[petsc-users] my code runs too slow
Xuan YU xxy113 at psu.edu
Wed Jul 7 13:54:15 CDT 2010
Reordering does work. But it went back to beginning. Info is shown
below. I want to follow the example(http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-2.3.3/src/ts/examples/tutorials/ex7.c.html
)  ierr =
TSSetRHSJacobian
(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);CHKERRQ(ierr); I
thought this code can compute Jacobian. Actually, I have not write the
Jacobian function yet. Does it necessary to speed up the code?
TS Object:
   type: beuler
   maximum steps=50
   maximum time=50
   total number of nonlinear solver iterations=647
   total number of linear solver iterations=647
   SNES Object:
     type: ls
       line search variant: SNESLineSearchCubic
       alpha=0.0001, maxstep=1e+08, minlambda=1e-12
     maximum iterations=50, maximum function evaluations=10000
     tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
     total number of linear solver iterations=50
     total number of function evaluations=51
     KSP Object:
       type: gmres
         GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
         GMRES: happy breakdown tolerance 1e-30
       maximum iterations=10000, initial guess is zero
       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
       left preconditioning
       using PRECONDITIONED norm type for convergence test
     PC Object:
       type: ilu
         ILU: out-of-place factorization
         0 levels of fill
         tolerance for zero pivot 1e-12
         using diagonal shift to prevent zero pivot
         matrix ordering: natural
         factor fill ratio given 1, needed 1
           Factored matrix follows:
             Matrix Object:
               type=seqaij, rows=1830, cols=1830
               package used to perform factorization: petsc
               total: nonzeros=1830, allocated nonzeros=1830
               total number of mallocs used during MatSetValues calls =0
                 not using I-node routines
       linear system matrix = precond matrix:
       Matrix Object:
         total: nonzeros=1830, allocated nonzeros=45750
         total number of mallocs used during MatSetValues calls =1830
On Jul 7, 2010, at 2:36 PM, Satish Balay wrote:
> What function are you using to compute jacobian? Perhaps you are
> missing MatAssembly() calls in that function?
> Or reordering the code as follows should work - but the correct
> location for MatAssembly() calls are in the routine you are using for
> assembling the jacobian.
> Satish
> ierr = MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,
> 10,PETSC_NULL,&J);CHKERRQ(ierr);
> ierr = SNESComputeJacobian(ts_snes,CV_Y,&J,&J,&flag);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatGetColoring(J,MATCOLORINGSL,&iscoloring);CHKERRQ(ierr);
> ierr = MatFDColoringCreate(J,iscoloring,&matfdcoloring);CHKERRQ(ierr);
> ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode (*)
> (void))f,(void*)&appctx);CHKERRQ(ierr);
> ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr);
> ierr =
> TSSetRHSJacobian(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);
> On Wed, 7 Jul 2010, Xuan YU wrote:
>> Sorry, this is the complete one:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state!
>> [0]PETSC ERROR: Not for unassembled matrix!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> fdc7be12de37b8a400b6e561de9850bcc7e79f4f  HG Date: Fri Jul 02
>> 21:17:36 2010
>> -0500
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./pihm on a arch-linu named lionxi.rcc.psu.edu by
>> xxy113 Wed
>> Jul  7 14:32:11 2010
>> [0]PETSC ERROR: Libraries linked from
>> /gpfs/home/xxy113/soft/petsc-dev/arch-linux-gnu-c-debug/lib
>> [0]PETSC ERROR: Configure run at Sun Jul  4 14:09:16 2010
>> [0]PETSC ERROR: Configure options --download-f-blas-lapack=1
>> --download-mpich=1
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatGetColoring() line 491 in src/mat/color/color.c
>> [0]PETSC ERROR: VecRestoreArrayPrivate3() line 201 in /work/petsc/
>> pihm.c
>> On Jul 7, 2010, at 2:28 PM, Satish Balay wrote:
>>>>> ierr =
>>> Perhaps there is a function thats set to compute jacobinan thats not
>>> assembling the matrix properly?
>>> Also - please dont' truncate error messages - when you send
>>> them. Incomplete info is not useful.
>>> Satish
>>> On Wed, 7 Jul 2010, Matthew Knepley wrote:
>>>> You have to assemble
>>>> a) after setting values
>>>> b) before using the matrix
>>>> Please consult the user examples where this is done correctly and
>>>> the
>>>> manual
>>>> section which explains the assembly process.
>>>>  Matt
>>>> On Wed, Jul 7, 2010 at 8:13 PM, Xuan YU <xxy113 at psu.edu> wrote:
>>>>> ierr =
>>>>> This assembly removes the unused space here. Since no values are
>>>>> inserted - it squezes out all of the allocated space. Perhaps
>>>>> you just
>>>>> need to remove these 2 calls as the actual matrix is assembled
>>>>> further
>>>>> down the code.
>>>>> I removed these 2
>>>>> But got Error Message
>>>>> Satish
>>>>> ierr =
>>>>> ierr =
>>>>> (*)(void))f,(void*)&appctx);CHKERRQ(ierr);
>>>>> ierr =
>>>>> TSSetRHSJacobian
>>>>> These are the Jacobian related codes.
>>>>> Looks like you are zero-ing out the non-zero structure - before
>>>>> assembling the matrix.
>>>>> Are you calling MatZeroRows() or MatZeroEntries() or something
>>>>> else -
>>>>> before assembling the matrix?
>>>>> Satish
>>>>> I made a change: ierr =
>>>>> 5,PETSC_NULL,&J);CHKERRQ(ierr);
>>>>> Time of the code did not change much, and got the info:
>>>>> Matrix Object:
>>>>>  total: nonzeros=1830, allocated nonzeros=36600
>>>>> On Jul 7, 2010, at 12:51 PM, Satish Balay wrote:
>>>>> total: nonzeros=1830, allocated nonzeros=29280
>>>>> There is something wrong with your preallocation or matrix
>>>>> assembly. You should see zero mallocs for efficient assembly.
>>>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#efficient-assembly
>>>>> satish
>>>>> Hi,
>>>>> I finite difference Jacobian approximation for my TS model. The
>>>>> size
>>>>> of
>>>>> the
>>>>> vector is 1830. I got the following info with(-ts_view):
>>>>> type: beuler
>>>>> maximum steps=50
>>>>> maximum time=50
>>>>> SNES Object:
>>>>> type: ls
>>>>> KSP Object:
>>>>> type: gmres
>>>>> PC Object:
>>>>> type: ilu
>>>>> 0 levels of fill
>>>>>    Matrix Object:
>>>>> Matrix Object:
>>>>> 50 output time step takes me 11.877s. So I guess there is
>>>>> something
>>>>> not
>>>>> appropriate with my Jacobian Matrix. Could you please tell me
>>>>> how to
>>>>> speed
>>>>> up
>>>>> my code?
>>>>> Thanks!
>>>>> Xuan YU
>>>>> xxy113 at psu.edu
>>>>> Xuan YU (俞烜)
>>>>> xxy113 at psu.edu
>>>>> Xuan YU (俞烜)
>>>>> xxy113 at psu.edu
>>>>> Xuan YU (俞烜)
>>>>> xxy113 at psu.edu
>> Xuan YU (俞烜)
>> xxy113 at psu.edu
Xuan YU (俞烜)
xxy113 at psu.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100707/e44e44a4/attachment-0001.htm>
