[petsc-users] Is it possible to use global variables in Petsc code?
    Li, Zhisong (lizs)
    lizs at mail.uc.edu
    Wed Jul 21 18:19:33 CDT 2010
 Hi, Petsc Team,
I wonder if we can utilize a global variable when using PETSc, such as a declaration and definition in the main function:
extern PetscScalar x, y, z;
    x = 1.0;
This should be a regular usage in ANSI C and will help a lot when we have user-defined functions. If it can work, then it will easily replace those functions like DAGetInfo( ) and save running time. But I don't see any examples of using this in PETSc before. And I've tried this but it doesn't work or cannot pass the compiling check.
Thank you.
Zhisong Li
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100721/d495659d/attachment.htm>
