.04;
v[2]=0.0;
row=0;
col=0;
ierr = MatSetValues(jac,3,&row,1,&col,v,INSERT_VALUES);CHKERRQ(ierr);
v[0]=1.0e4*x[2];
v[1]=-1.0e4*x[2]-6.0e7*x[1];
v[2]=6.0e7*x[1];
col=1;
v[0]=1.0e4*x[1];
v[1]=-1.0e4*x[1];
v[2]=0.0;
col=2;
ierr = MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
return 0;
PetscErrorCode Monitor(TS ts,PetscInt step,PetscReal time,Vec u, void *ctx)
PetscScalar *y;
VecGetArray(u,&y);
PetscPrintf(PETSC_COMM_WORLD,"At t =%11g y =%e %e %e,
\n",time,y[0],y[1],y[2]);
VecRestoreArray(u,&y);
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100622/1c621853/attachment.htm>
