[petsc-users] my code runs too slow
Xuan YU
xxy113 at psu.edu
Wed Jul 7 12:17:09 CDT 2010
I made a change: ierr = MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,
5,PETSC_NULL,&J);CHKERRQ(ierr);
Time of the code did not change much, and got the info:
Matrix Object:
type=seqaij, rows=1830, cols=1830
total: nonzeros=1830, allocated nonzeros=36600
total number of mallocs used during MatSetValues calls =1830
not using I-node routines
On Jul 7, 2010, at 12:51 PM, Satish Balay wrote:
>> total: nonzeros=1830, allocated nonzeros=29280
> There is something wrong with your preallocation or matrix
> assembly. You should see zero mallocs for efficient assembly.
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#efficient-assembly
> satish
> On Wed, 7 Jul 2010, Xuan YU wrote:
>> Hi,
>> I finite difference Jacobian approximation for my TS model. The
>> size of the
>> vector is 1830. I got the following info with(-ts_view):
>> type: beuler
>> maximum steps=50
>> maximum time=50
>> total number of nonlinear solver iterations=647
>> total number of linear solver iterations=647
>> SNES Object:
>> type: ls
>> line search variant: SNESLineSearchCubic
>> alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=50
>> total number of function evaluations=51
>> KSP Object:
>> type: gmres
>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> GMRES: happy breakdown tolerance 1e-30
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object:
>> type: ilu
>> ILU: out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 1e-12
>> using diagonal shift to prevent zero pivot
>> matrix ordering: natural
>> factor fill ratio given 1, needed 1
>> Factored matrix follows:
>> Matrix Object:
>> package used to perform factorization: petsc
>> total: nonzeros=1830, allocated nonzeros=1830
>> total number of mallocs used during MatSetValues calls =0
>> linear system matrix = precond matrix:
>> Matrix Object:
>> 50 output time step takes me 11.877s. So I guess there is something
>> not
>> appropriate with my Jacobian Matrix. Could you please tell me how
>> to speed up
>> my code?
>> Thanks!
>> Xuan YU
>> xxy113 at psu.edu
Xuan YU (俞烜)
xxy113 at psu.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100707/860c811b/attachment.htm>
