[petsc-users] configure problems
Dominik Szczerba dominik at itis.ethz.ch
Fri Jul 23 13:14:31 CDT 2010
On Fri, Jul 23, 2010 at 5:15 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 23 Jul 2010, Dominik Szczerba wrote:
> > On Fri, Jul 23, 2010 at 4:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > OK so to conclude this thread, on Windows I need to run the command
> line
> > > > window in Administrator mode, and start the daemon as :
> > > > /cygdrive/c/Program\ Files/MPICH2/bin/smpd.exe -install
> > > > then mpiexec works and 'make test' in petsc source behaves as
> expected
> > > > (login/password needed).
> > > > Will now try to build a version with hypre and parmetis.
> > > These packages don't build with MS compilers. If you need them -
> > > suggest using GNU compilers.
> > > Satish
> > Do you mean mixing Petsc built with MS compilers with hypre/parmetis
> built
> > with cygwin's gcc?
> > Will it work?
> Mixing diferent compilers [esp MS & gnu on windows] will not work. I
> mean: if you really need hypre on windows - then use gnu compilers for
> everything [petsc+mpi+hypre etc..]
> Or just stick with linux..
Unfortunately, I need also a Windows version and I will leave the cygwin
option as the last resort.
For the moment I managed to successfully build petsc with --with-parmetis=1
--download-parmetis=1. When using --download-hypre=1 configure fails
complaining about missing mpi.h, which is surprising.
I was wondering what you meant with "These packages don't build with MS
compilers": dependence on some core unix functionality or the lack of the
appropriate project/build script.
Dominik
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100723/6c9d40b4/attachment.htm>
