[petsc-users] petsc with hypre on Windows
Dominik Szczerba
dominik at itis.ethz.ch
Mon Jul 26 04:04:01 CDT 2010
Very helpful! So even though 'cl' was used to compile the linking somehow
not. Will clarify with the hypre team and come back.
Dominik
$ dumpbin.exe libHYPRE.lib
Microsoft (R) COFF/PE Dumper Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
Dump of file libHYPRE.lib
File Type: LIBRARY
libHYPRE.lib : warning LNK4003: invalid library format; library ignored
Summary
1BC69 .bss
D6A .data
16F1C .debug$S
6F71 .drectve
13B60 .pdata
29B48 .rdata
1444 .rdata$r
30B3CB .text
1D660 .xdata
On Mon, Jul 26, 2010 at 10:49 AM, Farshid Mossaiby <mossaiby at yahoo.com>wrote:
> I would check the format of the library with 'dumpbin' tool, available from
> Visual Studio command propmpt.
> Hope this helps to identify the problem.
> --- On *Mon, 7/26/10, Dominik Szczerba <dominik at itis.ethz.ch>* wrote:
> From: Dominik Szczerba <dominik at itis.ethz.ch>
> Subject: Re: [petsc-users] petsc with hypre on Windows
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Date: Monday, July 26, 2010, 1:10 PM
> I just reinstalled MPICH to C: (and not the default location Program
> FIles). I also followed Barry and added --with-cxx="win32fe cl"
> Now I am getting errors when linking to hypre. BOTH hypre and petsc are
> compiled with MSVC 2008 64bit (configured with cygwin). The library is
> called libHYPRE.a, and as I watched it compile 'cl' was used for
> compilation. It failed to link (*.lib not found) as *.a so I renamed it to
> libHYPRE.lib. Now the error is:
> Executing:
> /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl -o
> conftest.exe -MT -wd4996 conftest.o
> -L/cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib -L/cygdri
> ve/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib -lHYPRE
> /cygdrive/c/MPICH2/lib/fmpich2.lib /cygdrive/c/MPICH2/lib/fmpich2g.lib
> /cygdrive/c/MPICH2/lib/mpi.lib -L/cygdrive/c/Users/Dominik/Program
> s/petsc-3.1-p3/win64-msvc-release/lib
> -L/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/win64-msvc-release/lib
> -lf2clapack
> -L/c
> -lf2cblas Ws2_32.lib
> sh: C:\Users\Dominik\Programs\HYPRE-~1.0B\src\hypre\lib\libHYPRE.lib :
> I configured with:
> --with-mpi-dir=/cygdrive/c/MPICH2/
> --with-hypre-dir=/cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/
> but:
> $ ls -la /cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/lib
> total 8624
> drwxr-xr-x+ 1 Dominik None 0 2010-07-26 10:17 .
> drwxr-xr-x+ 1 Dominik None 0 2010-07-23 23:07 ..
> -rw-r--r--+ 1 Dominik None 8830476 2010-07-23 23:13 libHYPRE.lib
> How can I go on from here?
> Regards,
> Dominik
> On Sun, Jul 25, 2010 at 11:10 PM, Dominik Szczerba <dominik at itis.ethz.ch<http://us.mc522.mail.yahoo.com/mc/compose?to=dominik@itis.ethz.ch>
> > wrote:
> Hi,
> I am able to build petsc-3.1-p3 on Windows 7 64bit using native compiler
> (MSVC 2008) with:
> ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> --download-c-blas-lapack=1 --with-parmetis=1 --download-parmetis=1
> --with-x=0 --with-debugging=0 --with-cc='win32fe cl' --with-fc=0
> I also managed to build hypre-2.6.0b separately myself using the same
> compiler. Now the last problem is to build petsc with this external package
> (--download-hypre will fail). I add to the above configure line:
> but the configuration fails with:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> C++ error! mpi.h could not be located at: ['/cygdrive/c/Program
> Files/MPICH2/include']
> This error is clearly wrong as:
> $ ls -la '/cygdrive/c/Program Files/MPICH2/include'
> total 309
> drwx------+ 1 SYSTEM SYSTEM 4096 2010-07-21 15:54 .
> drwx------+ 1 SYSTEM SYSTEM 4096 2010-07-21 15:54 ..
> -rwx------+ 1 SYSTEM SYSTEM 4776 2007-11-02 15:50 clog_commset.h
> -rwx------+ 1 SYSTEM SYSTEM 696 2007-11-02 15:50 clog_const.h
> -rwx------+ 1 SYSTEM SYSTEM 731 2010-02-22 16:22 clog_inttypes.h
> -rwx------+ 1 SYSTEM SYSTEM 1272 2007-11-02 15:50 clog_uuid.h
> -rwx------+ 1 SYSTEM SYSTEM 437 2007-11-02 15:50 mpe.h
> -rwx------+ 1 SYSTEM SYSTEM 11021 2008-01-28 13:59 mpe_log.h
> -rwx------+ 1 SYSTEM SYSTEM 1833 2007-11-02 15:50 mpe_logf.h
> -rwx------+ 1 SYSTEM SYSTEM 1159 2007-11-02 15:50 mpe_misc.h
> -rwx------+ 1 SYSTEM SYSTEM 55623 2010-02-22 16:22 mpi.h
> -rwx------+ 1 SYSTEM SYSTEM 2439 2010-02-22 17:11 mpi.mod
> -rwx------+ 1 SYSTEM SYSTEM 14731 2010-02-22 17:11 mpi_base.mod
> -rwx------+ 1 SYSTEM SYSTEM 35003 2010-02-22 17:11 mpi_constants.mod
> -rwx------+ 1 SYSTEM SYSTEM 8417 2010-02-22 17:11 mpi_sizeofs.mod
> -rwx------+ 1 SYSTEM SYSTEM 97301 2010-02-22 16:22 mpicxx.h
> -rwx------+ 1 SYSTEM SYSTEM 18610 2010-02-22 16:22 mpif.h
> -rwx------+ 1 SYSTEM SYSTEM 16765 2010-02-22 16:22 mpio.h
> Inspecting the log file shows:
> Executing: g++ -c -o conftest.o -Wall -Wwrite-strings -Wno-strict-aliasing
> -O -I/cygdrive/c/Program\ Files/MPICH2/include conftest.cc
> I think the error is in the white space in "Program Files". I failed to
> convince hypre to use the default system installation of MPICH. I *had* to
> make a hardcopy in C: to avoid the white space.
> I am sending the log to the maintainters, just in case, because I saw more
> errors there too.
> Any help is greatly appreciated.
> Regards,
> Dominik
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/a2c5951b/attachment-0001.htm>
