[petsc-users] DA matrices and vectors ordering
Valerio Grazioso graziosov at me.queensu.ca
Tue Jun 22 03:02:29 CDT 2010
Hi everybody,
I'm building a Poisson solver for a cfd code in a structured grid using fortran 90. Substantially I need to solve a linear system in a cycle with a fixed matrix and a variable rhs.
I'm working with DAs and (being new to Petsc!) I have a problem.
I have built my matrix with :
call DACreate3d(...)
call DAGetMatrix(da,MATAIJ,A,err)
    call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,err)
    call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,err)
and I've got a matrix A ordered in a Petsc ordering: rows and variables have a sequential numbering relative to each processor.
On the other hand building the rhs with
call DACreateLocalVector(da,qloc,err)
call DAGlobalToLocalBegin(da,q,INSERT_VALUES,qloc,err)
call DAGlobalToLocalEnd(da,q,INSERT_VALUES,qloc,err)
call VecGetArrayF90(qloc,qloc_a,err)
	cont=0
	do k=gzs,gzs+gzm-1
		do j=gys,gys+gym-1
			do i=gxs,gxs+gxm-1
			if ( ...... ) then
                        cont=cont+1
			qloc_a(cont)=....
			else
			endif
			enddo
		enddo
	enddo
call VecRestoreArrayF90(qloc,qloc_a,err)
call DALocalToGlobal(da,qloc,INSERT_VALUES,q,err)
I end up with a vector q ordered in the natural ordering (as if it is built with one processor). The questions are:
Is there a way to end up with the same ordering for both the matrix and the rhs ?
If the only way is to use the AO mapping obtained with DAGetAO(), is there an example code that shows how to use the resulting ao to remap the vector (or the matrix) in the Petsc (or the natural) order?
I've seen that I can have the remapping indices but then I haven't understood how to use them to remap the vector (or the matrix).
Regards
Valerio Grazioso
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100622/7f11067f/attachment-0001.htm>
