[petsc-users] parallel complex preconditioner needed
Jed Brown
jed at 59A2.org
Tue Jul 20 10:18:18 CDT 2010
On Tue, 20 Jul 2010 11:06:53 -0400, Craig Tanis <craig at tanistech.com> wrote:
> This is a frequency domain EM simulation.
This is an especially difficult problem if you have large jumps in
coefficients.
> I think my main problem is interpreting the options available.. PETSc
> apparently has a built-in direct solver, which is how ILU works on a
> single processor, right?
The I in ILU stands for Incomplete. The direct solver is LU which you
can access with -pc_type lu.
> Are the parallel direct solvers in some 3rd party package,like hypre,
> that I need to install separately? Do I somehow specify a direct
> solver to use for the built-in ILU ?
Yes, the native LU is not parallel, you can get one with
--download-{blacs,scalapack,mumps} or --download-superlu_dist, and
-pc_type lu -pc_factor_mat_solver_package mumps (or superlu_dist).
To try a 1-level domain decomposition method, run with -pc_type asm,
check the -help options under -pc_asm_*, and control the subdomain
solver with -sub_{ksp,pc}_*
Jed
