[petsc-users] my code runs too slow
Xuan YU
xxy113 at psu.edu
Wed Jul 7 13:33:24 CDT 2010
Sorry, this is the complete one:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Not for unassembled matrix!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
fdc7be12de37b8a400b6e561de9850bcc7e79f4f HG Date: Fri Jul 02 21:17:36
2010 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./pihm on a arch-linu named lionxi.rcc.psu.edu by
xxy113 Wed Jul 7 14:32:11 2010
[0]PETSC ERROR: Libraries linked from /gpfs/home/xxy113/soft/petsc-dev/
arch-linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Sun Jul 4 14:09:16 2010
[0]PETSC ERROR: Configure options --download-f-blas-lapack=1 --
download-mpich=1
[0]PETSC ERROR:
[0]PETSC ERROR: MatGetColoring() line 491 in src/mat/color/color.c
[0]PETSC ERROR: VecRestoreArrayPrivate3() line 201 in /work/petsc/pihm.c
On Jul 7, 2010, at 2:28 PM, Satish Balay wrote:
>>> ierr = SNESComputeJacobian(ts_snes,CV_Y,&J,&J,&flag);CHKERRQ(ierr);
> Perhaps there is a function thats set to compute jacobinan thats not
> assembling the matrix properly?
> Also - please dont' truncate error messages - when you send
> them. Incomplete info is not useful.
> Satish
> On Wed, 7 Jul 2010, Matthew Knepley wrote:
>> You have to assemble
>> a) after setting values
>> b) before using the matrix
>> Please consult the user examples where this is done correctly and
>> the manual
>> section which explains the assembly process.
>> Matt
>> On Wed, Jul 7, 2010 at 8:13 PM, Xuan YU <xxy113 at psu.edu> wrote:
>>> On Jul 7, 2010, at 2:06 PM, Satish Balay wrote:
>>> On Wed, 7 Jul 2010, Xuan YU wrote:
>>> ierr = MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,
>>> 10,PETSC_NULL,&J);CHKERRQ(ierr);
>>> ierr = MatAssemblyBegin(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>> ierr = MatAssemblyEnd(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>> This assembly removes the unused space here. Since no values are
>>> inserted - it squezes out all of the allocated space. Perhaps you
>>> just
>>> need to remove these 2 calls as the actual matrix is assembled
>>> further
>>> down the code.
>>> I removed these 2
>>> But got Error Message
>>> Satish
>>> ierr = MatGetColoring(J,MATCOLORINGSL,&iscoloring);CHKERRQ(ierr);
>>> ierr =
>>> MatFDColoringCreate(J,iscoloring,&matfdcoloring);CHKERRQ(ierr);
>>> ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode
>>> (*)(void))f,(void*)&appctx);CHKERRQ(ierr);
>>> ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr);
>>> ierr =
>>> TSSetRHSJacobian
>>> (ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);
>>> These are the Jacobian related codes.
>>> On Jul 7, 2010, at 1:51 PM, Satish Balay wrote:
>>> total: nonzeros=1830
>>> mallocs used during MatSetValues calls =1830
>>> Looks like you are zero-ing out the non-zero structure - before
>>> assembling the matrix.
>>> Are you calling MatZeroRows() or MatZeroEntries() or something
>>> else -
>>> before assembling the matrix?
>>> Satish
>>> I made a change: ierr =
>>> MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,5,PETSC_NULL,&J);CHKERRQ(ierr);
>>> Time of the code did not change much, and got the info:
>>> Matrix Object:
>>> type=seqaij, rows=1830, cols=1830
>>> total: nonzeros=1830, allocated nonzeros=36600
>>> total number of mallocs used during MatSetValues calls =1830
>>> not using I-node routines
>>> On Jul 7, 2010, at 12:51 PM, Satish Balay wrote:
>>> total: nonzeros=1830, allocated nonzeros=29280
>>> There is something wrong with your preallocation or matrix
>>> assembly. You should see zero mallocs for efficient assembly.
>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#efficient-assembly
>>> satish
>>> Hi,
>>> I finite difference Jacobian approximation for my TS model. The size
>>> of
>>> the
>>> vector is 1830. I got the following info with(-ts_view):
>>> type: beuler
>>> maximum steps=50
>>> maximum time=50
>>> total number of nonlinear solver iterations=647
>>> total number of linear solver iterations=647
>>> SNES Object:
>>> type: ls
>>> line search variant: SNESLineSearchCubic
>>> alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>>> maximum iterations=50, maximum function evaluations=10000
>>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>> total number of linear solver iterations=50
>>> total number of function evaluations=51
>>> KSP Object:
>>> type: gmres
>>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> GMRES: happy breakdown tolerance 1e-30
>>> maximum iterations=10000, initial guess is zero
>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
>>> left preconditioning
>>> using PRECONDITIONED norm type for convergence test
>>> PC Object:
>>> type: ilu
>>> ILU: out-of-place factorization
>>> 0 levels of fill
>>> tolerance for zero pivot 1e-12
>>> using diagonal shift to prevent zero pivot
>>> matrix ordering: natural
>>> factor fill ratio given 1, needed 1
>>> Factored matrix follows:
>>> Matrix Object:
>>> package used to perform factorization: petsc
>>> total: nonzeros=1830, allocated nonzeros=1830
>>> total number of mallocs used during MatSetValues calls =0
>>> linear system matrix = precond matrix:
>>> Matrix Object:
>>> 50 output time step takes me 11.877s. So I guess there is something
>>> not
>>> appropriate with my Jacobian Matrix. Could you please tell me how to
>>> speed
>>> up
>>> my code?
>>> Thanks!
>>> Xuan YU
>>> xxy113 at psu.edu
>>> Xuan YU (俞烜)
>>> xxy113 at psu.edu
>>> Xuan YU (俞烜)
>>> xxy113 at psu.edu
>>> Xuan YU (俞烜)
>>> xxy113 at psu.edu
Xuan YU (俞烜)
xxy113 at psu.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100707/aec3bc29/attachment-0001.htm>
