[petsc-users] configure problems
Dominik Szczerba
dominik at itis.ethz.ch
Thu Jul 22 15:17:19 CDT 2010
Hmmm I get the following errors:
$ cd src/ksp/ksp/examples/tutorials
Dominik at Tharsis/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/src/ksp/ksp/examples/tutorials
$ make ex2
makefile:16: /conf/variables: No such file or directory
makefile:17: /conf/rules: No such file or directory
makefile:856: /conf/test: No such file or directory
make: *** No rule to make target `/conf/test'. Stop.
On Thu, Jul 22, 2010 at 10:11 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> make ex2
> mpiexec -n 2 ./ex2.exe
> mpiexec -localonly -n 2 ./ex2.exe
> Satish
> On Thu, 22 Jul 2010, Satish Balay wrote:
> > Try running manually. MPICH2 install by default insists on passwd -
> > and this process isn't handled by petsc scripts properly.
> > [or use '--with-mpiexec=mpiexec --localonly']
> > Satish
> > On Thu, 22 Jul 2010, Dominik Szczerba wrote:
> > > Dear all,
> > > The problem was apparently that I was trying to configure Petsc under
> the 32
> > > bit terminal with the 64 bit MPI system installation.
> > > I managed to invoke the 64 bit terminal and configure and build Petsc
> as
> > > follows:
> > > ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> > > --download-c-blas-lapack=1 --with-x=0 --with-debugging=0
> --with-cc='win32fe
> > > cl' --with-fc=0
> > > (with the official MPICH2 64bitinstallation):
> > > MPI:
> > > Includes: -I/cygdrive/c/Program\ Files/MPICH2/include
> > > Library: /cygdrive/c/Program\ Files/MPICH2/lib/fmpich2.lib
> > > /cygdrive/c/Program\ Files/MPICH2/lib/fmpich2g.lib /cygdrive/c/Program\
> > > Files/MPICH2/lib/mpi.lib
> > > However, I am getting errors when executing "make test": (errors below)
> > > Any ideas how to proceed? (I clicked some 'yes when Windows popped up a
> > > yes/no security window)
> > > Regards,
> > > Dominik
> > > $ make PETSC_DIR=/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3
> > > PETSC_ARCH=win64-msvc-release test
> > > Running test examples to verify correct installation
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1
> MPI
> > > process
> > > See
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> > > Error while connecting to host, No connection could be made because the
> > > target machine actively refused it. (10061)
> > > Connect on sock (host=Tharsis, port=8676) failed, exhaused all end
> points
> > > Unable to connect to 'Tharsis:8676',
> > > sock error: Error = -1
> > > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
> MPI
> > > processes
> > > See
> points
> > > Completed test examples
> > > On Thu, Jul 22, 2010 at 4:13 PM, Satish Balay <balay at mcs.anl.gov>
> > > > > Many thanks for your precious feedback.
> > > > > My MPICH install is 64 bit but it seems that for some reason 32 bit
> VC
> > > > > compiler is invoked (I have both 32 and 64 installed).
> > > > As mentioned - whichever compiler is first in the PATH is used
> > > > cl
> > > > > I am clarifying with a local MSVC expert how to control this, will
> update
> > > > > you later today.
> > > > One way to control this - is to run the desired 'build env' cmd - as
> > > > mentioned in the installation instructions.
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html#Windows
> > > > Satish
> > > > > Dominik
> > > > > On Thu, Jul 22, 2010 at 3:45 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > > > sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> > > > > > > Files/MPICH2/lib/amd64/msmpi.lib
> > > > > > Looks like - if win32fe doesn't find the file - it doesn't try to
> > > > > > convert the path. This is not the cause of his configure failure.
> > > > > > The primary issue is: [which is much ahead in configure.log]
> > > > > > sh:
> /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
> > > > cl
> > > > > > -o conftest.exe -MT -wd4996 conftest.o /cygdrive/c/Program\
> > > > > > Files/MPICH2/lib/mpi.lib Ws2_32.lib
> > > > > > Executing:
> /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl
> > > > -o
> > > > > > sh: conftest.obj : error LNK2019: unresolved external symbol
> _MPI_Init
> > > > > > referenced in function _main^M
> > > > > > C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error
> > > > LNK1120:
> > > > > > 1 unresolved externals^M
> > > > > > Here cl is finding the correct library - but not MPI_Init symbol
> in it.
> > > > > > For whatever reason - libmpi.lib is not compatible.
> > > > > > Satish
> > > > > > On Thu, 22 Jul 2010, Farshid Mossaiby wrote:
> > > > > > > I doubt 'cl' can interpret Cygwin paths:
> > > > > > > cl : Command line warning D9002 : ignoring unknown option
> > > > > > > '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> > > > > > > Shouldn't win32fe convert this path first?
> > > > > > > Hope this helps.
> > > > > > > --- On Wed, 7/21/10, Dominik Szczerba <dominik at itis.ethz.ch>
> wrote:
> > > > > > > > From: Dominik Szczerba <dominik at itis.ethz.ch>
> > > > > > > > Subject: Re: [petsc-users] configure problems
> > > > > > > > To: "PETSc users list" <petsc-users at mcs.anl.gov>
> > > > > > > > Date: Wednesday, July 21, 2010, 7:01 PM
> > > > > > > > Coming back to the original problem:
> > > > > > > > I tried to compile MPICH2 myself
> > > > > > > > and failed because of wrong version of automake in Cygwin.
> > > > > > > > I then
> > > > > > > > installed the Windows binary available on the mpich2
> > > > > > > > webpage. I
> > > > > > > > configure petsc with:
> > > > > > > > $ ./config/configure.py PETSC_DIR=$PWD
> > > > > > > > --with-mpi-dir='/cygdrive/c/Program
> > > > > > > > Files/MPICH2' --with-x=0 --with-debugging=0
> > > > > > > > --with-cc='win32fe cl'
> > > > > > > > --with-fc=0
> > > > > > > > to hear at the end (of a very long configuration
> > > > > > > > process...):
> > > > > > > > sh:
> > > > > > > > cl -o conftest.exe -MT -wd4996
> > > > > > > > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > > > > > > > Executing:
> > > > > > > > _MPI_Init
> > > > > > > > error
> > > > > > > > LNK1120: 1 unresolved externals
> > > > > > > > Any directions why would the configuration look for a
> > > > > > > > nonexistent
> > > > > > > > library? The contents of the installation folder are:
> > > > > > > > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > > > > > > > total 808
> > > > > > > > drwx------+ 1 SYSTEM SYSTEM 4096
> > > > > > > > 2010-07-21 15:54 .
> > > > > > > > 2010-07-21 15:54 ..
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 4644
> > > > > > > > 2010-02-22 17:13 TraceInput.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09
> > > > > > > > cxx.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11
> > > > > > > > fmpich2.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13
> > > > > > > > fmpich2g.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 1936
> > > > > > > > 2010-02-22 17:13 irlog2rlog.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 10430 2010-02-22 16:30
> > > > > > > > mpe.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29
> > > > > > > > mpi.lib
> > > > > > > > -rwx------+ 1 SYSTEM SYSTEM 61286 2010-02-22 16:30
> > > > > > > > rlog.lib
> > > > > > > > Best regards,
> > > > > > > > Dominik
> > > > > > > > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org>
> > > > > > > > wrote:
> > > > > > > > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley
> > > > > > > > <knepley at gmail.com>
> > > > > > > > wrote:
> > > > > > > > >> This would do you absolutely no good. Even Jed's
> > > > > > > > thing needs all the
> > > > > > > > >> information that the configure provides. CMake is
> > > > > > > > exactly what it
> > > > > > > > >> says, make. It does no configuration
> > > > > > > > > This isn't true, CMake isn't a build system at all, it
> > > > > > > > does
> > > > > > > > > configuration and produces build files for another
> > > > > > > > tool (like make or an
> > > > > > > > > IDE). I see no point in maintaining duplicate
> > > > > > > > configuration systems,
> > > > > > > > > and CMake's scripting language is so attrocious that
> > > > > > > > "replacing"
> > > > > > > > > BuildSystem with CMake script would be a disaster.
> > > > > > > > It's
> > > > > > > > > cross-compilation support is also a bit weak, and
> > > > > > > > there are a pile of
> > > > > > > > > other things that it does poorly (mostly related to
> > > > > > > > pathologically
> > > > > > > > > dysfunctional "Find*.cmake" modules). That doesn't
> > > > > > > > mean it isn't useful
> > > > > > > > > for producing build files.
> > > > > > > > > Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100722/7cecfa12/attachment.htm>
