[petsc-users] petsc with hypre on Windows
Dominik Szczerba dominik at itis.ethz.ch
Sun Jul 25 16:10:09 CDT 2010
I am able to build petsc-3.1-p3 on Windows 7 64bit using native compiler
(MSVC 2008) with:
./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
--download-c-blas-lapack=1 --with-parmetis=1 --download-parmetis=1
--with-x=0 --with-debugging=0 --with-cc='win32fe cl' --with-fc=0
I also managed to build hypre-2.6.0b separately myself using the same
compiler. Now the last problem is to build petsc with this external package
(--download-hypre will fail). I add to the above configure line:
--with-hypre-dir=/cygdrive/c/Users/Dominik/Programs/hypre-2.6.0b/src/hypre/
but the configuration fails with:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C++ error! mpi.h could not be located at: ['/cygdrive/c/Program
Files/MPICH2/include']
This error is clearly wrong as:
$ ls -la '/cygdrive/c/Program Files/MPICH2/include'
total 309
drwx------+ 1 SYSTEM SYSTEM  4096 2010-07-21 15:54 .
drwx------+ 1 SYSTEM SYSTEM  4096 2010-07-21 15:54 ..
-rwx------+ 1 SYSTEM SYSTEM  4776 2007-11-02 15:50 clog_commset.h
-rwx------+ 1 SYSTEM SYSTEM   696 2007-11-02 15:50 clog_const.h
-rwx------+ 1 SYSTEM SYSTEM   731 2010-02-22 16:22 clog_inttypes.h
-rwx------+ 1 SYSTEM SYSTEM  1272 2007-11-02 15:50 clog_uuid.h
-rwx------+ 1 SYSTEM SYSTEM   437 2007-11-02 15:50 mpe.h
-rwx------+ 1 SYSTEM SYSTEM 11021 2008-01-28 13:59 mpe_log.h
-rwx------+ 1 SYSTEM SYSTEM  1833 2007-11-02 15:50 mpe_logf.h
-rwx------+ 1 SYSTEM SYSTEM  1159 2007-11-02 15:50 mpe_misc.h
-rwx------+ 1 SYSTEM SYSTEM 55623 2010-02-22 16:22 mpi.h
-rwx------+ 1 SYSTEM SYSTEM  2439 2010-02-22 17:11 mpi.mod
-rwx------+ 1 SYSTEM SYSTEM 14731 2010-02-22 17:11 mpi_base.mod
-rwx------+ 1 SYSTEM SYSTEM 35003 2010-02-22 17:11 mpi_constants.mod
-rwx------+ 1 SYSTEM SYSTEM  8417 2010-02-22 17:11 mpi_sizeofs.mod
-rwx------+ 1 SYSTEM SYSTEM 97301 2010-02-22 16:22 mpicxx.h
-rwx------+ 1 SYSTEM SYSTEM 18610 2010-02-22 16:22 mpif.h
-rwx------+ 1 SYSTEM SYSTEM 16765 2010-02-22 16:22 mpio.h
Inspecting the log file shows:
Executing: g++ -c -o conftest.o  -Wall -Wwrite-strings -Wno-strict-aliasing
-O    -I/cygdrive/c/Program\ Files/MPICH2/include conftest.cc
I think the error is in the white space in "Program Files". I failed to
convince hypre to use the default system installation of MPICH. I *had* to
make a hardcopy in C: to avoid the white space.
I am sending the log to the maintainters, just in case, because I saw more
errors there too.
Any help is greatly appreciated.
Dominik
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100725/6341a04a/attachment.htm>
