[petsc-users] about speed
Xuan YU xxy113 at psu.edu
Mon Jul 26 17:50:45 CDT 2010
On Jul 26, 2010, at 3:53 PM, Barry Smith wrote:
>   ./configure an optimized version of PETSc (that is with the ./
> configure flag of --with-debugging=0) and run with -log_summary to
> get a summary of where it is spending the time. This will give you a
> better idea of why it is taking so long.
Does my log summary means the finite difference Jacobian approximation
is not good? Should I write analytic jacobian function(that will be a
huge amount of work)?
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/48f5111a/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/48f5111a/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/48f5111a/attachment-0005.png>
>   Barry
> On Jul 26, 2010, at 2:49 PM, Xuan YU wrote:
>> Hi,
>> I am using TS solving a nonlinear problem. I created an approximate
>> data structure for Jacobian matrix to be used with matcoloring, my
>> MatFDColoringView is like this:
>> <Picture 1.png>
>> But the speed of code is too slow than what I expected. Only 10
>> time step costs 11seconds!
>> What's wrong with my code? How can I speed up?
>> Thanks!
>> This is the ts_view result.
>> TS Object:
>> type: beuler
>> maximum steps=100
>> maximum time=10
>> total number of nonlinear solver iterations=186
>> total number of linear solver iterations=423
>> SNES Object:
>>   type: ls
>>     line search variant: SNESLineSearchCubic
>>     alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>>   maximum iterations=50, maximum function evaluations=10000
>>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>   total number of linear solver iterations=1
>>   total number of function evaluations=19
>>   KSP Object:
>>     type: gmres
>>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>       GMRES: happy breakdown tolerance 1e-30
>>     maximum iterations=10000, initial guess is zero
>>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>     left preconditioning
>>     using PRECONDITIONED norm type for convergence test
>>   PC Object:
>>     type: ilu
>>       ILU: out-of-place factorization
>>       0 levels of fill
>>       tolerance for zero pivot 1e-12
>>       using diagonal shift to prevent zero pivot
>>       matrix ordering: natural
>>       factor fill ratio given 1, needed 1
>>         Factored matrix follows:
>>           Matrix Object:
>>             type=seqaij, rows=1838, cols=1838
>>             package used to perform factorization: petsc
>>             total: nonzeros=8464, allocated nonzeros=8464
>>             total number of mallocs used during MatSetValues calls =0
>>               not using I-node routines
>>     linear system matrix = precond matrix:
>>     Matrix Object:
>>       total: nonzeros=8464, allocated nonzeros=9745
>>       total number of mallocs used during MatSetValues calls =37
>> Xuan YU
>> xxy113 at psu.edu
Xuan YU
xxy113 at psu.edu
