[petsc-users] How to debug problem with MatSetValues
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Mon Jul 5 09:27:45 CDT 2010
Matthew Knepley wrote:
> On Mon, Jul 5, 2010 at 3:22 PM, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
> Hi,
> I've some trouble with matrix values that are set by MatSetValues,
> but are missing in the final matrix. I can reduce the problem to a
> 75x75 matrix that is created on four processors. I create it quite
> simple with:
> MatCreateMPIAIJ(PETSC_COMM_WORLD, 12, 12, 75, 75, petscMatrix) on p0
> MatCreateMPIAIJ(PETSC_COMM_WORLD, 18, 18, 75, 75, petscMatrix) on p1
> MatCreateMPIAIJ(PETSC_COMM_WORLD, 18, 18, 75, 75, petscMatrix) on p2
> MatCreateMPIAIJ(PETSC_COMM_WORLD, 27, 27, 75, 75, petscMatrix) on p3
> On all processors, the values are set with the following command:
> MatSetValues(petscMatrix, 1, &rowIndex, cols.size(), &(cols[0]),
> &(values[0]), ADD_VALUES);
> where rowIndex is an integer, cols is of type std::vector<int> and
> values if of type std::vector<double>. Before
> I do not think this is always kosher. std::vector<> may store values
> however it wants (perhaps in a
> contiguous array). std::valarray<> I believe mandates a contiguous
> array, however even it does not
> give you access to the explicit pointer (you have to use &v[0]
> nonsense). Reasons to hate the STL.
This is guaranteed by the C++ standard, so this shouldn't be the problem:
A vector's storage is guaranteed to be contiguous. From ISO 14882, 2nd
ed., 23.2.4 [lib.vector]:
"The elements of a vector are stored contiguously, meaning that if v is
a vector<T, Allocator> where T is some type other than bool, then it
obeys the identity &v[n] == &v[0] + n for all 0 <= n < v.size()."
> MatSetValues is called, I run over the arrays and print all the
> entries that are added to the matrix. Finally,
> MatAssemblyBegin(petscMatrix, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(petscMatrix, MAT_FINAL_ASSEMBLY);
> are called. To check the matrix, I use the option
> -mat_view_matlab. Okay, now some of the entries are missing and
> I've absolute no idea what I did wrong (i.e. entry row 48-col 69,
> which is only once by rank 3). What is the best way to debug the
> problem? I use petsc 3.0.0p11, which is compiled in debug mode. My
> code is also compiled in debug mode and valgrind does not report
> any errors. Thanks for any suggestions.
> MatAssemble and MatView after every insertion.
Good idea, will try it.
Thomas
> Matt
> Thomas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
