[petsc-users] Missing symbols in libpetscts.h
Filippo Spiga filippo.spiga at disco.unimib.it
Fri Jul 23 07:47:39 CDT 2010
  Dear Satish,
     thanks for you reply.  Anyway not in all case the libpetscts.{a,
so} is compiled. Is there a specific option of the configure that build
this specific PETSc library? It is also possible that I miss something
else or my environment is not "clean"....
Once again, thank you very much.
-------- Original Message  --------
Subject: Re: [petsc-users] Missing symbols in libpetscts.h
To: filippo.spiga at disco.unimib.it, PETSc users list
<petsc-users at mcs.anl.gov>
Date: 22/07/10 10.37
> TSSetIFunction() doesn't exist in petsc-3.0.0. The same code will not
> work with both versions of petsc.
> You should stick with one version [i.e the latest ..
  Filippo SPIGA                MSc, HPC and GRID Technologist
  tel.:   +39 340 8387735      skype: filippo.spiga
«Nobody will drive us out of Cantor's paradise.»
      -- David Hilbert
