[petsc-users] How to debug problem with MatSetValues
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Jul 5 08:22:50 CDT 2010
I've some trouble with matrix values that are set by MatSetValues, but
are missing in the final matrix. I can reduce the problem to a 75x75
matrix that is created on four processors. I create it quite simple with:
MatCreateMPIAIJ(PETSC_COMM_WORLD, 12, 12, 75, 75, petscMatrix) on p0
MatCreateMPIAIJ(PETSC_COMM_WORLD, 18, 18, 75, 75, petscMatrix) on p1
MatCreateMPIAIJ(PETSC_COMM_WORLD, 18, 18, 75, 75, petscMatrix) on p2
MatCreateMPIAIJ(PETSC_COMM_WORLD, 27, 27, 75, 75, petscMatrix) on p3
On all processors, the values are set with the following command:
MatSetValues(petscMatrix, 1, &rowIndex, cols.size(), &(cols[0]),
&(values[0]), ADD_VALUES);
where rowIndex is an integer, cols is of type std::vector<int> and
values if of type std::vector<double>. Before MatSetValues is called, I
run over the arrays and print all the entries that are added to the
matrix. Finally,
MatAssemblyBegin(petscMatrix, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(petscMatrix, MAT_FINAL_ASSEMBLY);
are called. To check the matrix, I use the option -mat_view_matlab.
Okay, now some of the entries are missing and I've absolute no idea what
I did wrong (i.e. entry row 48-col 69, which is only once by rank 3).
What is the best way to debug the problem? I use petsc 3.0.0p11, which
is compiled in debug mode. My code is also compiled in debug mode and
valgrind does not report any errors. Thanks for any suggestions.
Thomas
