[petsc-users] petsc with hypre on Windows
Wee-Beng TAY zonexo at gmail.com
Mon Jul 26 07:00:23 CDT 2010
Hi all,
I actually tried compiling hypre 2.6b using windows. I can't remember
which version I'm using (Vs2005, 2008) but I followed the instructions
carefully and it worked. Compiling, linking in IDE are also ok. However,
only the C code work. The fortran code just can't work, even after much
help from the developers.
Only the 2.6b version works with windows. However, I have not tried
using both hypre and PETSc in windows.
Thank you very much and have a nice day!
Yours sincerely,
Wee-Beng Tay
On 7/26/2010 5:12 PM, Matthew Knepley wrote:
> This is what we mean when we say that Hypre does not support Windows.
> It really doesn't. You
> can try mailing their list, but I do not anticipate a response other
> than "We do not support Windows".
> The build system is completely broken for this platform, as you have
> experienced. So, my conclusion
> would be to
>   a) switch packages to something that does support Windows
> or
>   b) switch platforms to something that Hypre supports
>   Thanks,
>      Matt
> On Mon, Jul 26, 2010 at 6:40 PM, Dominik Szczerba
> <dominik at itis.ethz.ch <mailto:dominik at itis.ethz.ch>> wrote:
>     I just reinstalled MPICH to C: (and not the default location
>     Program FIles). I also followed Barry and added
>     --with-cxx="win32fe cl"
>     Now I am getting errors when linking to hypre. BOTH hypre and
>     petsc are compiled with MSVC 2008 64bit (configured with cygwin).
>     The library is called libHYPRE.a, and as I watched it compile 'cl'
>     was used for compilation. It failed to link (*.lib not found) as
>     *.a so I renamed it to libHYPRE.lib. Now the error is:
>     Executing:
>     /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl
>     -o conftest.exe    -MT -wd4996  conftest.o
>     -L/cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib
>     -L/cygdri
>     ve/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib -lHYPRE
>     /cygdrive/c/MPICH2/lib/fmpich2.lib
>     /cygdrive/c/MPICH2/lib/fmpich2g.lib /cygdrive/c/MPICH2/lib/mpi.lib
>     s/petsc-3.1-p3/win64-msvc-release/lib
>     -L/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/win64-msvc-release/lib
>     -lf2clapack
>     -L/c
>     -lf2cblas Ws2_32.lib
>     sh:
>     C:\Users\Dominik\Programs\HYPRE-~1.0B\src\hypre\lib\libHYPRE.lib :
>     warning LNK4003: invalid library format; library ignored
>     I configured with:
>     --with-mpi-dir=/cygdrive/c/MPICH2/
>     --with-hypre-dir=/cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/
>     but:
>     $ ls -la /cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib
>     total 8624
>     drwxr-xr-x+ 1 Dominik None       0 2010-07-26 10:17 .
>     drwxr-xr-x+ 1 Dominik None       0 2010-07-23 23:07 ..
>     -rw-r--r--+ 1 Dominik None 8830476 2010-07-23 23:13 libHYPRE.lib
>     How can I go on from here?
>     Regards,
>     Dominik
>     On Sun, Jul 25, 2010 at 11:10 PM, Dominik Szczerba
>         Hi,
>         I am able to build petsc-3.1-p3 on Windows 7 64bit using
>         native compiler (MSVC 2008) with:
>         ./config/configure.py PETSC_DIR=$PWD
>         PETSC_ARCH=win64-msvc-release --download-c-blas-lapack=1
>         --with-parmetis=1 --download-parmetis=1 --with-x=0
>         --with-debugging=0 --with-cc='win32fe cl' --with-fc=0
>         I also managed to build hypre-2.6.0b separately myself using
>         the same compiler. Now the last problem is to build petsc with
>         this external package (--download-hypre will fail). I add to
>         the above configure line:
>         but the configuration fails with:
>                  UNABLE to CONFIGURE with GIVEN OPTIONS    (see
>         configure.log for details):
>         C++ error! mpi.h could not be located at:
>         ['/cygdrive/c/Program Files/MPICH2/include']
>         This error is clearly wrong as:
>         $ ls -la '/cygdrive/c/Program Files/MPICH2/include'
>         total 309
>         drwx------+ 1 SYSTEM SYSTEM  4096 2010-07-21 15:54 .
>         drwx------+ 1 SYSTEM SYSTEM  4096 2010-07-21 15:54 ..
>         -rwx------+ 1 SYSTEM SYSTEM  4776 2007-11-02 15:50 clog_commset.h
>         -rwx------+ 1 SYSTEM SYSTEM   696 2007-11-02 15:50 clog_const.h
>         -rwx------+ 1 SYSTEM SYSTEM   731 2010-02-22 16:22 clog_inttypes.h
>         -rwx------+ 1 SYSTEM SYSTEM  1272 2007-11-02 15:50 clog_uuid.h
>         -rwx------+ 1 SYSTEM SYSTEM   437 2007-11-02 15:50 mpe.h
>         -rwx------+ 1 SYSTEM SYSTEM 11021 2008-01-28 13:59 mpe_log.h
>         -rwx------+ 1 SYSTEM SYSTEM  1833 2007-11-02 15:50 mpe_logf.h
>         -rwx------+ 1 SYSTEM SYSTEM  1159 2007-11-02 15:50 mpe_misc.h
>         -rwx------+ 1 SYSTEM SYSTEM 55623 2010-02-22 16:22 mpi.h
>         -rwx------+ 1 SYSTEM SYSTEM  2439 2010-02-22 17:11 mpi.mod
>         -rwx------+ 1 SYSTEM SYSTEM 14731 2010-02-22 17:11 mpi_base.mod
>         -rwx------+ 1 SYSTEM SYSTEM 35003 2010-02-22 17:11
>         mpi_constants.mod
>         -rwx------+ 1 SYSTEM SYSTEM  8417 2010-02-22 17:11 mpi_sizeofs.mod
>         -rwx------+ 1 SYSTEM SYSTEM 97301 2010-02-22 16:22 mpicxx.h
>         -rwx------+ 1 SYSTEM SYSTEM 18610 2010-02-22 16:22 mpif.h
>         -rwx------+ 1 SYSTEM SYSTEM 16765 2010-02-22 16:22 mpio.h
>         Inspecting the log file shows:
>         Executing: g++ -c -o conftest.o  -Wall -Wwrite-strings
>         -Wno-strict-aliasing -O    -I/cygdrive/c/Program\
>         Files/MPICH2/include conftest.cc
>         I think the error is in the white space in "Program Files". I
>         failed to convince hypre to use the default system
>         installation of MPICH. I *had* to make a hardcopy in C: to
>         avoid the white space.
>         I am sending the log to the maintainters, just in case,
>         because I saw more errors there too.
>         Any help is greatly appreciated.
>         Regards,
>         Dominik
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/d5a45be1/attachment.htm>
